Toshiba REGZA 47HL167 TV Logo
A
Anonymous Posted on Mar 17, 2011
NEED TO REPLACE DISPLAY PANEL - Toshiba REGZA 47HL167 TV
Anonymous
Level 2:
  • Expert 902 Answers
  • Posted on Mar 17, 2011
Anonymous
Expert
Level 2:
Answers
902
Questions
0
Helped
179614
Points
142
Toshiba will sell you a new one at about 800 dollars (worked at best buy and tha was the price for a 42 in screen) the best bet is to either take it to a local tv repair shop or buy a new tv at that price. new egg and tigerdirect.com have that model for about 800 dollars alone
Verticall bar on the screen
A vertical bar is frequently a sign that the matrix decoder has failed.
The usual solution is to replace the display panel itself. Dependent upon the model, sometimes this may not be economically viable.
There is also a possibility that the connexion between the display panel and the motherboard may have come loose. Try removing the connexion and replacing it before you replace the display panel.
1helpful
DISPLAY NOT WORKING, BUT OTHERWISE EVERYTHING ELSE IS FINE
You can order the part from appliancefactoryparts.com
You need to replace the entire control board. The display is built into it, but it is easy to replace.
You just need a screw driver to install the display control panel.
To install the part, do the following:
Turn off the unit and unplug it.
You need to remove the screws on the back of the unit and remove the back. It slides up. Then slide the sides toward the back. You need to remove the side without the water canister. The side with the water canister just needs to be slid back enough to reveal the screws at the top front of the unit holding the display. Remove those screws on both sides and gently pull the top front display cover off. There is a long ribbon (similar to one found on a hard drive in acomputericon1.png, which is exactly what this is) with a clip that attaches to the main control panel on the left side of the unit. Remove that (noting how and where it attaches - I mark everything), take apart the inside of the front panel to reveal the display board, remove and replace it along with the water tight seal. Plug the new display into the control board, reattach the top front panel to the body of the machine, reinstall the water container, plug it in and turn it on to see if it works. Mine did and so I reinstalled the sides - they just slide forward, then I reattached the back and the machine was good to go.
Hope these instructions help.
My ge profile refrigerator temperature digital printout reads 999,888,777, etc. Is this a main control panel problem, thermostat or digital control itself?
This is just a bad display control board. You need to replace the actual display control board in order to correct the issue unfortunately. I'm not sure what shorted out both your main control and your display control board, but you will need to replace your display control now. hope this helps :)
How to replace LCD screen
To replace the the LCD screen of your laptop, You need to be very careful in replacing this screen. Please kindly follow the steps below to be able to guide You in replacing the screen.
  1. Shut down the Acer laptop, unplug the AC power adapter and all extensive devices.
  2. Remove the battery pack from the battery tray that is at the bottom of the screen.
  3. Open the display panel as far as You can open it.
  4. Pry the rubber screw covers from the display panel's front cover with a small, flat-head screwdriver.
  5. The front panel is the front plastic piece covering the LCD screen.
  6. Remove the Phillips-head screws fastening the front cover to the display panel.
  7. Remove the front cover from the laptop with your fingers.
  8. Remove the Phillips-head screws from each side of the LCD screen that fasten the screen to its metal frame inside the display panel.
  9. Tilt the screen forward, then disconnect the large ribbon cable from the connector on the back side of the screen.
  10. Peel away any tape securing the cable in place. Lift the screen out of the display panel.
  11. Place the new screen inside the display panel.
  12. Reconnect the LCD ribbon cable to the back of the new screen.
  13. Align the screw holes on each side of the screen with the screw holes on the metal framing inside the display panel.
  14. Replace the LCD screen's retaining screws.
  15. Replace the display panel's front cover, and its retaining Phillips-head screws.
  16. Then replace the rubber screw covers.
  17. Replace the battery pack, then reconnect all cables and devices to the laptop.
That is how to replace the screen of your phone.
Hope this was helpful. Thank You for using FixYa!!
2answers
Display Panel Problem.... my Onkyo TX-SR805 AV receiver works properly except No Display on the front panel. I follow the instruction troubleshooting on the manual by resetting the unit but to no...
I follow the instruction troubleshooting on the manual by resetting the unit but to no avail. It's beyond warranty period.
please help, thank you
2helpful
Pfaff Tiptronic model 2030 LCD display panel went dark, no display. Now lamp burns hot. Told by local service shop that panel needed to be replace to correct lamp issue. Need replacement lcd panel.
very common prob . with pfath . panel failure . display failure . no easy sol . but to repl pc control panel .. / how ever after repair ( and they never tell us .. use a surge power controler on the line . to your machine .. .. **** .. hope this ansewered your Q " mm feed back pls .. mm
Replace/open the Outer Panel of Nokia6300
Firstly you need to open the Panel carefully to clean the Glass Display
Secondly, once you buy the Phone Panel check for the required tools to open that and then you can open and change it..
2helpful
2answers
AC display panel lights
You will need to replace the whole in-dash A/C control unit. Changing the small bulb won't rectify your problem, as the display is LCD.
NEED HELP ON DCS WO-230 DOUBLE OVEN
there are 2 screws at the top outside and 2 or 3 on the bottom of the display panel. remove those and the panel should lift off the mount. remove the ribbon cable and 4 screws for the display and replace.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
