Question about George Foreman GGR62 Grill
I WANT TO FIND OUT WHERE I CAN GET A TEMPERATURE KNOB
    Brigadier General:
  • 4,736 Answers
You can order parts directly from the manufacturer by calling 800-738-0245. Be sure to have the Model Number and Serial Number of your grill, handy.
Posted on Mar 17, 2011
Where is the air and heat blend motor on a 2000 dodge dakota?
Hi Sharon, I'm glad to help. Your 2000 year doesn't have a motor for the temp door. It operated by a cable running from the control head to the temp door and you work it manually. If you can't control the temperature from hot to cold, sometimes the cable come off or breaks. Here how you can see the cable to see if its working. Remove the radio and right behind it you will see the cable attached to the door, while watching it move the temp lever from hot to cold and watch it. If it is moving then its most likely out of ajustment. If it is not moving, then you'll need a new cable. Just in case it is moving, I'm attaching the instruction on how to adjust it below. Hope this helps and have an awesome day Sharon!
TEMPERATURE CONTROL CABLE
Any time the heater-A/C control or the temperature control cable are removed and/or replaced, the following procedure must be performed.
  1. The temperature control cable housing and core must be installed at both the heater-A/C control and the heater-A/C housing ends, and the heater-A/C control must be installed in the instrument panel. See Heater-A/C Control and Temperature Control Cable in the Removal and Installation section of this group for the procedures.
  2. Rotate the temperature control knob on the heater-A/C control so that the knob pointer is in the 12 o'clock position.
  3. Pull the temperature control knob straight out from the heater-A/C control base until the perimeter of the knob (not the knob pointer) protrudes about 6 millimeters (0.25 inch) from the face of the control base.
  4. Rotate the temperature control knob to the 1 o'clock position. Push in on the knob slightly and continue rotating the knob to its full clockwise stop. The knob pointer should be aimed at a position about 8 millimeters (0.315 inch) beyond the end of the graduated red strobe temperature control graphic on the face of the heater-A/C control base. If the knob is not pointed to the correct position, go back to Step 2 and repeat the adjustment procedure.
  5. Rotate the temperature control knob counterclockwise until the knob pointer is in the 12 o'clock position again.
  6. Push the temperature control knob straight in towards the heater-A/C control base until the perimeter of the knob (not the knob pointer) is flush with the face of the heater-A/C control base.
  7. Rotate the knob to its full clockwise stop again. The knob pointer should be aimed at the end of the graduated red strobe temperature control graphic on the face of the heater-A/C control base. If OK, go to Step 8. If not OK, go back to Step 2.
  8. Rotate the knob to its full counterclockwise stop and release the knob. If the knob springs back from the counterclockwise stop, the self-adjuster clip that secures the temperature control cable to the blend-air door lever is improperly installed. See Temperature Control Cable in the Removal and Installation section of this group for the procedures. If the knob does not spring back, the temperature control cable adjustment is complete.
May 14, 2014 | Dodge Dakota Cars & Trucks
Heater controll switch
Hello, I want to tell you about some of the knobs for the temperature control switch, if that is the switch you are referring to.
The way some of the knobs are made, they have a 1/2 moon shape with a metal clip inside them on the backside of the knob. The 1/2 moon shape is also present on the control shaft the knob fits onto. When the knob breaks and splits, the knob rotates around the temperature control shaft without moving anything. From the driver's view, the knob is normal.
You would need to pry off the knob and inspect it, then rotate the temperature control shaft with your fingers or lightly grab it with pliers.
Jan 30, 2014 | 2004 Ford E-350 Super
Temperature
Hello R, thank you for your question! Generally speaking it is recommended that the temperature knob is set in the middle for both the refrigerator and freezer compartment for top mount refrigerators. The temperature can be adjusted by moving the knob in small increments, allowing the temperature to stabilize. If you desire a colder temperature, then turn the knob towards COLDER, or for warmer temperature, turn the knob towards COLD. Turning the refrigerator control will change temperatures in both compartments. For example, if the refrigerator control is turned to a colder setting, the freezer control may have to be adjusted to a warmer setting. Turning the freezer control will only change the freezer temperature. Hope this proves to be helpful!
Jul 22, 2013 | Refrigerators
Problem with washing maschine temperature control knob
It depends on whether the knob is slipping or that the contacts are working within. Please check and see if the controls can be moved further and the temperature cuts off earlier than 90. If so the control and the thermocouple is working and the external knob needs to be replaced
Jan 20, 2013 | Washing Machines
Temperature control knob not working
HAVE YOU PULLED THE KNOB OFF TO SEE IF IT IS CRACKED?
THEY SOMETIMES DO AND THE KNOB WON'T TURN THE SHAFT
Oct 23, 2012 | Chevrolet Colorado Cars & Trucks
The temperature control does not change when the fan is turned up. if i want to change the temperature from hot to cold, i have to turn down the fan, listen for the switch in the dash and then turn the...
I can tell you about my experience on my 1999 F150. I do not believe it is the blower control switch because mine went out and only affected the fan speed. On my truck, in an incident like yours, I could not get a good response from the temperature switch.
I would turn the control and it would hit a stop on both ends, but the temperature would not change to match the switch. What I found is the stem of the temperature control did not turn because the knob cracked behind the switch. There is a half-moon shaped metal clip inside the plastic temperature knob. The clip can spin when the knob is cracked and nothing moves right.
Because the plastic knob has molded stops under the knob, from the drivers point of view, the knob was turning lock to lock. In reality, the stem was not turning. Try taking the knob off and turning the stem with pliers wrapped in cloth to protect the plastic. Then see if the temperature changes.
Jun 30, 2011 | 1998 Ford F150 Regular Cab
We have a Grohmix shower valve and we are unable to adjust the water temperature. Any assistance would be appreciated.
Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
Oct 20, 2009 | Grohe Grohmix Thermostat Valve & Trim -...
TEMPERATURE CONTROL KNOB WILL NOT WORK ON WARM OR HOT
If you can pull the rotating knob off, use a pair of pliers and rotate the rod and see if it works....or, does the knob seem like it is not grabbing?
Mar 13, 2009 | 2002 Mitsubishi Galant
Stove to hot burns everything
This is a simple fix as long as the oven is heating properly and the only problem is that the temp seems higher than what the temperature control knob indicates...
Purchase an inexpensive oven thermometer from the hardware store and place it in the center of the oven. Set the temperature control knob to 350 degrees F.
Check the temperature indicated on the thermometer in the oven after 20 minutes. If it's not within 5 degrees of 350, you'll need to adjust the oven's temperature control.
Turn the oven off.
Pull off the temperature control knob. You can usually pull it off by hand, pry it off with a thin screwdriver, or slide a piece of cord up behind it and pull.
Note which kind of temperature control knob you have. There are two types: The first has a screw in the shaft of the knob; the second has an adjustment dial on the back of the knob.
Adjust the temperature with the first type by turning the screw in the shaft with a screwdriver. Turn it clockwise to lower the temperature; turn it counterclockwise to raise the temperature. Turn the screw just a little bit in the appropriate direction.
Adjust the temperature with the second type of knob by turning the dial on the back of the knob. (This dial is held in place with a screw or a clip that will need to be removed.) Raise the temperature setting by turning the dial counterclockwise; lower it by turning the dial clockwise. The notches are typically in 5 or 10-degree increments.
Test the oven temperature again.
Repeat until you're in the right temperature range.
Good Luck!
Mar 20, 2008 | Kitchen Ranges
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
George Foreman GGR62 Grill Logo
65 people viewed this question
Top George Foreman Grilling Experts
Jaime Hernandez
Steven Clarke
Steven Clarke
Are you a George Foreman Grilling Expert? Answer questions, earn points and help others
