Question about Compaq 449901-001 - HP Presario V6500 V6600 V6700 V6800 Series Full-Featured (FF) Laptop Motherboard
My presario will not start, after several minutes get warning 2"no operating system", all lights come on and dvd drive wirrs. Have recovered system to no avail.
    Scholar:
  • 172 Answers
Most likely , It is not finding a right booting device....make sure OS was re-installed properly
OR
Eject any CD or DVD from from DVD , unplug any USB drive....
After this reboot your system & see , if you can go in...
Thanks for choosing Fixya
Sandeep
Posted on Mar 17, 2011
Tip
How to back up your iTunes in Window 7 OS
<p>On CDs (Discs)<br /> <p>1. Open iTunes. Click "File" tab at the top of the screen to "Library" and click "Backup to disk" option "iTunes Backup" window.<br /> <p><br /> <p>2. Choose one of the backup "iTunes Backup" screen - with the back of the entire iTunes library and playlists "or" you only buy from the iTunes Store. "<br /> <p><br /> <p>3. Insert a CD-R or DVD-R drive and click "Next "in the "iTunes Backup" window. iTunes will automatically read the disk and start the burning process (see tips).<br /> <p><br /> <p>In an external hard drive<br /> <p>1. Close iTunes if open. Connect your hard drive on the correct port on your computer and switch it on.<br /> <p><br /> <p>2. Find your external hard drive in My Computer and select the folder you want your files back.<br /> <p><br /> <p>3. Open a new browser window and locate your iTunes folder indexed. These can be found in "\ Users \ username \ My Music \".<br /> <p><br /> <p>4. Click Start, and the required files to the hard disk, or select your entire iTunes library and drag the contents to the external hard drive to drop. The transfer may take several minutes to several hours.<br />
on Jun 21, 2011 | Computers & Internet
2004 Nissan Altima 3.5L BATTERY LIGHT went on during 15 minute drive. Next day car "died" while idling after a 20 minute drive. BRAKE WARNING LIGHT & BATTERY LIGHT on prior to full electrical failure.
Start with checking the alternator voltage with a multimeter. With the car off check the voltage in the battery which should be holding 12v charged less if flat of course then start the car and test the battery again. If the alternator is good you should be getting a reading of 14 to 14.5 v if it's the alternator it'll A) not put any charge into the battery or B) be a very low voltage being anything under 13.5 v
Sep 30, 2016 | 2004 Nissan Altima
I have a hp presario CQ57 w/windows 7. I get a BOOTMGR MISSING at start up. I have a repair disk. Ive done the "copy bootmgr c:\" at command prompt thing. When it restart's it says,"no...
sounds like a hard drive is bad check plugs inside comp if there all ok . go into to bios set boot to dvd/cd rom and insert repair disk do a reset to an earlier time if that fails replace hard drive you will need an operating system disk from ,hp.
Feb 07, 2013 | Computers & Internet
Break foult
I did the brakes on my 03 Passat about 2 years ago and the same thing happened to me. I took it to several places to have them figure it out any many wanted to charge an arm and a leg. With severe hesitation I took VW and they said it was a recall sensor item and would cost nothing to fix. So you may want to give VW a call and see if it is the same sensor issue.
Jan 18, 2012 | 2003 Volkswagen Passat
My compaq presario f768wm isnt recognizing my cd/dvd rom. my camera quit working and also it says it can't find my audio output device.
For that problem, Try first replace that internal DVD-rom drive other good internal DVD-rom drive. if not Also Detected or recognize.
Try this second solution. insert external USB type DVD-ROM. if not recognize also, Your operating system Have internal software device data corrupted. You need to reinstall operating System like windows xp, windows 7 (OS) etc.. to fix data Corrupted of operating system device for hardware software.
Please see sample external DVD-rom USB type.
Just let me know if not yet working your Compaq Presario 700 series DVD-rom Drive.
Thanks for using Fixya.
Aug 19, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
I have a message rebooting computer dell inspiron 8500 with DK23EA-30 "Warning: Dell's Disk Monitoring System has detected that drive 0 on the primary EIDE controller is operating outside of normal...
This is a SMART hard disk monitor Warning. You should probably make a backup on an external drive just in case the drive decides to fail completely.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 27, 2011 | Hitachi TravelStar DK23EA Series DK23EA-30...
I have a orange warning light flasing on my mini cooper 51 plate and i do0nt no wat it is can u help?? the symbol has a (!) on it? there is a button with the exact same symbol under my handbrake
This is the tyre pressure indicator. It shows that one of the tyres is losing pressure through a calve leak or puncture, or can also be triggered after you get new tyres or rotate the tyres.
The method to re-set the tyre pressure warning light is as follows:
Turn the ignition to position 2 (ignition on but motor not started). Press and hold the button under the handbrake until the warning light on the dashboard comes on for several seconds. Start the engine. Drive the car normally for several minutes. This will cause the system to re-set to the current tyres and pressures you have. It will then only turn the warning light on if the pressures change - for example if you get a puncture.
Oct 17, 2009 | 2002 Mini Cooper
Several warning lights come on after 20 min, then overheats
have the alternator replaced and when you do this also replace the drive belt
Feb 09, 2009 | 2003 Volkswagen Beetle TDI
Need to install OEM Windows 98
ok you need to reboot your computer from the CD rom with xp disk in it.
start your computer hold down the f12 key, a small menu will come up , pick cd/dvd/cd-rw drive with your arrow keys ,
select enter , follow xp directions on how install operating system on the monitor.
Jan 15, 2008 | Hitachi HDT725050VLAT80 500 GB EIDE Hard...
Compaq 449901-001 - HP  Presario V6500 V6600 V6700 V6800 Series Full-Featured (FF) Laptop Motherboard Logo
133 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
