Question about ASUS (wl500g) Wireless Router
How to secure the wire less router - ASUS (wl500g) Wireless Router
    Scholar:
  • 169 Answers
To secure wireless router, simply follow the steps provided below:
- Accessing Your Wireless Router's Configuration.
To gain access to your wireless router settings and configuration menu then connect to the router either wirelessly or via a Ethernet cable. Open a web browser and type either:
http://192.168.1.1 or
http://192.168.2.1
- Change the Admin password.
Most wireless routers ship with a blank password. It is essential that this is changed else a potential hacker could get into your router configuration and lock you out of your own hardware.
- Change The Network Name (otherwise known as the SSID).
The default network name is usually made up of the name/model of your wireless router. This information gives a head start for a hacker and makes it easier for them to break into your network. Don't rename it to something like your surname or house name as this unnecessarily exposes personal information. Rename it to an alpha-numeric string - this can be up to 32 characters long.
- Turn off SSID broadcasting.
By default, a wireless router's SSID is broadcast so anyone in the vicinity of your wireless router can see that it. SSID broadcasting can be turned off thus making your wireless router virtually invisible.
- Enabling Encryption.
This is switched off by default. There is a choice of WEP, WPA and WPA2. Currently the latest encryption method is WPA2 so use this where possible. Both your wireless router and wireless PC adaptor must be configured to use the same encryption.
- Mac Address Control.
All hardware has a unique MAC address associated with it, including your PC adaptor card. This MAC address can be added to access control list in the wireless router. Only devices added to the router's access control list are allowed to be connected.
- Update router firmware.
It is recommended that the latest router firmware is downloaded from the manufacturer's website and installed in the router. This will hopefully fix any bugs that have been found for your router and also help with any known security flaws in the router itself.
- Backup settings.
Finally, backup all router settings. If you reset the router back to its factory default settings for whatever reason, your configuration can later be easily and quickly restored back into the router.
Posted on Mar 17, 2011
  • 314 Answers
Hi sriram8,
Visit this site and it will give you FULL instructions on how to secure your router.
http://www.ehow.com/how_2253625_secure-wireless-router.html
i hope this helps, good luck!
I have not open wi fi wire less net work . But wire less net work LED is open
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Jun 13, 2011 | ASUS Eee PC 1000HA Notebook
Wii internet
If you have a wireless router and there is no security, you just go to wii settings, then internet, and search for a access point. If you do have security it will ask you for the security id of your router, if you don't know it contact whoever setup your wireless router.
May 10, 2010 | Nintendo Wii Console
DI-524 wired/wireless access point
Just for fun, make the router give out IP addresses starting at 192.168.0.101 forward. Configure the AP at 192.168.0.2 with no DHCP (the host will give out the addresses), a netmask of 255.255.255.0, and a gateway of 192.168.0.1. Now, let the laptop find DHCP, or give it a 192.168.0.x address where x is greater than 2 but less than 101.
How lucky is that?
Carl
Nov 19, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Does a belkin n1 w/less modem router need to be wired to a pc before i connect my airport only mac
hi,
there is no need to connect the router to pc if u know the w/l settings means the ssid (network name) and security password or key if any. U can connect the pc to router to double check that thru wired u can go online.
thanx and regards
sukhiii
Jul 26, 2009 | Computers & Internet
Wired and wireless computers
First get your router works with the internet on the wired connection before considering the wireless connection simplying the initial problem.
Once the router works wired is time to try the wireless.
Once the wireless works unsecured you may want to change the router and wireless adapter to secure the wireless network.
So this can be a three step process.
If you internet service is provided by a cable(tv) there is a reasonable chance your router will work out of the box no configuration changes. However, if your internet service is supplied on the phone line chances your router will work as it comes out of the box are much less. Who is your Internet Service Provider and if possible can you supply a link to their help/support website so I can see if they supply configuration instructions?
Jan 03, 2008 | Linksys Wireless-G WRT54G Router
Cant get thelaptop to work and very fustrating
u need to first configure teh wire less on the router>go to the main computer>and open browse window and and in teh address bar type- 192.168.0.1 hit enter u can see login screen
user name-- admin lower case or blank
password-- admin lower case or blank or password
and u can see the set up scren and select wire less setup in the left side and follow this
Wireless Settings Wireless Network Name (SSID): Region: --- Select Region --- Africa Asia Australia Canada Europe France Israel Japan Mexico South America United States Channel: 11 Wireless Access Point Enable Wireless Access Point Allow Broadcast of Name (SSID) Wireless Card Access List Security Encryption (WEP) Authentication Type: Automatic Open System Shared Key Encryption Strength: Disable 64bit 128bit Security Encryption (WEP) Key Passphrase: Key 1: Key 2: Key 3: Key 4:
Nov 18, 2007 | NetGear WGR614 Wireless Router
Belkin n router.
change the wire less channels use 1 or 11>and always keep teh wire less pc close to teh router>and disable the fire wall in the router rate me solved if its helps thx
Nov 15, 2007 | Belkin (F5D7231-4) Wireless Router
Password
i think its wep or wpa password which u created in teh w/l router>connect a pc through hard wired on teh routers ether net port>and open a explorer>and in address bar type-(192.168.1.1)>enter>
user name--- admin- all lower case
password---- admin- all lower case
click on wireless-and click on wire less security>and change teh wep or wpa password and click on save settings>and reboot the router as well as laptop and use teh new password which u changed>rate me solved if its works
Nov 06, 2007 | Linksys Wireless-G WRT54G Router...
Lost my web key
k connect a pc through hard wired on the router and login to teh router and go to wire less set up -->go to w/l security-->and disable the security pin>or change the pin >and save it>an dreboot the router and laptop>and check>and rate me solved if its help full thx
Nov 04, 2007 | MSI Wireless-G RG54G3 Router
Password protection
s u can login to ur belkin router like connect a pc through hard wired >and login to router screen>and go to wire less settings>and u can see security under w/l> go to there>and select WEP and under phaseprace type any 10 digit no as password which u can easyly remember one>and save it>and reboot the laptop>and login to ur w/l n/w and it will ask for password>rate me if its help full thx...
Oct 24, 2007 | Belkin (F5D7231-4) Wireless Router
ASUS (wl500g) Wireless Router Logo
177 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
