Question about First Alert 9120B Smoke Detector with Batt Backup & SL177 Strobe Kit
I just replaced the 9v battery in all 8 smoke detectors (First Alert model 9120B). They all show a solid green light, yet continue to take turns chirping. How do I "reset" them?
  • 34 Answers
SOURCE: smoke detector won't stop chirping.
it may need to be cleaned or it is bad may need to be replaced
Posted on Oct 25, 2009
TeaCii
  • 90 Answers
SOURCE: I replaced the 9 voly battery to the Smoke and
Can you pleas ensure that you have cleaned the unit as well. If it is not broken, that would be the probable cause. You can ask your local fire dept. to assist. They do that for free :-)
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Posted on Apr 23, 2010
reddawgesq
  • 134 Answers
SOURCE: Hardwired Kidde Nighthawk co/smoke detector
If the display shows "Lb", the battery is probably low; replace it. If the display shows "Err", push and hold the Peak Level button. Does the display change to "E09"? If so, then you have just been "had" by the grossly under-documented "planned obsolescence feature" called, rather matter-of-factly, "End of Life". This means that ~7 years after first being powered up, the unit will, BY DESIGN, cease to function, forcing you to buy a replacement. Would have been nice of Kidde to include THAT warning on the OUTSIDE of the package. Call their "Hotline" at 1-800-880-6788 and tell them what you think of that policy. If it is still under warranty (5 or 7 years depending on date of manufacture) they should replace it. In any event, buy another one; if they replace your first one you will have twice the protection. Not a bad thing. *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Instructor
Posted on Feb 01, 2011
  • 4736 Answers
SOURCE: My SS785 smoke detector "chirps"
The unit may simply need cleaning. As dust and lint will accumulate on the unit and in the senors.
You can accomplish this with a can of compressed air with a straw nozzle (like you clean your computer with). Carefully remove the cover and blow out all the nooks and crannies of the detector. If you can't remove the cover, stick the straw nozzle into any opening you can see and give it a quick blast of air.
The detector may alarm due to the COLD air from the can. But, should stop once it warms back up.
You should clean all the detectors in the house at least every 6 months.
I find it unusual, that there is no battery backup in your detector. What happens if you have a fire during a power outage?
Posted on Feb 23, 2011
dcramer531
  • 1654 Answers
SOURCE: i want to disable the remote sensor function on
First you need to remove the battery, hold test button down while re-installing battery, when detector beeps,it disarms remote feature. Normal detector then. this should dissable the remote feature. this is a very common complaint. If for some reason it wont turn the remote off get a piece of tape to cover the sensor.
If your happy with this solution a vote for the thumb up would be greatly appreciated. Thanks for using Fix Ya
Posted on Jul 05, 2011
How to replace a battery to First alert mod sa303
http://www.firstalertstore.com/store/images/pdf/sa305cn3-10-year-battery-smoke-alarm.pdf
Follow the link above to download the user guide. There is a door that opens to the side of the device that contains the battery. The drawing is not very good. I believe the door is like a tray that holds the battery? Take care that the polarity is correct...often times 9V connectors will permit improper polarity connections which could harm the unit and destroy the battery. Fortunately, it's not usually too difficult, especially if you pull the unit down first so you can see better...good luck!
Feb 13, 2015 | Home
What causes continual beeping
With some smoke detectors, this indicates a low battery. Try putting in a new battery and see whether it stops beeping. If it doesn't add a comment to this question and specify the make and model of your smoke detector.
Oct 06, 2014 | Home
False alarms in the middle of the night
Sometimes an alarm will malfunction if a small spider or insect gets inside and also if it's in an area where it;s dusty will set it off as well. If you can take the face off you can lightly dust them or lightly blow them out with low air pressure. I even vacuumed our low one. High humidity will set them off as well.
Dec 07, 2013 | First Alert Smoke Alarm, 9120B"
First alert 9120b
Hi hislop_amand,
I know this is coming to you late yet I just seen your post and hope the following can still help you or others.
Kind Regards,
SD
FIRST ALERT Model: 9120 9120B
Normal Operation (AC Power)
Green LED ON; flashing Red LED once/ minute
No Audible Alarm
Normal Operation (DC Power - 9120B only)
Green LED OFF; Red LED flashes once/minute
No Audible Alarm
Mar 23, 2013 | First Alert SC9120B Smoke / CO Detector...
Our hard wire smoke detector model i12060 just beeped really lound a few times and stopped, it glows green and flashes red every few minutes?
Change the 9V backup battery,with a new one.Push and hold the reset button for a minute or two for the alarm to to go off like about 30-40 sec. for the smoke detector to dectected the 9V backup battery power sourced.The green power LED light indicator will stop flashing also the beeping sounds too.
Jul 12, 2011 | Kidde 120-Volt Front Load Battery Smoke...
I could not get to battery compartment of the first alert smoke alarm. Please tell me how to replace with new battery.
Hold the entire smoke detector,turn it to the left or right,u will able to take the smoke detector out.The battery compartment is in the back.
Sep 09, 2010 | First Alert SA302 Dual System Smoke...
Every hour my detector beeps and the green lights flashing is it carbon nonoxide or smoke or battery??
If it only beeps once and then pauses, the batteries are suspect. The batteries should be replaced twice each year. I like to change them when we change the clocks back and forth.
I hope that this helps.
asnowman
Hint you can test them with a match (blow it out) and let the smoke rise into the detector. I recommend that this be done at lease once a year.
Hope this helps
asnowman
Apr 17, 2010 | First Alert SA302 Dual System Smoke...
Smoke alarm/carbon monoxide detector
I have a First Alert Smoke Detector Model SA 86RAC.When I changed the Battery today it beeps.How do I fix this problem?
Sep 22, 2007 | First Alert SA302 Dual System Smoke...
First Alert 9120B Smoke Detector with Batt Backup & SL177 Strobe Kit Logo
85 people viewed this question
Top First Alert Home Security Experts
charlie rodriguez
charlie rodriguez
Ronny Bennett Sr.
Ronny Bennett Sr.
woodzowl307
Are you a First Alert Home Security Expert? Answer questions, earn points and help others
