The laptop was on and the battery was low so i plugged the charger in and now the moon is on and the screen stays black. I tried charging for a while then turning it on, but the power light and moon light comes on. I have had it less then 24hrs and it is brand new! please help!
    Novelist:
  • 137 Answers
The "moon" is your sleep mode, indicator. Press the power button for a second and it should come right back on.
Thank You For Choosing FixYa~!
Posted on Mar 17, 2011
    Brigadier General:
  • 10,406 Answers
> have had it less than 24 hours
Take it back to where you purchased it, and get them to assist you.
You just gave them $500 to $1000 -- make them _EARN_ some of that money, by helping you!
Why laptop screen goes black after plugging battery charger?
Try another charger and then see or it might be a power options issue
Try this
SOLUTION: If you have a second computer, use Remote Desktop by choosing 'Run', type 'mstsc', type the name of the computer with a black screen, and connect. After logging in, open 'Control Panel', and choose 'Power Options'. On the left panel choose 'Choose when to turn off the display'. On the row labeled 'Adjust plan brightness', under the 'Plugged in' column, turn up the brightness slider.
Aug 10, 2014 | Sony SVE15135CXS - VAIO E Series...
Won't Charge
If it's not a recognized charger it'll stop charging the battery and try to run on the charger alone. If the peak draw of the laptop is higher than the charger output, it'll go right back off.
Try removing the battery and see if it'll boot on the charger alone.
Apr 01, 2014 | ASUS Q200e Touchscreen Notebook
Screen only lights up on battery power but no ac adapter/charger tried three ac chargers all do the same thing so its not screen or charger
Hi David
It sounds like a fault to its power transition section circuit. Actually, this circuit is built inside the mother board to your laptop.
Please contact the authorized service center, and describe and show them the problem you do experience now, with your laptop. It can be rectified. Gopakumar Gopalan Google
Feb 28, 2014 | Acer Aspire 7720 Notebook
Black screen phone turns on but screen stays black why
How long have you had the phone?
Sounds like hardware failure.
If its still under warranty you could take it in for repair.
try turning phone on while plugged into the charger. Does this make any difference?
Try charging using a different charger. The fault could be battery or charger related. Might have just enough juice to start the phone but not the screen
hope this helps
Jan 22, 2014 | Samsung Behold II SGH-t939 Smartphone
How can I fix my hp61 of it won't start screen
You say the battery is charging? Have you tried another Cord/Charger with the EXACT same power specs? Has the AC jack been damaged due to pulling on the cord while plugged in? Any damage? Drop? Do you leave the Laptop plugged in while not in use?
Apr 13, 2013 | Computers & Internet
SAMSUNG LAPTOP PLUGGED IN NOT CHARGING
try removing the battery and just use the mains power. If the laptop works you may need a new battery. If it doesn't your charger is faulty.
Nov 26, 2012 | Samsung R580 Notebook
When I power up my Laptop the screen stays black?
try to do this:
- remove the battery and charger (everything connected to the pc) then press the power button for 1 minute.. - plug back in the charger - after few secs try to turn it on
hope this helps :D
Mar 26, 2011 | Computers & Internet
At start up the BIOS screen fades to black..nothing else ever come up the screen.. warranty expired in September 09..figures...
try turning it off and turning it back on with cord charger plugged in... it could have low battery charge or is burning up. make sure its cooled off and when using it use it on a hard surface.
Mar 09, 2010 | Toshiba Satellite L305D-S5904 Laptop
Charger light flashes when plugged into laptop , stays on solid when unplugged,had charger checked 19v ok ,had socket checked 19v ok ,then checked to first board 19v ok ?? has a board gone down ??? annoyin...
your battery pack is causing your problem rule #1 never!! leave the charger in!! everytime you start up!! run off the batteries till the power low light come's on then apply the charger constant charging causes early failure of all/ any nican battery pack
Jan 13, 2010 | Acer Aspire 5920-6335 Laptop
My toshiba satallite p200-1ee laptop is not charging. Battry life left: 40% When on: The Charging light blinks 3 times every few seconds and the screen dims with it. When off (But pugged into mains): the...
If you plug the charger into the computer without the battery and the laptop runs fine, then I would suggest to you that your battery is failing and will no longer accept the charge. On the other hand if the laptop will not stay running or acts strage and the screen dims and gets bright, then I would suggest to you that the charger's built in voltage regulator is failing and will damage the laptop if it continued to be used. A bad charger will also permenently destroy the battery condition.
Dec 01, 2009 | Computers & Internet
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
