Model Mex731ca53. I have a current problem with the water not draining out of the barrel. we tried re-running and still fills. was told that this was likely to be a pump issue. Wondering if you know where to get the user manuel for this model as I am having trouble finding it
Krazytech
  • 725 Answers
SOURCE: I have a whirlpool front load washing machine model WFW8300SW00
Hay Crab.
what I have found is that the washer thinks it is not pumping out .. if your drain pump is clearly removing the all the water in a good time... then the problem is your pressure switch...it is telling the computer that it still has water in the machine...
replace the pressure switch and it will solve your f21 error.
It is a round unit on the right hand side on top...with a tube and wires going to it...let me know if it helps
Posted on Apr 05, 2008
Krazytech
  • 725 Answers
SOURCE: Bosch SHX46A02UC-21
float switch is in the flood position and the drain pump is running.. there is water under the dishwasher or that switch is stuck up..
Posted on Aug 21, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore front load washer won't drain
Remove the bottom panel under the door to access the drain pump. Make sure the washer is unplugged before servicing the pump. The pump will be located under the wash tub in the front of the washer. There should be a small access cover that can be unscrewed to access the inside of the pump. If not, remove the inlet hose to access the pump impeller. HINT: Pull the drain hose from the standpipe and use a shop vac to pull a vacuum on the drain line. This will pull any remaining water out of the drain lines and wash tub. This will minimize the amount of water that spills out of the drain pump when you remove the access cover.
It does not take much to damage this small drain pumps. If you clean the pump thoroughly and it still exhibits drain problems, the manufacturer recommends replacing the pump.
If you require additional assistance, let me know before you rate the solution. I hope this helps you.
Posted on Feb 02, 2009
  • 99 Answers
SOURCE: WHirlpool Waser model LSR8133HQ0 - tries to fill for rinse cycle
hellow my name is joyce and It sounds like you have a issue with your cut off valve that controls the water flow to your machine in between cycles, this is controled by your timer switch you may want to call technichian to repair. sounds like the only problem you have with the timer is on the rinse cycle not the wash cycle, but it defently needs to be fixed. if I can help you find a repair person please let me know.
thanks you and let me know if I can further assist you.
joyce
Posted on Feb 06, 2009
SOURCE: Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Posted on May 29, 2010
Why won't my LG washing machine pump out water?
If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump
Sep 10, 2014 | LG WM2688HWM TROMM SteamWasher
SUDsamsung washer error codes
• dc--Unbalanced load preventing washer from spinning
• dL--Door is in locked when washer is running
• dS(d5)--Door is open when washer is open
• FL--Washer failed to lock the door
• Hr--Water temperature control problem(Heat control problem)
• LE--Washer tried to fill but has not reached proper water level(Slow fill)
• LO--Door will not unlock
• E3--Motor not running properly
• nd--Washer is not draining/Washer senses a brief restriction while draining
• nF--Washer tried to fill but was unsuccessful
• Sr(5r)--Problem with control
• PF--Power failure, electric service was lost while washer running
• OE--Fault detected in water level sensor
• E2--Jammed key
• bE--Motor speed sensor problem
• tE--Temperature sensor problem
• 3E--High current detected
• 2E--High/low voltage detected
• 8E--Vibration sensor problem
• 7E--Silver Care control problem
• SUdS--Too much suds detected during wash cycle, unit on hold until suds reduced
Nov 12, 2013 | Washing Machines
WE HAVE A FLOATING DOCK WITH BARRELS UNDER IT AND ONE BARREL HAS A HOLE IN IT AND NOW THE DOCK IS SINKING ON ONE CORNER. HOW CAN WE FIX IT WITHOUT TAKING THE DOCK OUT OF THE WATER.
I would get another barrel and fill it with water, that will allow it to sink, and be more maneuverable under water. Then you can switch it for the barrel with the hole in it, and then drain the water from the good one with a hose. Good luck fixing your dock!
Jason.
http://www.falveycorpmccall.com/marine.htm
Apr 11, 2013 | Cars & Trucks
Kenmore 111 stuck mid cycle with water in barrel
Try unplugging it for a hour - see if it clears..
Hope this helps !!
Jul 13, 2009 | Washing Machines
Top load barrell will not spin on rinsr nor spin cycle
if it is syphoning......pull the drain house out of the stand pipe it is in tooooooo far. once it is too far down it does not have an air gap anymore which causes it to fill and drain and never reach maximum water level. the hose should only be in the stand pipe 6 inches. when you pull the hose out of the wall and you hear it go glub glub glub and water exits the hose that is a major sign of syphoning. And yes it can be intermitten. Let me know how it goes and if you have any other questions.
Jun 02, 2009 | Whirlpool Washing Machines
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Wont fill up with water it drains out before its full
If you hear the motor running when it is draining then you have a bad timer. If it just drains out and the motor is not running then you have a siphon problem which is caused if the drain hose is too low. Let me know what you find.
Dec 03, 2008 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
