Question about Nu Mark Numark Cdx Table Top CD Player CD Player
Numark cdx power problems
My cdx will not power up at all, the light around the power button is dim and if i hit the play button the platter just bounces around. on display lights or any thing please help
  • bondyara Sep 17, 2008
    i have the same problem!
  • 68 Answers
Possible servo problems..
http://www.audiovisualservices.info/
Posted on Dec 13, 2008
The platter on my CDX is a bit lifted and wobbly. How can i fix that?
That is normal vinyl itself was never really straight and as for the platter it should have some give to it now if it looks like a bent rim on a bike then i would send it back but a little play is fine.
Apr 19, 2011 | Numark CDX Turntable
Numark x2 motor problem
I would like to know if it possible to use my Numark DXM09 mixer ... with two Numark ICDX players and use Numark Cue software
Oct 14, 2009 | Numark x2 Hybrid Turntable
Numark TTX-1 turntable starts slow but then is okay.
A drop or two of light oil at the center of the spindle will surely solve the problem.Remove the platter and check if its clean
Jul 06, 2009 | Numark TTX Turntable
Numark tt1625 turntable wavey sound
Your belt is probably worn and needs replacing. Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
May 28, 2009 | Numark BATTLE PAK v.4 Turntable
Numark ttx wont spin
some tables require the tonearm to be over the record area before the patter starts to spin. If thats not it, have you tried "jump starting" the platter with your finger? the direct drive "stepper" motor might be confused as to where it is at the moment. and finally remove power from the wall for a few minutes then retry.
Feb 09, 2009 | Numark TTX Turntable
My Numark Cdx and Numark Cdn90 are frozen
Hi Mitchdias,
Have you tried downloading the most recent rom update for the CDN-90? All you need to do is download it from here http://www.numark.com/contentmgr/showdetails.php/id/1493/tt/5 , then burn the download to disc. Once that's done, put the disc into the player, switch the player off and wait 10 seconds, then switch it back on again. the player will read the disc and flash the ROM. this should reset the player for you. Before you ask, you can out the disc into either side of the player. Full instructions are given with the download.
Jan 05, 2009 | Nu Mark Numark Cdx Table Top CD Player CD...
Scratch works only on pause
The problem is with the tiny button that tells the CDX that the platter is engaged. Take the face of the unit off by unscrewing the screws of on the circumference of the bottom of the unit, then locate the copper T shaped piece touching the spindle of the platter. Unscrew the little circuit board (this houses the on/off soft switch for the scratch mechanism) covering the bottom of the T and the T itself. Try powering the unit up and play a CD with the scratch mode activated. Push the grey soft switch to see if the music stops and move the platter back in forth to see if it scratches. If so, all you have to do is bend the copper T trigger to a position where it hits the soft switch just right; off when you don't have the platter pushed down, and on when you do. If the scratching doesn't work when you push the grey switch down, you have a problem I don't know how to fix. Hope this helps!
Sep 01, 2008 | Vestax CDX-05 Turntable
Numark cdx
have you checked the brake and start up settings they are the dials by the start and stop buttons it it is turned too far the platter will start up slow, you just trun to dial till you get the right start up speed you want
Jul 25, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
Numark CDX CD Turntable
HERE YA GO!! GOOD OLD FASHIONED BEATING FIXED MINE... I PROMISE THIS. When you turn on your CDX... HIT THE SQUARE AREA where the play button and the cue buttons are located. It will jump to CDX on the screen and work fine. Mine did this and i messed around with bumping it and stuff and figured this out
Apr 25, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
Platter spins very slowly
Well hope fully its something small. check your pitch control first make sure its not set at a slow speed. then check your start stop knobs at the bottom of the table. roll them one way then start it see if that works, then the other way... if its not that then its possibly its a malfunction ,, Numark with there new awesome products but sometimes faulty that turntable wigs out goin slow then normal then slow ect... If its less then a year send it in it is coverd by warrantee
Oct 07, 2007 | Numark CDX Turntable
Nu Mark Numark Cdx Table Top CD Player CD Player Logo
310 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Greg Cann
Greg Cann
robert landry
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
