Question about Canon PIXMA MX700 All-In-One InkJet Printer
It was showing error code 5200, I did the fix of removing the print head and when I re-installed it , now it is showing that print head is incorrect. It is the original one that came with the printer and has been working.
    President:
  • Canon Master
  • 2,246 Answers
1. The printer is turned off and plugged the power cord.
2. Press Resume button 2 seconds
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow GREEN.
7. And the computer will detect new hardware, just ignore ...
8. Press the POWER button, then the printer will die.
9. Press the POWER button again then the printer will flash
Posted on Mar 17, 2011
  • dharmastw May 18, 2011
    By dharmastw May 18, 2011
    This week I have same problem on my CanonMX700 (Error code 5200 then print head error).
    I applied the solution but the problem still persist
Canon troubleshooting
Hi Nolan,
Error code 5200 indicates that print head temperature error occurs. This error usually occurs in case of ink low or third party or refill ink usage.
I hope the following link will answer your question clearly. :)
Canon Printer Error 5200
Jan 11, 2014 | Office Equipment & Supplies
Canon PIXMA MP495 InkJet Printererror code 5200 problems
Here what I found for you. If it fixes your issue, don't forget to give me a good rate. Thanks
Print head temperature rise error or Error Code 5200
Condition: The print head temperature exceeded the specified value.
Problems and Solutions:
  • Turn off the printer and then turn on if error still persist replace Ink cartridge or print head thankyou for using
Aug 30, 2011 | Canon PIXMA MP495 InkJet Printer
My Canon MP490 is displaying error 5200. I can't get it to work again -- help.
May 26, 2011 | Office Equipment & Supplies
ERROR CODE 5200 PRINTER ERROR HAS OCCURD TRIED EVERYTHING ,UNPLUGED ,REMOVE INK CARTRIDGE ETC. STILL NOT WORKING
Error 5200 is a service error
Follow this solution step by step
  • With the printer turned on, unplug it
  • Open the top and bring the ink cartridge holder to the middle
  • Raise the gray bar and remove the print head assembly with the cartridges in it
  • Lower the gray bar with the head missing and close the top with the head out
  • Restore the power,wait till the printer starts
  • It will tell you to put in the cartridges
  • Refit the print head, close the top and the printer should resume working
This is a commonly mentioned fault/fix, hope it helps
May 18, 2011 | Canon PIXMA MX340 Wireless Office...
I kept getting service error 5200 when I tried printing something. How do I fix this problem?
Hi there
Service error code 5200 is the print head error. Rub the print head into a plain paper with rubbing alcohol until ink flows and then after that remove all the USB cable connection and power cord and plug it again. Then run the print head cleaning maintenance like print nozzle or print alignment.
It should be fine right now. Please let me know if you need more help
Mar 07, 2011 | Canon PIXMA MP240 All-In-One InkJet...
My canon mp250 shows the error 5200 when i try to print what does thet mean ?
it means Print head temperature rise error or Error Code 5200
Visit:
[url]http://pcmediks.blogspot.com[/url]
Dec 10, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
My printer is showing error code 5200.i took it to the store i bought it from and the electrician said that the printing board is damage.can it be fixed.
Hello
Well, i dont exactly know if the electrician has given the correct diagnosis, but then i could be wrong as well. SO here is my opinion.
According to the error code, http://pixma.ulmb.com/?p=226, the error #5200 means "Print head temperature rise error".
Some of the nozzles of your printer are clogged. The print head will overheat because it does not have ink going through the nozzles to cool it. This explains that your printer prints again after cooling. But you continued to print repeatedly, the print head may have been destroyed due to overheating. Printing solid color on Canon printer, while the print head is clogged, is the quickest way to kill a print head. This kind of instruction may work for other printers. But it is certainly NOT for the Canon printers.
When a Canon print head is clogged, only printing nozzle check is allowed. Otherwise, you are putting your print head at risk. Trust me because I killed an i550 print head this way while learning how to unclog print head.
Really hope this can be of help.
Kind regards
Andrea
Dec 07, 2009 | Canon PIXMA MP240 All-In-One InkJet...
I have problem with my mp600, in the lcd displayed error code u52. how to fix it?
This means The type of print head is incorrect. Install the correct print head." U052
The solution is follow the directions given in the Easy Setup Instructions to install the Print Head.
If the Print Head is already installed, remove the Print Head once and then reinstall it.
If the error is not resolved, the Print Head may be damaged and may need replacing.
Oct 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error 5200
Error 5200 is a printhead temperature error, sounds like you need a new printhead. The part number is printed on the side of the printhead. it's a QY6 number
Aug 13, 2009 | Canon Pixma MP480 All-In-One InkJet...
My canon mp830
Error code 5200 means the print head temperature is too high. The only was to resolve this error is either replace the print head or replace the logic board. The print head is available, part number QY6-0061 but you will struggle to find a logic board. The only other thing you can try is resetting the EEPROM on the logic board, this sometimes clears the error. A service manual will show you how to do this: http://www.tradebit.com/filedetail.php/4546483-canon-pixma-mp830-printer-service-manual
Jun 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MX700 All-In-One InkJet Printer Logo
321 people viewed this question
old marine
old marine
