Printer Lexmark x-1100. Makes all the moves but the sheet comes blank
    Brigadier General:
  • 10,406 Answers
Either:
* empty ink-cartridges -- replace them
* clogged ink-jets -- use the Lexmark software to run a few "print-head-cleaning" cycles.
Posted on Mar 17, 2011
Every 10 prints or so a single sheet of paper will come out printed but will crunch up as it is feeding to the output tray. Nothing seems to be blocking it because not every page does it.
If you are getting blank pages between print jobs or between page or each print job, separator sheet must be turn off. By default NONE is the factory settings for separator sheet. You may restore factory defaults. to do this click on menu>settings>general setting>factory defaults.
For further assistance, please contact Lexmark Technical Support
Mar 08, 2011 | Lexmark C540N PROD SPECS TBD Printer
Lexmark e260dn printer always prints an extra page (blank other than page 2 of 2). It doesn't seem to be a setting on one computer because there are several different computers that are set up to print to...
If printer is connected to network, separator sheet must be turned off. Please access the printer's web interface and click on configuration and click on finishing menu, select none for separator sheet and then click on submit.
For further assistance, please contact Lexmark Technical Support.
Jan 21, 2011 | Lexmark E260dn Laser Printer
I have a lexmark 1100 printer and got a differant computer.I didnt have the software so i downloaded the drivers from lexmark website and now printer acts like it is printing but when page comes out it is...
hhmmm...ok..well..here's a suggestion.
A. remove the old printer that you installed from printer menu, through control panel.
B. Get the driver again. Sometimes they get corrupted.
C. Install the driver again.. Unplug printer from computer and power it down.
D. Make sure that the driver installs cleanly.
E. Plug printer in again, no power.
F. Turn Power On. XP should 'see' the printer show up on the window. If this does NOT happen, then the cable is most likely no good.
Let us know how this works for you.
Nov 30, 2009 | Lexmark Color JetPrinter 1100 InkJet
Instruction manual
Setup sheet and User's manual on this site:
http://www.lexmark.com/publications/eng/x1100/index.html
The direct links to the instructions in pdf format:
Setup Sheet
User's Guide
Sep 20, 2009 | Lexmark X1150 All-In-One InkJet Printer
The printer is issuing blank sheets - every other sheet being dispensed by printer is blank - i.e. without printed data
This could happen if the text you are sending to the printer spills over slightly onto a new page. To test for this, press Ctrl-P and select "Current Page." This will insure that only one page is being sent.
Aug 12, 2009 | Lexmark Office Equipment & Supplies
Lexmark C752
if you just run blank sheet through the printer using the printer feed button it should remove any ink on a roller. which probably got there from printing off a picture.
Apr 15, 2009 | Lexmark C752 Printer
Won't print
The printe will not scan or print. When I fax documents it is recieved witha balck shadow in teh background. I get error 2200 when I try to print or scan.
Apr 03, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark X 5150 prints blank pages
Hi !!
Try this ---
take out the ink cartridges from printer
Take a tissue paper and make it damp with water
Then CLean the bottom part of cartridge where you see some golden contacts , just wipe it off with damp tissue .
Check if there is any ink coming on the tissue or not .
If No ink coming out , may be u forgot to pull out the protective tape or there is no ink inside the cartridge
Let me know what happens
Priya
Nov 29, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark 427 - shuts down during printing
maybe the print drivers went haywire? remove them, from your system, and then get new ones here
Mar 22, 2008 | Lexmark X4270 All-In-One InkJet Printer
21 people viewed this question
k24674
jasbo
jasbo
