Question about Kenmore 44832 Front Load Washer
Wont spin final cycle - Kenmore 44832 Front Load Washer
    Brigadier General:
  • 6,277 Answers
Many makes of washers will not start the spin cycle if they sense that there is water still left in the drum- AND they don't flash lights or give any other indication!
So- just in case it is water still left (no promises, it could be something entirely different but it's worth carrying these instructions out anyway and regularly!) here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 17, 2011
My front load washer wont go into final spin and clothes are soaked
What is the model number of the unit?
Try running it in a different cycle to see if it does the final high speed spin.
Post back the results.
Nov 08, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Washer wont spin out clothes when it is in the final spin
i have a atf6000fs1...I washed a load and i thought it was done but items were still wet. So i turned on the spin cycle and it flashed err and turned itself off. It wont run. Any suggestions???
Oct 24, 2010 | Frigidaire ATF6000ES Front Load Washer
My fridgidaire frontloader wont do a spin cycle
A lot of times it is the strainer clogged at the pump. That has happened to mine. Hope that helps.
Sep 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
Won't spin in final spin cycle.
transmission shot if it does everything else but spin,not worth fixing for the price of a transmission plus labor,just junk it and buy a kenmore,whirlpool top load-mike
Apr 28, 2009 | Washing Machines
Washer will not start final spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Apr 05, 2009 | Maytag EPIC MFW9700S Front Load Washer
Damp clothes at end of spin cycle
Time to check out and clean your filter...........
Mar 01, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Having issues with my washer Model # LSR7010PQ0. Will not perform final spin cycle. All the water is draining.. basket just wont spin. Tried the spin cycle on one of the other settings and that worked. ...
As the machine goes through the cycle, it should do what is called a neautral drain (drains water without the tub spinning) then a momentary power intreupt allows the gear to slip down and the spin begins. If this is not occouring on one cycle, it is usually a bad timer.
Jun 13, 2008 | Whirlpool Washing Machines
Wont complete final spin and drain
Ok you need another repair man this is a simple timer problem since you said dial I take it as timer machine if so it has a dead spot in that cycle. although if it is a electronic control replace the control board and this will be the cure good luck and Merry Christmas
Dec 21, 2007 | Maytag MAV7600 Top Load Washer
Kenmore 44832 Front Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
