Question about GE Microwave Ovens
I have a G E Spacemaker 2.0 microwave. model no. JVM2070WH02 Serial # ZH900340B. Recently the touchscreen has started to malfunction. You can press one function and a different function starts up. Example if you press the number 5 on the keypad the number 4 will show up. I can no longer use the time cook function but can use express cook function. Is there anyway to reset the keypad functuins? Any help will be appreciated. Thanks Ted
SOURCE: GE Profile Spacemaker 2.0 Microwave
Clean the inside top of the microwave. There is food stuck to the top and is killing your microwave cook time. I had this same problem and was fixed $125.00 Later. Good luck
Posted on Jan 04, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic Model NN T964SF inverter
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Aug 02, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE SPACEMAKER XL MICROWAVE OVEN JVM1440
Assuming that your internal cooling fan is working, I would suspect that your magnetron is failing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the
left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
I would check the cooling fan, then suspect the magnetron.
Posted on Nov 16, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE spacemaker XL1400, Model number JVM1430WA 001
OOPS!
I meant to post that as a solution, not a clarification request, so it came out as one big blob paragraph (Thanks, FiyXa!)
Here it is again, but in readable form:
You have a failing membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
It is part number WB27X10171 and while GE sells it for a whopping $115.50, you can get it for $90.58 here.
You can also find helpful exploded view diagrams via that link.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs, in this case
$90.58 plus $8.95 shipping for a total of $139.48.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on Jul 25, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: The keypad buttons do not work
> model JVM1640WJ03
The keypad is part number WB27X10721 MEMBRANE KEY PANEL available for $37.09 here (it's $61.50 from GE!).
First of all, you should check the end of the keypad strip for rough white, gray, or green deposits that can sometime interfere with conductivity.
Then disconnect the strip as shown in the photo below and use a soft pencil eraser to gently clean both sides of the end, then reinsert it and try it again.
If that doesn't fix it, and you don't notice any rough white, gray, or green deposits on the circuit board (moisture or mineral deposits) or grease, then your keypad is bad.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
prototech@usa.net
Posted on Jul 26, 2009
Touch pad/ no response Model JVM2070BH02 GE Profile Spacemaker 2.0
:) Luckily, these GE touch screen models can now be affordably repaired.
Full official details on the fix are at http://www.microwavecontrol.com/jvm2070.htm.
Let me know if you have other questions.
William Edward Miller
pupista@gmail.com
August 2016
NOTE: This information applies to ALL of the General Electric touch-screen models below:
CVM2072 SERIES
CVM2072SM1SS
CVM2072SM2SS
CVM2072SM3SS
CVM2072SM4SS
JVM2070 SERIES
JVM2070BH
JVM2070CH
JVM2070SH
JVM2070SK
JVM2070WH
JVM2070BH001
JVM2070BH002
JVM2070BH01
JVM2070BH02
JVM2070CH001
JVM2070CH002
JVM2070CH01
JVM2070CH02
JVM2070SH001
JVM2070SH002
JVM2070SH01
JVM2070SH02
JVM2070SK001
JVM2070SK002
JVM2070SK01
JVM2070SK02
JVM2070WH001
JVM2070WH002
JVM2070WH01
JVM2070WH02
JVM2071BH01
JVM2071BH001
JVM2071CH01
JVM2071CH001
JVM2071SH01
JVM2071SH001
JVM2071WH01
JVM2071WH001
PVM2070 SERIES
PVM2070DMBB
PVM2070DMCC
PVM2070DMWW
PVM2070DM1BB
PVM2070DM1CC
PVM2070DM1WW
PVM2070DM2BB
PVM2070DM2CC
PVM2070DM2WW
PVM2070DM3BB
PVM2070DM3CC
PVM2070DM3WW
PVM2070DM4BB
PVM2070DM4CC
PVM2070DM4WW
PVM2070SM1SS
PVM2070SM2SS
PVM2070SM3SS
PVM2070SM4SS
These models utilize one or more of the following part numbers:
WB07X10731
WB07X10732
WB07X10733
WB07X10972
WB07X10973
WB07X10974
WB07X11113
WB07X11131
WB07X11139
WB07X11143
WB07X11192
WB07X11194
WB07X11195
WB07X11196
WB07X11302
WB07X11303
WB07X11304
WB07X11305
WB07X11306
Sep 17, 2013 | GE Profile Spacemaker Over-the-Range...
Key pad on my GE Profile Spacemaker 2.0, Model JVM2070choo1 does not respond.
1) the control board is faulty. however you can try to clean the keypads for dirty , oxide, or corrosion, Of course you must try to unplugged the power cord and discharge the capacitor see the diagrams.
God bless you
7_15_2012_12_27_54_pm.jpg7_15_2012_12_28_09_pm.gif7_15_2012_12_28_43_pm.gif7_15_2012_12_29_12_pm.gif
Jul 14, 2012 | GE Profile Spacemaker Over-the-Range...
What is the serial # range for GE Spacemaker microwaves vintage 1984-1985
That would be difficult to track down, but you can use a universal door switch "open or closed " selection making it handy, some tv repair shops still may carry some parts, appliance repairman another choice.
Mar 06, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
How do I unlock the touchpad of my Profile 2.0 Spacemaker Microwave Oven # JVM2070
calvin,
If you have access to where your microwave is plugged in, unplug it for a few minutes and then plug it back in. This will reset your contol panel. Then follow your book directions to reset the time on the clock. Hope this helps!
Nov 06, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven just quit. Have checked fuse and plug. Have had no earlier problems. Do these ovens just ''wear out''? It is 8 years old. It is a GE Spacemaker. (November 2002) GE Spacemaker Serial...
yes they wear out. usally the first part to quit is the unit inside that creates the microwaves called the "magnetron" over time they will wear out, and so will the circuitry that runs the entire microwave, some will last 8 years like yours, some only a year or 2. 8 years is pretty good for the life of a microwave. but yea, its time to get yourself a new one. good luck to you
Jan 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave Oven
You can download GE owner's manuals and installation instructions here.
Aug 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Constant rattling noise during operation
possibly the "stirrer" motor - this is in the top and turns a metal reflecting ring to disperse the microwaves around the oven more evenly. About $70 on GE site for my oven.
Jun 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
183 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
