Question about Welding Tools
I have a mtc 160 from smiley tools (out of business) that the air/gas selinode doesn't turn on with the arc I have no repair manual or Schematic and can't find one I think I could fix it with a manual. I use to fix TV's thanks
3 Suggested Answers
  • 18 Answers
SOURCE: I'VE GOT HI FREQ BUT NO ARC. SMILEY TOOLS MTC 160.
Its probably the torch. Turn off the hf , with the machine triggered Measure the open circuit voltage from the positive o/p socket to the negative with a multimeter set on d.c . The correct no load output voltage for the machine will be shown on the spec plate as Uo = ........and whatever the voltage is. If you get the correct voltage try another torch or try stick welding.
Posted on Oct 07, 2009
When i turn on the van when i step on gas it boggs down and service engine light turns on and it smells like raw gas
You probably need to replace the oxygen sensor. If it is bad the computer doesn't know the correct air fuel ratio.
murf427
Oct 25, 2012 | 1994 Chevrolet Astro
Im looking for a repair manual for my rmm corporation air comressor/model#DB1552
I believe that they are out of business but if you wish to contact them to see if they can get you a manual here is there contact information:
RMM Corp.
7677 Equitable Dr
Eden Praire, MN 55344
1-800-304-1316
Oct 20, 2012 | Air Tools & Compressors
Can't start and gas is not being pulled thru the filter. How do I test to make sure my fuel pump is working?
Pull the spark plug wire to make sure the engine doesn't start. First check the line from the gas tank to the pump. Disconnect the fuel line from the gas tank at the fuel pump. Take off your gas tank fill cap and using light air pressure, blow into the line to see if you get bubbles in the gas tank. Canned air for cleaning computers or compressed air at a very low setting work well for this. Do not use high pressure so you don't burst the line or blow it off a connection that's not easy to get at. If no bubbles come up in the tank, check the line and pickup area of the tank. If the line is clear, reconnect everything. Disconnect the fuel line at the carburator. Holding the end of the fuel line in a small jar, turn the motor over. If the pump is OK it should shoot gas into the jar. If not the pump should be replaced. If it does check your float and needle valve in the carburator bowl.
Mar 11, 2012 | Briggs & Stratton Briggs Stratton Intek V...
DP461000AJ
The only way you can have air blowing out of the breather is if the valve plate is installed backwards or incorrectly, possible because they are symetrical. If it's in wrong on one cylinder it will also let any pressure built up by the other cylinder(s) bleed off. Try turning the valve plate around 180 degrees on the cylinder blowing out the breather, if that doesn't work check the plate's assembly compared to the valve plate on the working cylinders. You should be able to tell if each cylinder is working properly just by turning the flywheel by hand and putting a finger over the breather hole and/or discharge hole.
Dec 29, 2011 | Campbell Hausfeld Electric Stationary Air...
Where do I go to order repair parts?
Air Compressor Parts & Accs - eBay
www.ebay.ca > Business & Industrial > Light Equipment & ToolseBayAir Compressor Filter Regulator Industrial Quality 0 to 160 PSI. C $41.83; Buy It Now; +C ... Power Ingersoll Rand Impact Wrenches, Ratchets & Tools. C $104.65.
Clarke Air Compressor Parts‎
about.com/Clarke+Air+Compressor+Parts‎rating for about.com
Clarke Air Compressor Parts. Search Now!
Over 85 Million Visitors.
Nov 04, 2011 | Clarke Power Products Inc AC2000 2HP 6...
I have model 91811 chicago electric inverter. worked fine last time I used it,,, now it won't work. fan comes on, as well as power light, but will not arc.
Can you hear it "humming" inside. If not check fuses / wiring connections inside case. Failin gthat sounds like transformer has failed.
Feb 24, 2010 | Inverter 220 Volt Tig Arc Welder
I'VE GOT HI FREQ BUT NO ARC. SMILEY TOOLS MTC 160. PLASMA, STICK AND DC TIG MACHINE. I DON'T HAVE A MANUAL OR ANY INFO. THANKS
Sep 30, 2009 | Welding Tools
I have a 2000 Dodge Intrepid 2.7L DOHC Engine - Climate Control
Might be the same....You may want to do the diagnosis proceedure. Alot of times its the door actuators. Servos in replace of old cable design. Usually it will be a code 46. DOOR BLEND ACTUATOR SHORT TO BATTERY.
The DTC's can be checked with the MTC control and the Odometer Display of the Mechanical Instrument Cluster if a DRBIII® scan tool is not available. The MTC control can only be placed into the diagnostic mode while the engine is running and the vehicle is not moving. To place the system into it's diagnostic mode, adjust the MTC control to the following settings:
  1. The engine must be running with vehicle not moving.
  2. The fan speed set to any speed except OFF.
  3. The temperature control knob in full cold (full counterclockwise position).
  4. The mode control knob must be placed in Defrost position (full clockwise position).
  5. The A/C button can be On or Off.
  6. Press and hold the rear window defogger (EBL) button until the mechanical instrument cluster odometer display indicates an "AC00". The BCM will chime once and the MTC A/C button LED will begin blinking.
  7. Release the EBL button and wait until the MTC A/C button LED stops blinking. This means that the error check and climate control door calibration is complete. NOTE: It is important that no other control knob or button is pushed until all DTC's are read. Pushing any button except the A/C button or turning a control knob will end the diagnostic test without showing the rest of the DTC's. There also may be other DTC's stored in the BCM not related to the climate control system. These DTC's can only be found using the DRBIII® scan tool.
    DTC's related to the MTC control head will appear on the odometer display in numerical form after the letters "AC". The odometer display will return to normal operation if no DTC's are found. If a problem is found, then the odometer will display the letters "A/C" followed by the DTC number. The odometer display can only show one DTC at a time. Under certain circumstances, more than one DTC could be in the memory. To scroll through any additional DTC's, press the A/C button on the MTC control. The BCM will beep each time the A/C button is pushed. Continue pushing the A/C button and recording the DTC's until the odometer returns to normal operation (note the letters AC will dissapear.
Jun 15, 2009 | 2000 Dodge Intrepid
I NEED TO AIR ARC CAN THIS MACHINE DO THIS AND HOW
hook up to the stick position on the machine - to work + to the stinger hook stinger to the air arc hook up air to the air arc turn welder up to top {350}turn air on at the push button on the air arc & get busy
Apr 09, 2009 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
Welding Tools Logo
254 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
