Question about PfaFF Sewing Machines
When the needle goes down to cath the bottom thread, it dosent catch the bottom thread, an the top thread releases, and dosent stick
    Scholar:
  • 89 Answers
Sound like a timing problem, what is your model number, Ill need that to help.
Posted on Mar 17, 2011
My brother computerized sewing machine does not catche the bottom thread to make a stitch
try using a longer needle, or lowering the one you have now by loosening the needle screw and dropping the needle down some
Aug 08, 2014 | Brother Sewing Machines
I have a consew 225 I think and when I try to bring the thread up from the bobbin the thread from the needle goes down and around the bobbin to bring up the bobbin thread and catches. It will not pass
Your machine probably needs to be adjusted and timed. But make sure you clean under the bobbin area before you try again... or take it to a machine pro
Jul 18, 2012 | Consew 226R-1
How do I thread my white 765 top and bottom
The bobbin is held in a removable bobbin case. If the bobbin case is already out of the machine, place the bobbin in the bobbin case such that the thread will come off clockwise. Leave a couple of inches of thread loose. Then pull the end of the thread down into the cross slot and thread it through the tension spring and into the delivery eye.
Next make sure the presser foot is up and the needle is in the highest position. Push the slide plate up. Hold the latch in the center of the bobbin case and place it over the center stud with the finger opposite the notch in the shuttle race. Release the latch in the center and press down on the bobbin case until you hear a click when the latch catches the groove. Leave a 2-3" length of thread extending out of the bobbin case and push the slide plate down. (Reverse the steps to remove the bobbin case.)
To thread the needle, place a spool on the spool pin with the needle bar fully up. I try to place the spool on the pin so that the little catch is out of the way. (The catch holds the end of the thread when the spool isn't in use.) Bring the thread through the guide loop on the top of the machine and then down through the thread guide on the right side of the tension discs. Bring the thread back up on the left side of the tension discs through the check spring and through the thread guide. Bring the thread through the hole (eye) in the take up lever (from right to left). Then bring the thread down through all of the guides down the face of the machine to the needle. Finally thread the needle from left to right. Pull a few inches of thread through the needle. (I find the threading of the needle to be easiest if the thread has been cut at an angle after threading the machine.)
The manual for the White 765 is available from Singer's support site. The direct link to the manual is http://www.singerco.com/uploads/download/827_white-765-x.pdf . See page 6 of the manual and the subsequent pages for pictures.
I hope this helps.
Nov 18, 2011 | White Sewing Sewing Machines
THE SEWING THREAD WILL NOT CATCH THE BOBBIN THREAD
the needle is not catching the thread on the down stroke have you got enough thread out on the bobing for the needle to catch
Jul 22, 2010 | Elna Heirloom Edition 6005
Viking husqvarna classica 100, thread tension
I suspect you are correctly threading the machine but the timing of the needle and bobbin hook is off. When the threaded needle goes into the bobbin area, a pointed hook grabs the thread and loops it with the bobbin thread. Something is catching when the needle starts to come up that is not allowing the bobbin thread to be pulled back through the needle plate opening by the upper thread. With machine threaded and bobbin in place, have the bobbin area open if possible and watch the thread interaction when the needle goes down. To set the hook/needle timing, normally covers have to be removed. Suggest taking it to an authorized Husqvarna Viking dealer for service. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Jan 19, 2010 | Husqvarna Viking 1
Bobbin thread won't catch with needle thread
check that the needle is in the right way round i.e. with cut out on the needle facing into the machine. if this is fine then check that as the needle comes back up from the lowest point that it goes to, that the point on the bobbin case passes just above the hole in the needle, i.e. in the middle of the cut out.(if not it needs re timing) if threaded a small loop should appear at this point for the bottom bobbin to catch if not slacken the top thread and try again.
Sep 07, 2009 | Singer 7436 - INGENUITY
I've got a Necchi 535FA with a bobbin thread that doesn't hook.
Sounds to me like you may have put the needle in backwards. The flat side should be to the back.
Rick
Aug 24, 2009 | Necchi Sewing Machines
Sewing thread won't pick up the bobbin thread
are u holding the end of the top thread hen needle goes down?
it helps :)
Mar 17, 2009 | Euro-Pro 1260DX Mechanical Sewing Machine
Sewing Machine (brother XL 3200) When I attempt to thread the machine I get to the part that I want to catch the top thread that goes through the needle with the thread that is in the bobbin and usually...
You may have the bobbin case in wrong.  I have this machine, and I know that it is really easy to put the bobbin case in wrong.  Try taking it out and making sure that the little stop is in the front and it is seated down in there and able to wiggle back and forth.  My experience with this machine, until the other day when my cat knocked mine off the table and knocked something out of alignment, is that it just works.  Any time mine hasn't worked, it has either been dirty, needing oil, threaded wrong or the bobbin case wasn't seated right.  In other words, it has always been my fault.
Jul 19, 2008 | Brother XL-3500
Bobbin help please!
Take out the raceway and check for broken threads/lint. Unthread the machine and put in a new needle taking care to insert it correctly. It may be that the needle is slightly bent. Put everything back carefully and check it is running smoothly with NO THREAD first(no bobbin thread either-use an empty bobbin). This will prove there is nothing catching. If it catches when you thread it then you are having a problem with incorrect threading.
Mar 24, 2007 | Kenmore 15212 Mechanical Sewing Machine
Sewing Machines Logo
44 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
