Remote garage roller door will not go up or down.Remotes have new batteries.Garage was opened and closed on the same day;there was no interference by any internal objects.Checked fuse box in the house and the fuse had not tripped?Remote controls are simple 'up or down or stop'
  • 902 Answers
You may need to resync the remote. if there isnt a sync button on the remote and the box. tell me the model i will inform you on how to do it
Posted on Mar 17, 2011
Garage door opener remotes work OK on OPEN but have short range on CLOSE.
try adding on the antennaes, ive had success with this in the past
Nov 15, 2014 | Building Materials
Craftsman overhead garage door opens at random?
There is some interference created by other wireless devices within range of your garage door. This maybe a door bell, baby motor or car immobilizer. Check to see if there are any new wireless devices, it maybe someone Cole by like a neighbor. Alternatively, you can delete the existing remotes from the unit and reprogram the remotes again, this will reprogram the emotes on a different frequency and hopefully cut out any interference. Need new garage roller doors for your Perth home Think Modern Garage...
Feb 16, 2014 | managemylife.com
Digidoor remote
"Another reason is problems with the radio frequency of the remote control system used, some older systems use frequencies that are liable to interference from various sources such as police and fire department radios and military communications. The effects of this interference are many for example, the garage door may open and close on its own or the operating range of your remote control may become so poor you cannot open or close the door with your remote control even whilst standing next to it."
source
Jul 29, 2013 | Audio Players & Recorders
Garage door send receive signal
Caution: do not use LED bulbs with garage door openers. They are a possible source of signal interference between the transmitter and receiver on the opener.
Mar 22, 2013 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman 1/2 HP garage door opener. For it to open or close,I need to be next to the door or under the unit.Remotes have new batterys
Limited range of your remote controls could be related to radio frequency interference that comes from something in your home or in the surrounding environment. Certain electrical devices can radiate interference; this could be almost anything that is plugged into an electrical outlet.
Please keep in mind that the device can be brand new, or can be an item that has been in use for quite a while. Also, the item may continue to function properly as far as you are able to tell. The only problem with the item may be that it has started to broadcast the interference, with no other symptoms noted.
Some devices are more likely to generate interference than others. This includes TV cable, cable amplifiers, surge protectors, fluorescent lights, battery charging devices (power tools, golf carts, etc.), anything that utilizes a timer (sprinkler systems, lights, alarm systems, etc.), and a myriad of others. If the problem seems sporadic, we can safely assume that the device responsible for the interference is only being operated during these times. Again, please keep in mind that the age of the device does not determine if it is capable of broadcasting unwanted interference. Any electrical device can be the source of the problem.
The first step is replacing the battery in your remote. If the range on your remote does not improve, remove the wall control wires from the overhead unit. If the range does not improve you will likely need to replace the remote control. After replacing the remote, or if you have other remotes programmed in to the opener, and the range problem still exists, please proceed to the Power Down test.
Multiple garage doors:
If you have two garage door units and one is working just fine, you will need to start by unplugging the good unit. This will help determine if the unit with no range starts to function properly. If the range comes back to the bad unit then you will need to replace the logic board on the unit that was unplugged as it is emitting an RF signal that is over powering the other garage door opener. If the range does not improve after the “good” unit has been unplugged, replace the batteries and try programming some additional remotes to determine if the existing remotes are the issue. If the extra remotes do not have any range then you would need to replace the receiver logic board in the “bad” unit.
Power Down test:
To isolate potential sources of interference, turn the circuit breaker off to the garage and plug the garage door opener into an extension cord from another room. If the range improves, then the interference is coming from a device in the garage. If no improvement is seen follow the same procedure, this time turning off the circuit breakers to your home, with the exception of the garage and test the remote controls. If improvement is noted, turn the circuit breakers back on, one by one, until the range problem resurfaces. This will allow you to narrow down what room the problem device is in. You will have to go from there to isolate it further, by unplugging and re-plugging the items in that room.
If you are unable to determine any source of interference, then the receiver logic board in the overhead unit will need to be replaced.
Jun 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a liftmaster formula 1 garage door opener. It has become very difficult to open w/ both remotes unless you are right next to the door. I've replaced batteries in both remotes it didnt help. Is there...
Here are some things to check.
Power Down test:
May 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftman 1/2 garage door. Model 13953879. RF intereference issue
Power Down test:
Apr 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
I've Craftsman garage door opener, model 1/2 HP belt drive 315. It has been hard to open the door by remotes and key pad in front of garage door. I have to come close to the opener within 10' to open it by...
Limited range of your remote controlscould be related to radio frequency interference that comes fromsomething in your home or in the surrounding environment. Certainelectrical devices can radiate interference; this could be almostanything that is plugged into an electrical outlet.
Please keep in mind that the device canbe brand new, or can be an item that has been in use for quite awhile. Also, the item may continue to function properly as far asyou are able to tell. The only problem with the item may be that ithas started to broadcast the interference, with no other symptomsnoted.
Some devices are more likely togenerate interference than others. This includes TV cable, cableamplifiers, surge protectors, fluorescent lights, battery chargingdevices (power tools, golf carts, etc.), anything that utilizes atimer (sprinkler systems, lights, alarm systems, etc.), and a myriadof others. If the problem seems sporadic, we can safely assume thatthe device responsible for the interference is only being operatedduring these times. Again, please keep in mind that the age of thedevice does not determine if it is capable of broadcasting unwantedinterference. Any electrical device can be the source of the problem.
The first step is replacing the batteryin your remote. If the range on your remote does not improve, removethe wall control wires from the overhead unit. If the range does notimprove you will likely need to replace the remote control. Afterreplacing the remote, or if you have other remotes programmed in tothe opener, and the range problem still exists, please proceed to thePower Down test.
If you have two garage door units andone is working just fine, you will need to start by unplugging thegood unit. This will help determine if the unit with no range startsto function properly. If the range comes back to the bad unit thenyou will need to replace the logic board on the unit that wasunplugged as it is emitting an RF signal that is over powering theother garage door opener. If the range doesn not improve after the“good” unit has been unplugged, replace the batteries and tryprogramming some additional remotes to determine if the existingremotes are the issue. If the extra remotes do not have any rangethen you would need to replace the receiver logic board in the “bad”unit.
Power Down test:
To isolate potential sources ofinterference, turn the circuit breaker off to the garage and plug thegarage door opener into an extension cord from another room. If therange improves, then the interference is coming from a device in thegarage. If no improvement is seen follow the same procedure, thistime turning off the circuit breakers to your home, with theexception of the garage and test the remote controls. If improvementis noted, turn the circuit breakers back on, one by one, until therange problem resurfaces. This will allow you to narrow down whatroom the problem device is in. You will have to go from there toisolate it further, by unplugging and re-plugging the items in thatroom.
If you are unable to determine anysource of interference, then the receiver logic board in the overheadunit will need to be replaced.
Jan 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Model 139.53930DM Remotes very eratic, will not
I am going to assume you have short range with your remotes and give you some stuff to check.
LIMITED RANGE
If you have two garage door units and one is working just fine, you will need to start by unplugging the good unit. This will help determine if the unit with no range starts to function properly. If the range comes back to the bad unit then you will need to replace the logic board on the unit that was unplugged as it is emitting an RF signal that is over powering the other garage door opener. If the range doesn not improve after the “good” unit has been unplugged, replace the batteries and try programming some additional remotes to determine if the existing remotes are the issue. If the extra remotes do not have any range then you would need to replace the receiver logic board in the “bad” unit.
Power Down test:
Nov 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote Control closes garage door but does not open
It sounds like a case of your keypad losing signal strength enough that it cannot transmit through the closed door. If a new battery doesn't do the job a new keypad will.
Sep 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
