Question about HP DesignJet 9000 InkJet Printer
We own and HP Designjet 9000 wide format printer. About 9 months ago we had an issue with the magenta cartridges not reading in the machine. We got and sent back 3 different cartridges before they started to work. This problem just started again yesterday, and I am wondering if there's a defect issue in general with these cartridges or is it our printer? Anybody hear anything? Our supplier is kind of clueless.
BARRET
  • 21 Answers
SOURCE: HP L7780 always reports empty magenta cartridge
Hi, The issue can be resolved by just shaking the ink cartridge slightly by holding the nob closed so that the ink mixes and then insert the cartridge back in the printer this should fix the issue... You can also power cycle the unit by unplugging the power chord and replugging it back by keeping the printer turn on and make sure that the all the cartridges are out while powercycling the unit, This will fix the issue check ..
Posted on Sep 27, 2007
  • 24 Answers
SOURCE: HP DesignJet 450c printer issues.
Kavalbe,
You can find drivers for your DesighJet printer here:
Then, a JetDirect 170X or 300X will fit the bill for connecting the printer to the network.
Also, you preferably should use an HP Standard TCP/IP port for connecting the driver to the network, since the MS version in some cass have issues (prints can be reprinted when crossing over to a new date, prints can disappear...)
A stable version of HP's Standard Port Monitor can be found here: (Note, this is a direct ftp link to HP's ftp server, so you should get a file for downloading when you click the link.)
Else, you can use either the software that comes with the JetDirect box or download its software from hp.com. But the HP Standard Port Monitor software is easier to use if you already have the printer driver.
//Al
Posted on Mar 08, 2009
  • 159 Answers
SOURCE: HP will not recognise new cartridge
The problem you are describing with the yellow cartridge sounds like ink starvation possibly due to a clogged print head or an air bubble in the print head. Since the machine is so new I would contact HP to get the print head replaced. As for the magenta cartridge, exchanging it for a new one at the store you bought it from should fix the problem. It sounds like the chip on the one you have is either damaged or wasn't set to read full ink levels.
Posted on Mar 23, 2010
  • 241 Answers
SOURCE: i replaced all 3 color cartridge with origanal hp
This is a common problem with this model of printer. The scanner optic degenration is due to dust buildup on mirrors and lenses. Since the most vulnerable mirror reflects its laser beam to the magenta toner cartridge, red tones are the first to show fading. Colours shift: purples turn blue and oranges turn yellow. The printer optics will need to be cleaned by a technician to resolve this issue as it means dismantling your printer deep into the optics to fix the problem.
Posted on Jun 09, 2010
Daniel S
  • 4323 Answers
SOURCE: Try to print but: get General Printer error 0x61000f6
Hi
This error comes due to carriage jam. Turn off the printer and unplug it from wall socket. Now, remove the cartridges and check for any dried up ink residue on cartridges on inside the carriage. Clean the cartridges contacts and carriage using a Q-tip dipped i alcohol. Let the carriage and cartridges dry before you plug in the printer.
Install the cartridges and check. If it still shows error then unplug the power cord coming to the printer without switching it off. Now, remove the rear door of the printer and check for any paper jams over there, remove if any. Wit for at least 15 seconds and plug in the power cord. Now check whether it is working.
Daniel Scott
Posted on Jun 22, 2010
Testimonial: "Thank you very much for the information. very helpful. I am sure this information will help other people as well. Thanks again. "
Hp 9000 s can I flash only one color?
it seems that the machine has a diagnostic feature.
i guess you can try, just install only the required cartridges to the desired color to be flashed (purged). if machine refuses, there's your answer.
Oct 13, 2015 | HP DesignJet 9000s - large-format printer...
HP Designjet 800 - Magenta cartridge
Check the expiration date in the ink menu of the printer
Mar 13, 2013 | HP DesignJet Office Equipment & Supplies
HP Designjet 110 inconsistent printing of magenta
>Check ISS pumping, >Check ISS tubes is there air gap?>Check cartridge bag broken in side?>Check for leakage at cartridge bank & carriage assm.>Do the following force priming to fil ink in tubes as well as in print heads:****Hold the power button down and press the cancel button three times and the resume button three times.****Switch Off the printer and then On again in order to start the priming of the ink supply tubes.
Jan 04, 2012 | HP DesignJet 110 Plus NR InkJet Printer
We have HP Designjet 110plus. Our magenta is flashing saying that it is out of ink, however it wasn't. We replaced it with a new cartridge, and it still reads empty. Please help!
Turn off the printer, disconnect and remove everything like power cable, usb cable, cartridges etc.. Connect your power chord and power on, leave it for few minutes (clean the cartridge interfaces not the head, and the corresponding interfaces on the printer). Again shut down the printer using the power button. Reconnect/reinsert everything, and again power on the printer before you connect the Usb to the computer. Now check if it helps or not. This will clear any static memory/voltage. Good luck Thanks for using FixYa.
Jun 01, 2010 | HP Designjet 110plus nr InkJet Printer
May 29, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP 9000s Cartrige Problem
The Black cartridge chip is affected by its neighbors: Lc and Lm. Sometimes there's a problem with Lc or Lm chips and the printer says Check Black ink. You can keep changing the Black but the Black was OK. What can be done:
- clean golden contacts on all 3 cartridges (Lc, Lm, K) with alcohol
- if you can, reach with a long swab inside the cartridge slot on the printer and clean the gold pins there
- re-insert cartridges with printer OFF, and turn it on
- if still no help, you can buy spare chips online here: www.hp9000cartridges.com
Mar 23, 2009 | HP DesignJet 9000 InkJet Printer
HP 2840 says install magenta when it is installed
All of the cartridges are self-contained so i'm sure it's a bad cartridge.
This machine is a pain, as you probably know.
Jan 06, 2009 | HP LaserJet 2840 Printer
HP DesignJet 9000 InkJet Printer Logo
73 people viewed this question
Seeker5211
Seeker5211
