Question about Pentair Kreepy Krauly Inground Automatic Cleaner
How di I use embay countdown? - Pentair Kreepy Krauly Inground Automatic Cleaner
Hi there, my name is Kasu Embaye. I have a problem of I/O card parity interrupt f000:f188 on my dell optiplex 780 computer.so,how to fix this problem? can you help me?
Hi mmm it sounds to me like your motherboard has got some problems. sometimes running system tests through the boot menu may help but should indicate weather you need a new motherboard or not. Sometimes a good clean inside computer is the way to go as well... Hope this helps
Kindest regards
Jan 10, 2015 | Dell OptiPlex 780 MT Desktop Computer...
How do I reset the countdown timer on a slazenger digital watch...please
Try Googling (Slazenger)(model)(manual) without parens to get instructions.
May 12, 2017 | Watches
Programming to command other switches
Question is not clear.
Add a comment and say specifically what timer you have and what type of switch(es) you want to control, and add what voltage you are working with and what color wires you have.
You posted under Leviton 6230 30-minute countdown timer.
Generally, a countdown timer is not considered a programmable timer since the countdown program is already inside the timer.
With countdown timer, you push a button that turns circuit ON, and after countdown expires, the circuit turns OFF.
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#6230
Countdown timer can easily switch a contactor ON, and then turn it off after countdown expires.
http://waterheatertimer.org/H230A.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 02, 2011 | Leviton 6230M Decora Four Preset...
Despite the fans working on a plain Jane single pole switches, I can't get these 6515M switches to work for my 1.3 ceiling fans. The fan hums and all I get on the timers are red LEDs. These timers...
1) Leviton 6515 is incandescent only:
http://www.amazon.com/Leviton-6515M-I-2-5-10-15-Electronic-Incandescent/dp/B0007NOZDI
2) Below is list of countdown timers with horsepower rating so they work for fans:
GE15088 countdown timer is rated 3/4 hp
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay
Intermatic spring wound countdown timers are rated for 2 horsepower
http://www.intermatic.com/products/timers/in-wall%20timers/decorator%20spring%20wound%20timers.aspx
Woods spring-wound countdown timer says bath/ ceiling fans, but doesn't give horsepower
http://waterheatertimer.org/pdf/Wood-59700-series--spring-wound.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#countdown
Woods push-button countdown is 1/4 horsepower
http://www.amazon.com/Woods-59014-Decora-12-8-4-2-12-Hour/dp/B002C54GH4
Wattstopper RT50 at Grainger shows 1/6 horsepower rating
http://www.grainger.com/Grainger/WATT-STOPPER-Time-Switch-2HTE1?Pid=search
3) Following timers are NOT rated for fans:
Lutron MA-T51 countdown timer specifically says it cannot be used for motors.
http://www.amazon.com/Lutron-MA-T51-WH-Maestro-Countdown-Timer/dp/B001EFV1DA
http://www.lutron.com/TechnicalDocumentLibrary/0301041A.pdf
Pass and Seymour RT1 countdown does not show rating for horsepower, so this timer will probably not work for fan motor
http://www.homedepot.com/Electrical/h_d1/N-5yc1vZ1xg8Zarcd/
Feb 26, 2011 | Leviton 6515M-W Timer Switch, 2-5-10-15...
I am installing the timer for a whole house fan. I hooked red up to load, black to hot and white to neutral per instructions...confirmed with meter....the timer does not seem to work..I can turn on and...
A) GE 15069 image at Amazon
http://www.amazon.com/60-minute-Automatic-Shut-Off-Timer-Switch/dp/B002DNAE7Q
15069 manual
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/In-Wall-15069-Manual-eng.pdf
Manual shows GE 15069 countdown timer is rated up to 1/2 horsepower
Whole house fan is likely 3/4 horsepower >> check nameplate on fan motor.
B) work around:
Hook timer up to a contactor/relay.
Timer turns on 120 volt, 7 watt contactor coil.
Contactor turns on fan motor
Square D contactor at Grainger
http://www.grainger.com/Grainger/SQUARE-D-Compact-Contactor-5B132?Pid=search
http://www.pexsupply.com/Furnas-Controls-45EG20AF-2-Pole-30-Amp-120V-Contactor
I buy these contactors at local HVAC supply for $15
add a comment if you need help wiring this device.
C) List below shows countdown timers with horsepower rating:
Lutron MA-T51 countdown timer specifically says it cannot be used for motors, which says the electronics inside each device is Load specific
Dec 12, 2010 | GE 60minute Automatic ShutOff Timer Switch...
Adding countdown timer to profile
Go to this link and you will be able to download a Facebook countdown timer.
Mar 24, 2010 | Facebook Social Network
Why does the dash count down to start the car?
Hi Tyler- The countdown happens when you turn the ignition switch to the "On" position without turning the engine over. It (the countdown) is for the oil level display. Once the countdown is complete, the digital oil level indicator will tell you how much oil is in the case. You do not need to wait for the countdown to reach 0:00 to start your car.
Oct 21, 2008 | 1999 Porsche Boxster
Pentair Kreepy Krauly Inground Automatic Cleaner Logo
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
