Question about PSC psrf-1300 (psrf-1300 psb-1000 8-0423-03 400)
Printer power not on
Printer not working not on checked the power cord etc
can u connect me to service as i need the printer urgently
  • 734 Answers
Hi,Try the following sites to short out your problem…..
http://uw713doc.sco.com/en/PR_admin/prntT.NoPrint.html
http://files.support.epson.com/htmldocs/pho22_/pho22_rf/trble_5.htm
http://www.smartcomputing.com/editorial/article.asp?article=articles/archive/r1101/04r01/04r01.asp&guid=
Thanks
Posted on Dec 04, 2008
Just printer a couple of documents..Printer lost power and will not print anything,,Unplugge and repluggd into a working plug,,,Nothing,,
Double-check that the power cable is plugged tightly into the back of the printer, as well; also check the power cable for any cuts or fraying. If the cord looks okay, and the printer will not power on at all, it is very likely that the power supply inside the printer has failed. You will need to either return the printer (if you are within 30-90 days, depending on your place of purchase), or contact Canon for warranty service. This is not a part I would attempt to replace yourself, as it involves soldering connections.
Dec 22, 2014 | Canon PIXMA MX712 Wireless Inkjet Office...
Hp laserjet 1020 meltdown
Try this out:
Some printers require time to turn on. These printers may or may not give feedback in the form of blinking light(s). Wait up to a minute for the power light to come on before proceeding with the steps below. Instructions If the printer uses a power adapter (module), follow the instructions below. If the printer uses only a power cord, see the section below entitled “ If the printer uses only a power cord .” If the printer uses a power module Follow the steps below to ensure power is properly supplied to the printer:
  1. Check the power module part number against the part number listed in the User’s Guide to ensure the proper power adapter is being used.
  2. Disconnect the power cord or adapter from the wall outlet.
  3. Disconnect the printer data cable from the printer.
  4. Disconnect the power cord from the printer, wait thirty seconds, then reconnect the power cord to the printer.
  5. Disconnect the power cord from the power module and reconnect the power cord to the power module. This may not be necessary if the power module has a permanently attached power cord.
  6. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead. NOTE: "The HP Photosmart 8100, 8400, and HP Deskjet 6000 series printer power cords feature a green LED built into the power plug. If the LED is not glowing, the power module may have failed. Proceed to step 7 below.
  7. If the printer still will not turn on or the power LED built into the power cord is not glowing, plug the printer into a wall outlet in another room. If the printer or power LED turns on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  8. If there is still no power to the printer, then the power module, cord, or printer may be defective. Try the power module/cord on another HP Deskjet or Photosmart printer, of the same model if possible, to see if the power module is functioning. If the power LED is still not glowing, the power module may be defective. Replace the power module and cord.
  9. If the power module/cord works on the other printer, then this printer is defective. Service your printer.
  10. If you cannot determine whether the problem is the printer or the power module/cord, or if another printer is not available to test with, replace the power module/cord first. If this does not resolve the issue, service your printer.
If the printer uses only power cord Follow the steps below to ensure power is properly supplied to the printer:
  2. Disconnect the power cord from the wall outlet.
  5. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  6. If the printer still will not turn on, plug the printer into a wall outlet in another room. If the printer turn on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  7. If there is still no power to the printer, then the power cord or printer may be defective. Try the power cord on another HP Deskjet or Photosmart printer to see if the power cord is functioning.
  8. If the power cord does not work on the other printer, it is defective. Replace the power cord.
  9. If the power cord works on the other printer, then this printer is defective. Service your printer.
  10. If another printer is not available to test with, carefully inspect the power cord for damage.
  11. Inspect the power cord for visible damage. If the power cord is damaged, replace the power cord first. If this does not resolve the issue, or if the power cord looks fine, then service your printer.
Goodluck,
Dont forget to rate me as fixya..
Jan 30, 2008 | HP LaserJet 1020 Printer
Laptop will not charge. Brought new battery and and it did charge for a while now it will not charge at all. Changed power cords and still nothing. Need all programs for classes. It's urgent that...
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
Aug 21, 2010 | Compaq Computers & Internet
Just replaced the ink cartridges. Printer keeps telling me to turn it off then on. However, it fails every time I turn it on again.
With the power cord connected and the unit on, disconnect your data cable(s) from the printer (USB, parallel). Press the power button to turn off the unit; wait 15 seconds and then turn the power on again.
Check if the error comes back. If it doesn't, reconnect your data cable(s) one at a time, checking for the error message between adding each connection. If you see the error, replace that cable.
If the error did come back after cycling the power when no data cables were connected, you have to look at your power cable. If the cable has a power module (box that you plug another cord into), make sure that you have the correct one for the printer.
In either case, unplug the power cord from the back of the printer (first) and unplug it from any surge protector or power strip (second). If you have a power module, unplug the cord from that and reconnect. Wait 30 seconds. Plug the cord directly into the wall outlet and then into the back of the printer. Then turn on the printer.
Check for issues. If the printer turns on, you may have overloaded the power strip. If it doesn't turn on, you should check the outlet for problems. Try using an outlet in a different room (preferably a different circuit breaker). (Move the printer and its power cord.) If the printer still doesn't work, replace the power cord or module.
If none of the above works, the printer needs service.
I hope this helps.
Aug 02, 2010 | HP Photosmart C6180 All-In-One InkJet...
Hp designjet z6100 error code 21 : 13
Service Station error. Switch the power OFF from the back of the Printer and disconnect the power cord. Check the Primer Tubes. Reconnect the power cord and power On the Printer. Make sure that the Service Station path is clear. Remove any visible obstacles (e.g. screws, plastic parts, etc...) restricting the movement of the Service Station. If the System Error continues, replace the Service Station. If the System Error continues, replace the PrintMech PCA
Jul 27, 2010 | HP DesignJet Z2100 InkJet Photo Printer
Printer says to change the black cartridge BUT the cartridge carrage is way to the left and won't move to the right so I can get at the black cartereridge. Service # B017869
Call kodak > Printer needs to be replaced
IF you need to print urgently
Open the access door > Disconnect the power cord > Then connect is back > As soon as the carriage comes in middle > again disconnect the power cord > You'll be able to change the ink cartridges
Feb 05, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Mu HP Designjet T610 get mistake 21.13
Aug 05, 2009 | HP Designjet T610 InkJet Printer
Help Urgent
Hi Natasha,
If the button settings didn't help, then try resetting the printer.I have mentioned all 3 kinds of resetting, try and let me know.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON button for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait until the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Remove the Ink Cartridges, then unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait until the ON light flashes,or wait for 20 seconds then release the button.If the printer goes off don't worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Thanks n Regards
Rizwan
rizwan84tx@gmail.com
Dec 07, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Need help urgently
Try unplugging the printer from the computer, then turn off the printer with the Power button, next unplug the power cord from the printer for 5 minutes or longer, now plug the power cable back in and turn on printer without connecting to the computer. If the lights have stopped flashing, reconnect to the computer (if using USB) or power off first if using a parallel cable.
Add comment if still having trouble. Hope this helps.
Mar 07, 2008 | HP DeskJet 930c InkJet Printer
Printer takes a long time to start
Hi! Sorry to hear of this issue! There are a few steps you can do to diagnose the issue. If these steps do not work, let me know and I can suggest other steps or which part you may need to order. I can be emailed directly at: bosscomputers@comcast.net or http://bosscomputers.org Follow the steps below to ensure power is properly supplied to the printer: Check the power module part number against the part number listed in the User?s Guide to ensure the proper power adapter is being used. Disconnect the power cord from the wall outlet. Disconnect the printer data cable from the printer. Disconnect the power cord from the printer, wait thirty seconds, then reconnect the power cord to the printer. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead. If the printer still will not turn on, plug the printer into a wall outlet in another room. If the printer turn on when connected to an electrical outlet in another room, there is a problem with the power in the original room. If there is still no power to the printer, then the power cord or printer may be defective. Try the power cord on another HP Deskjet or Photosmart printer to see if the power cord is functioning. If the power cord does not work on the other printer, it is defective. Replace the power cord. If the power cord works on the other printer, then this printer is defective. Service your printer. If another printer is not available to test with, carefully inspect the power cord for damage. Inspect the power cord for visible damage. If the power cord is damaged, replace the power cord first. If this does not resolve the issue, or if the power cord looks fine, then service your printer. Again, if these steps do not work for you and the issue is still present, then the printer will need a specific part - and I can tell you how to order, install, etc, so that you can do the repairs yourself! =) Just email me at bosscomputers@comcast.net Please rate my help for you too, so that I can track your progress as well as helps me get a better rating =) I really appreciate that, as well as hopefully being able to get your issue resolved/fixed!! ~Darrin~
Jun 10, 2007 | HP DeskJet 890c InkJet Printer
PSC psrf-1300 (psrf-1300 psb-1000 8-0423-03 400) Logo
64 people viewed this question
Top PSC Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Jax Planet
Jax Planet
Electric Dime
Electric Dime
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
