Question about Frigidaire Dishwashers
FRIGADIRE FDBC45BAB0 WATER WON'T COME INTO DISHWATER
    Brigadier General:
  • 3,513 Answers
Hi
There are various reasons as to why a dishwasher wont fill.
1. Check for low water pressure at the tap.
2. The water that fills your dishwasher is controlled by a float, much like the float in a toilet. As the water rises, so does the float, eventually causing the float switch to shut the water off.
The float could be stuck or its movement impeded. Remove bottom rack of dishwasher and then the cover of the float assembly. Verify if it moves freely.
3. You will need a multimeter to check the float switch itself, which is accessed by removing the service panel that is below the door. The switch is just below the float assembly and is held in place by a few screws or possibly a clip. Turn off power to washer, disconnect switch from the float assembly and replace, if needed.
4. There could be an obstruction in the water-inlet hose at the inlet valve. Remove the dishwasher from its cubby hole by removing remove the service panel, then unscrewing the dishwasher from the countertop. Disconnect the water inlet hose and check for any sediment buildup.
5. There could be a problem with the fill valve, drain valve or drain solenoid.
Also check the bellow link to have an in-depth idea related to your issue:-
http://www.partselect.com/dishwasher+dishwasher-wont-fill+repair.htm
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Mar 17, 2011
Water won't come into dishwater
Make sure your brass line or braided line is hooked up with no kinks or pinches, Then make sure water to valve is turned on.
Sep 05, 2012 | Whirlpool 24 in. DU920PW Built-In...
What is the float switch
I have no real experience with float switches on dishwashers, but have with some in humidifiers. It's a piece of styrofoam on a narrow metal stick that lifts when the appliance fills with water & lowers when the water empties. If this gets stuck on something, like a dishwasher rack, the unit won't fill or empty the water & the cycles won't work properly. Take a look & see if there is such a thing hung up somewhere in the dishwasher. If you can loosen it, your dishwasher should work again.
Feb 21, 2012 | Beko 24 in. D3421F Free-standing...
Problem is put the dishwater on ,doesnt seem to be enough water on the cycle ,dishwater goes through the whole cycle even drys, but has some water lying at the bottom at the end .Some said it might be a...
Check that your supply faucet is open, Check if there is a screen in the supply line, these can become blocked due to scale deposits from the mains. If there is no screen check that the inlet solenoid valve has not got blocked. If none of the above help, check that there is power getting to the solenoid valve when the machine is supposed to be on the fill cycle. If no power is betting to the valve, the timer might ba faulty. (You can try hand filling the machine and see if it goes through a cycle, at least up to the rinse stage, this will tell you if the timer control is working).
If you feel that there is water not being pumped out, remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Feb 18, 2011 | Indesit Dishwashers
Dishwater goes from sink to bottom of dishwater
you need to tie up the drain hose under the sink above where it connects to the drain spigot to stop the sink water flowing down into dishwasher instead of the drain. A blockage in the sink drainage can also make the condition worse.
Jul 14, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Sink dishwater intrusion
Hello- Find drain hose from dishwasher under sink. Should have gooseneck ~ in hose run to keep water from getting back into dwshr. Does full sink drained all at once push water into tub? Sometimes stuff not disposalled yet blocks drainage. Older motors can tend to become weak with age, not pumping as much water out of tub as it used to.Anyway- Hope this helps- ED
Mar 01, 2010 | GE Dishwashers
Water keeps filling even if dishwater is off or if the door is open, the only way to stop it is from turning tap valve off below the sink.
Your dishwasher water fill valve is defective. Remove power from the DW. Remove the bottom toe kick panel. The water valve has the incoming water line connected to it.Remove the wires from the valve. If the water stops entering you have a bad timer. If it makes no difference you have a bad valve. The valve is a replaceable part. The timer is a replaceable part.
Dec 16, 2009 | KitchenAid KUDS01DJ - Multiple Color...
I have a Dishlex Global 500 dishwasher (DX500lWW*b). Woke up the other night to find water all over my kitchen floor. The hot water hose connector to the hot water tap split (bursted). The dishwater was...
I found this
"Hi - answer I was given by Electrolux Help was: pull machine out from under bench onto old towel, tip GENTLY onto left hand side (your left as you face the front of the machine) after it has drained, stand up gently, put back & turn on. Apparently it is the overflow trough reading as full ('oF' Overflow). Then run through some dishwasher descaler or Finish dishwasher cleaner. Worked for me."
http://www.howtomendit.com/answers.php?id=79783
Oct 05, 2009 | Dishwashers
KENMORE ELITE DISHWATER panel went blank but there
Check the continuity of the thermal fuse. It's clipped onto the electronic control inside the console.
Let me know if you need more help.
Mar 12, 2009 | Kenmore Dishwashers
Dryer runs, no heat
hey mark we got this one done.if your ignitor is glowing and its not firing over 2 things flame sensor,but rarley.99 out of 100 will be the valve coils 2 black guys on top of the gas valve with wires going to them.you could use the cheapest brand you can find[ie..frigadire,ge,kenmore,amana.there all the same .on my truck i stocked frigadire because it was cheaper for me and then would make more profit yet charging same price as there brand,you can do it .God bless,tom
Dec 28, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Dishwater not filling with water when switched on.
Hi nitwit2,
I'm Harvey the Master Plumber.
Your problem is: Dishwater not filling with water when switched on.
Electric on? Good. 9 times out of 10 it's a bad solenoid valve. It's under the d/w behind the kickplate on the left. I don't recomend this repair for the average homeowner. You might look in the Repair Directory for a repairman. If you're up to it, I find removing the d/w from the cabinet facilitates installation.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 27, 2008 | Bosch Dishwashers
Dishwashers Logo
71 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
