Question about Sony Ericsson P1i
Connecting P1i with dell 1210 with window vistas business
Drivers are not available on windows update (CDC comms )after connecting with USB cable one of the four required driver is not available
  • Anonymous Apr 08, 2009
    Drivers for "CDC Comms Interface" are not available.
The drivers can be found in "C:\Program Files\Sony Ericsson\Mobile4\Drivers2".
This worked for me.
Found this soluton here: http://www.howardforums.com/showthread.php?p=10606331
Posted on Apr 08, 2009
  • Raajaram Jul 08, 2010
    Excellent! God Bless you!
Hp psc 1210 printer driver is not installed sucessfully in window 7 64 bit
When you connected the product to the computer with a USB cable, the Windows Update installation failed. Solution You can manually install the driver. Make sure you follow the steps in the order given to reset your printer, remove the product, restart your computer, and then manually install the driver. Step one: Turn the printer off and then on
  1. Disconnect the USB cable from the printer.
  2. Turn the printer off and then back on. Clear any blinking lights or error messages.
Step two: Remove the product from Devices and Printers
  1. Click the Windows icon (c01319360.gif ), and then click Devices and Printers .
  2. Right-click the product icon (c01813941.gif ) representing your HP product, and then click Remove device . Follow the on-screen instructions to complete the process. (If the product is not listed, skip to Step three: Restart your computer.)
  3. If multiple icons exist for the product, remove them all.
  1. Restart your computer. You might want to bookmark this page so that you can quickly return to it.
  2. Make sure your computer has a valid Internet connection by opening a web browser and surfing to an Internet site.
Step four: Manually install the driver
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon (c01319360.gif ), and then click Devices and Printers . The Devices and Printers window opens.
  3. Click Add a printer . The Add Printer window opens.
  4. Click Add a local printer .
  5. Click Use an existing port .
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
  7. Click the Windows Update button and wait for the updates to complete.
  8. In the Install the printer driver window, under Manufacturer click HP , and then search for your driver under Printers . If the driver does not show up under HP, try looking under Hewlett Packard. NOTE: The print drivers are displayed by their series names, which means the last one or two numbers may show as zeroes. For instance, the HP Photosmart 8750 displays as HP Photosmart 8700, and the PSC 1210 displays as the PSC 1200 series.
  9. Once you find the appropriate driver, plug the USB cable back into the printer.
  10. The Installing Device Driver Software window should briefly display in the bottom right corner of the computer screen. Wait for it to disappear.
  11. Click the Cancel button on the Add Printer window.
  12. The newly installed printer now shows in the Devices and Printers window.
Jan 05, 2011 | HP PSC 1210 All-In-One InkJet Printer
Tip
EZ steps to install HP printer in Windows 7 without Installation software
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers, select approriate drive from below list provided and then click Next.
  9. In the message window, click Finished.
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. Click Close to close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  15. Click OK.
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page.
Determine the appropriate compatible driver
Deskjet 3320, 3325, 3420 and 3520 -------------Deskjet 3600 *
Photosmart 7600 series------------------------------ Deskjet 5600
Deskjet 5850 ---------------------------------------------Deskjet 5600
Photosmart 130, 145, 230 and 245 ---------------Photosmart 330 *
Photosmart 7350 and 7550 --------------------------Deskjet 5550
Deskjet 6122 and 6127 --------------------------------Deskjet 990c *
Deskjet 3820 -----------------------------------------------Deskjet 970cse *
Deskjet 656 ------------------------------------------------Deskjet 660c *
Business Inkjet 1100d ---------------------------------Business Inkjet 1000
Business Inkjet 1100dtn ------------------------------Business Inkjet 1000
Deskjet 9300 ----------------------------------------------Deskjet 1220c *
Deskjet 9650, 9670, 9680, 9680gp---------------- Deskjet 9800
* Available only through Windows Update.
(Happy Printing)
Regards
Rizwan
on Jan 29, 2010 | Office Equipment & Supplies
My computer runs windows 7, will the PSC 1210 printer be compatibke
Hello and Welcome to FixYa!
Yes the Printer is compatible with Windows 7 both 32bit and 64bit, you can install the printer on Windows 7 without any eternal driver source, the drivers for this product model are already included in the Operating System, all you have to do is;
  • Turn the product on.
  • Connect the Universal Serial Bus (USB) cable to the printer, and then to the computer.
  • A Your devices are ready to use window might display on the screen.
Note: When you connect the USB cable to the product, and then to the computer, Windows 7 activates Windows Update. Windows Update searches online for the most recent product driver on the Windows Update site. If the online driver is more recent than the driver stored in Windows 7, the computer downloads and installs the updated driver.The Windows Update process takes place automatically. Therefore, you might not notice that the process is in progress.
If you got any Questions/queries, do ask us, we are here to help.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
Aug 06, 2010 | HP PSC 1210 All-In-One InkJet Printer
I bought a new laptop from Dell. My old on is a desktop from Dell. I have a Belkin transfer cable. It is asking for a transfer key number. what is that????????
Please note that your cable will support below givne O/S check at your end.
One destination PC running Windows 7 (32- or 64-bit) and available USB port
One source PC running Windows® XP (32- or 64-bit) or Windows Vista® (32- or 64-bit) and available USB port
For Example two Pcs 1 is Xp and other pcs is Windows 7, then try to connect between both .
Another one more option is there for transfering the data between two systems either laptop or Desktop by a cross cable (LAN CABLE), buy a cross cable from shop and insert into RJ45 Socket (i.e lan socket) the try to transfer the datas.
If this answer is helpful, please rate....
Feb 27, 2010 | Belkin Easy-Transfer Cable for Windows XP...
PSC 1210 ALL IN ONE WILL NOT CONNECT TO MY NEW DELL INSPIRON WITH WINDOWS 7 . IT SAYS THEREIS A COMPATABILITY ISSUE?
drivers are no available on website for win 7. wat you can do you can directly connect ur pritner to computer with usb cable you will se message found new hardware. installing device drivers. after some time it will show you message device is ready to use. then click on start. go to start search adn type pritners. then hit enter. it will open pritners windows.
in that window click on add a pritner on top. then select add a local pritner. then it will says select existing port select usb vertual pritner port and hit next. then under manufacturer select hewlett adn packard and under prtiner select psc 1200 series prtiner and hit next. do not share this pritner follow onscreen instruction to finish add a pritner wizard.
Dec 16, 2009 | HP PSC 1210 All-In-One InkJet Printer
Dell 1450 Wireless Adapter ProblDell wireless
This driver works with 32-bit Vista and Windows 7
http://members.driverguide.com/driver/detail.php?driverid=1556056
Aug 21, 2009 | Dell 1450 (D1450U) Wireless Adapter
Vista doesn't detect hp laserjet 3030 as usb device
6 - Yes. Your product is supported. Drivers for HP printers are included with the Microsoft Windows Vista Operating System. Additional software will be available soon. HP has a driver solution available for your product. HP is committed to providing the best experience for HP products in the Windows Vista operating environment. Currently, a full-solution driver is not available for your product. However, we do have an alternative driver solution that you can conveniently find in Microsoft Windows Vista. This driver will enable your product's basic functions to work and can be used until the full driver solution is available. Full-solutions will be available as early as January 2007. HP expects to complete the certification process for applicable software by July 2007. Solutions will be posted as they become available. Click here to recieve e-mail updates from HP when a solution is available. HP aspires to provide the most up-to-date information on HP drivers and software. Please check back soon for updates.
NOTE: If your printer currently uses either a PCL5, PCL6 or PostScript XP driver you may download the current XP driver from HP to provide printing functionality. Windows Vista printing is very similar to Windows XP and most print drivers supported in XP environment for LaserJet printers may also work in the Windows Vista operating system.
Jan 04, 2009 | HP LaserJet 3030 All-In-One Printer
Dell A920 Inkjet Printer is not communicating with an HP Pavillion dv6700 laptop with Vista Operating System
It could be related to Vista. Check Dells website to see if they have a Vista driver for it.
If you have another USB Cable you can try swapping it.
If you have a spare USB Port, you can try swapping that as well.
Jun 15, 2008 | Dell A920 InkJet Printer
Updated to Windows Vista and now the Dell 922 AIO scanner won't work
For windows Vista; it is imperative to run the Vista patch which can be found on the Dell website (Downloads and drivers).
Make sure that you run the patch, after removing the printer USB cable from the computer. Restart the computer as the patch suggests and then install the Vista specific drivers, which also need to be downloaded from Dell Website.
Again, do not connect the printer unless the installation software asks you to.
For scanner issues, those who are unable to get anything scanned to their computer, and are able to print, it is essentialy a Firewall/Anti-virus issue. You can check that out by trying to scan using an application such as MSPaint (Start> type 'mspaint' > hit enter).
Nov 01, 2007 | Dell 922 All-In-One InkJet Printer
Can't install to Vista HP PSC 1210
Use Paint.
It's not ideal, but I can scan with my HP PSC 1205 running Vista when I use Paint. Just click 'file' then 'from Scanner or Camera'.
Works a treat.
Sep 23, 2007 | HP PSC 1210 All-In-One InkJet Printer
Sony Ericsson P1i Logo
493 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
