Emachine w3609 will not turn on green light is on the motherboard nothing works i did the power drain and still does not work could the ps be bad or the motherboard or both
  • 2,229 Answers
Yes to both of your questions.
When nothing works, I first unhook everything from the motherboard except for the CPU, video, and memory. Then turn it on. If you get the fan starting up and video, then hook up the hard drive and keyboard and mouse to see if it works. Lastly, hook up the CD--this is the part that fails most often.
Posted on Mar 17, 2011
HP PAVILION ZV5000 WONT BOOT UP HAS POWER ON LIGHTS AND NOTHING PLEASE HELP!
I had this same problem with my Emachines W3609 PC, it had the power on lights and nothing else. Try making sure that the hard drive and everything is connected properly inside. If the hard drive or RAM isn't connected it won't turn on. If that doesn't solve your problem than you might just need to get a new hard drive and re-install which ever Windows OS you want. Should work than.
Oct 08, 2013 | E-Machines eMachines Desktop PC
Nothing on my Emachines computer will turn on.
I would recommend rechecking your connection to the motherboard. All wires from the power supply to board and making sure the front panel switch connection are correct. Also, make sure the power supply is compatible to the motherboare. even though a 20-Pin ps will connect to a 24-Pin board, it still does not work. Good Luck
Franklin
C2Solutions
Aug 02, 2009 | eMachines D3415 PC Desktop
No boot, New PS, Green light on MB lights, No Fans running
Bottom line: Either your power supply or (hopefully not) the mother board has gone bad.
Replace power supply (remove old one), take to local independent computer shop, ask them for new unit. Should be around $50.00. - no more. After reinstall, if still no fans, boot, etc. Replace motherboard or buy a new machine. MB's installed probably will run you around $250.00-ish.
Good luck.
gurutim
Mar 21, 2009 | E-Machines eMachines Desktop PC
Emachine T2890 won't power up. After reading some posts on this issue I went ahead and replaced the power supply, but the unit still won't power up. I am fairly certain that the old ps was fried since...
If you remove all the RAM fro the system and power it on, you should hear "Memory Error Beeps" if not, then it is usually Motherboard or CPU, for around $30.00 you can purchase a PCI POST code reader to try to pin the problem down further.
I am assuming from the post that all PCI cards (dial up modem especially) have been removed. Sounds like a bad MB or CPU, but if the video is integrated,( built on the motherboard, and not a seperate card, the memory is responsible for video also, and it maybe defective.
Feb 19, 2009 | Intel D845GVSR Motherboard
Emachine T2890 won't power up. New power supply.
move its bios jumpur on cofig mod and after some time post it its orignal post .it will ok ok Insha Allah
Emachines w3609
Hey iluvyakatu
Does your emachine has inbuild video card or AGP or PCI card? if one it has AGP or PCI card try to reseat it. If it is inbuild try to use AGP card or PCI card and see what happen. Also try to check whether you have an inbuild video and AGP or PCI both installed, if you have both try to use one of them.
good luck
zinja
Sep 17, 2008 | E-Machines eMachines Desktop PC
Doesn't start. Green LED off. Red light permanently lighted.
First, try replacing the power supply. If this does not work then the motherboard will need to be replaced.
Aug 02, 2008 | Matsonic MS8137C Motherboard
E-machine 5220 power up
Emachines have notoriously cheap power supplies. Often, while the power supply itself doesn't fail, it causes the failure of motherboard components, essentially trashing the computer.
Try the following:
First check and make absolutely certain that the power switch connector is properly connected to the motherboard. (Take standard grounding/safety precautions: wear a properly-grounded grounding strap, for example, when working with any internal components.)
Obtain a known-good power supply of equal or greater capacity to your eMachines PS and switch 'em out.
If either of these fixes your problem, well and good. If not, the problem may be, as is all too common with eMachines power issues, a motherboard issue caused by the power supply.
Jul 16, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
114 people viewed this question
David Payne
David Payne
