Question about Refrigerators
Dometic fridge amonia smell.
I have a1990 refrigerator that has been working just fine and now it was sitting parked but running and I opened it to confirm operation before a camping trip and it had a very strong amonia smell that was burning my eyes when I opened the fridge door. The temp inside is 75 deg. I can hear and see the flame from the gas and I can hear the clicking when on AC. What is wrong, can it be fixed or is it time to replace it and if so, what brand and model is the best and hpefully not too expensive?
  • chazylake157 Sep 04, 2008
    Interesting, I had the same thing happen to a camper fridge that is about 1993. Guess it 's time to just get a new one if it cost that much to fix.
    thanks.
It is simply a bad cooling unit and that particular piece needs replacing.
I can chose to repair it for around $460 or replace it for about $960.
Posted on Aug 02, 2008
CAN MY DOMETIC RV FRIDGE BE FIXED
try unplugging it and allowing it to sit for 24 hours or so to allow the refrigerant and compressor oil to settles. then retry. If the filter got plugged you will need a refrigeration tech to repair it.
Sep 04, 2014 | Dometic RM2652 Refrigerator
Strong amonia smell at back
The smell is Freon, I would replace the unit. The cost to repair is usually 50% or more of the cost of a new one. Once the Freon goes the compressor usually goes with it.
Aug 24, 2014 | Dometic Refrigerators
My Dometic RM2652 fridge suddenly quit cooling. No amonia smell, no yellow residue around cooling unit. Gas ignites, lites work.
what is the yellow residue around heating element? my fridge just isnt working right and sometimes stops all together, the freezer worked until lastnight but fridge hasnt cooled right for a week or so.
Aug 03, 2012 | Dometic RM2652 Refrigerator
I have a dometic rm2510 that worked 2 weeks ago. It smelled like amonia when I opened it to cool it for this weekends trip. it will not cool.
Cooling unit is leaking. Shut it off and have checked by a technician. Probably looking at a new fridge. Sorry.
Aug 19, 2011 | Dometic RM2620 Refrigerator
Had a strong Amonia smell. Fridge wants to turn on but no cooling.
Strong Ammonia smell is dead give away for LEAK. Ammonia is the chief ingredient in the absorption type cooing system. Probably not economical to repair. For a second opinion, contact a Dometic Authorized Service Center.
Thanks for your question @ FixYa.com
May 31, 2011 | Dometic NDR 1292 Refrigerator
Our dometic RM 2350caravan fridge smells like amonia when switched on to ac or dc power. It wont get cold. Help please.andrea
Hi, you have a freon leak in your system, with the caravan refrigerators they use amonia as a cooling media. You need to either have a service person the knows this system or purchase a new one. thanks.
May 18, 2011 | Dometic Refrigerators
My Dometic trailer refridgerator is warm but freezer is freezing.
Brandi4723,
Unfortunately, you have a bad cooling unit in your refrigerator. Then ammonia smell means that you have a leak in the unit. TURN THE FRIDGE OFF!!! Do not use the fridge on AC or Gas until you have the cooling unit replaced or buy a new fridge. Depending on the model number and serial number of the fridge, it may be under recall by dometic and you might be able to have it repaired for free. If you will provide me with the model number, serial number and the serial number of the cooling unit (found on the outside of the unit in the fridge compartment, lower tank of cooling unit), I can then tell you the pricing of the repairs or whether it is under recall.
Again, TURN THE FRIDGE OFF and do not use it...RISK OF FIRE!!!!
Hope this helps,
Jeff
Jul 03, 2009 | Dometic RM2652 Refrigerator
Our rv refridgerator/freezer was turned on for the first time since we bought our rv and when the freezer was opened it had a terrible smell of amonia that about knocked me over. Is that smell free on or...
thats because yoiu have a amonia system thats why they say to keep it level to opoerate properly. the smell may be a leak from where someone punctured the evaporator.
Mar 07, 2009 | Refrigerators
I have a Boler Trailer [Cadet] 1994 ,and the fridge is not getting cold. The pilot light is working well. The model is a Dometic RM183. On the cannister it's marked ARCTEK, serial #560683,made in U.S.A. ...
I had this same problem and here is the possible solution.
The older fridges used amonia and water for a refrigerant. If it sits for a time the two seperate. Remove your fridge and turn it upside down and back again... let it sit for a bit in both positions. Occasionally turn it on.. either with gas or electric if so equipped. The process of heating and mixing the amonia and water will sometimes do the trick. When you notice its starting to get cold let it run a while.
Jul 22, 2008 | Refrigerators
Rv fridge problems
have a dometic rm2852 fridge . does not switch over from 110 volt to gas automaticlly. it will click but not ignite. can you help?
thanks
Jul 09, 2008 | Dometic RM2652 Refrigerator
Refrigerators Logo
246 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
