Question about Sony Computers & Internet
My sony CD Rom problem is that the computer is detecting the CD Drive but the CD Rom is not detecting the CDs
    Brigadier General:
  • 10,406 Answers
Invest $40 in a brand-new CD/DVD reader/writer, since your current device has "died".
Posted on Mar 17, 2011
  • 27 Answers
Then you should clean you cd rom using a cleaner and stil if it doesn't respond you have to change the ROM
2 Suggested Answers
DHINCE10
  • 169 Answers
SOURCE: the computer is detecting the CD rom but the cd
To fix this problem what you can do is to perform the steps below:
- click start > run and type "regedit" w/o qoutes
- once you access the REGISTRY EDITOR kindly open therse folder (each folder contains another folder) make sure to follow the below steps carefully.
- go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
- insed the "class" folder look for {4D36E965-E325-11CE-BFC1-08002BE10318} it is the CD/DVD rom drive.
- at the right part of the registry delete "upper" and "lower" filters name
- once done close the registry.
Go to device manager
- click start > run > type "devmgmt.msc"
- click the + sign beside CD/DVD drives
- right click and select properties
- go drivers tab
- and then select the button uninstall the driver
- RESTART THE COMPUTER
After restart all should be fine now.
Cheers . . .
The computer is detecting the CD rom but the cd rom is not detecting or reading any CDs
The laser is probably burned out or the spindle motor isn't turning.
With the price of these units, I'd just replace it.
There's not much you can do to fix either problem anyway.
A CD ROM (hard to find, but some places still carry them) can be had for $5 or $10.
For just a bit more, you could get a DVD burner.
Mar 17, 2011 | Sony (CDU701) Internal 32x CD-ROM Drive
My hp laptop cd rom is not detecting the cds. i want to formate my laptop.
Hi there, do not format now. Just try these.
Run the driver disk & install the CD/DVD driver. After finish the setup restart your pc or laptop. Hope that time your CD rom detecting the cds. But make sure, that your rom is working. Because if the cd rom is damaged then after formatting you can't install the operating system. May be your cd rom lens is damaged & that's why he can't read the cds or dvds. I suggest you Visit a service center & check the cd rom only. If you able to view the cd rom driver in side the my computer then, i am sure your vd rom lens is damaged.
Thanks & waiting for your feedback.
Feb 14, 2010 | HP Compaq nx6110 PC Laptop
This drive reads a dvd but not cds. do you have
may be it's only a DVD ROM drive not a combo,
you will need a combo to read both DVD and CD
if it was reading CDs earlier then the CDs might have scratch in them, try with new CD.
did u make changes to the cables inside, if you did check if the cabels are connected properly to the drive
Dec 06, 2009 | Sony DDU1613 16X DVD-ROM Drive, Black...
My cd rom won't detect blank cds
try re-installing your burning software ( nero-Roxio et,c )
Does it play a standard Music/Audio CD.
if not un-install and re-install the drive.
Are the cables to the drive connected correctly ?
Does the drive support CD+ And CD- media ?
Are the cds definately Blank, any small amount of data written to them, after failed burn attempts will not show the disk as being empty.
Mike @ Compurepair.
Jun 13, 2009 | Dell Computers & Internet
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Mar 09, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
Mitsumi cd-rom fx4821t wont work
have you installed any software for compiling the data and writing it on the disc....
try to use nero and tell if it shows any error
Aug 31, 2008 | Mitsumi (CRMC-FX4821T) (crmcfx4821t)...
DVD not getting detected
Hi, i have LG GCC4522B CD-RW/DVD-ROM Combo Drive and my problem is that i could open & play CDs. However when i insert DVD the drive doesn't detect the DVD and it shows no DVD in drive or blank. I checked the region setting which is 1. Is it the problem of region setting if so is there any solution for this. Expecting your valuable solution in this regard.
Thanks
Moses
Aug 30, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Does not read cd's
the cd you inserted was not compatible with your cd rom. inorder to read all cds you must use cd roms that supports up 60x speed your only have 24x speed thats y it cant read cds that has above 24x.
Jan 21, 2008 | NEC CD-2800D (cd2800d) 24x CD-ROM Drive
Not reading DVD
It's common problem with combo drives in notebooks, they don't seem to last long. Try this:- Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers. If the problem persists the laser is faulty in the drive and the drive will need to be replaced.
Mar 07, 2007 | Sony CRX830E CD-RW/DVD-ROM (Combo) Burner
No playing CDs
go to website of bell computer 1. find the latest BIOS and download it to your computer 1. find the latest driver for your CD model and download it Good luck!
Aug 17, 2006 | Packard Bell GCD-R580B (gcdr580b) Internal...
Computers & Internet Logo
100 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
