Question about Sony KDL-52Z5100 LCD TV
Kld-52z5100 6 blinks - Sony KDL-52Z5100 LCD TV
  • 902 Answers
The 6 blinks abdormal speaker voltage or backlight issue if you still have the manual it will tell you how to diagnose it and fix it.
Posted on Mar 17, 2011
I recently bought an Sny Bravia kld-32w600d smart TV but we don't seem to be able alter the volume either up or down
If the volume works ok on the TGV without remote, replace the remote.
But the volume on the TV does not work, replace TV (you could return in warranty or otherwise)
Sep 23, 2016 | Sony BRAVIA Televison & Video
The symptom my Sony KLD-46BX427 TV displays is multiple vertical colored lines on the screen.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. line fault to all LCD TVs are similar; irrespective of its brand and screen size.
Jul 29, 2015 | Sony Televison & Video
My Sony TV kld-40ex400 is blinking one
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Oct 08, 2014 | Televison & Video
The tv goes dark on one side sony 46
Had same issue with kdl 46xbr5 (service manual lists this model and your model in the same manual).
I loosened and retightened all of the ground screws until I found the one that caused the problem. I also reseated all of the cable connectors (with the unit off) before I did that as well. Found a few connectors were loose and at least 3-5 ground screws were not tight. works just perfectly now.
Mar 22, 2013 | Televison & Video
Set up code for sony tv kld 60ex645 to work with universal electronics remote control URC2054
Check these codes. 0020 0054 0186 0028 0030 0171 0381. If you wish to get more codes to different other remote controls, check this site.
Feb 10, 2013 | One For All URC4220 Remote Control
Sony kdl52nx800 will not turn on indicator light blinks 5 times
While looking found this:
Found this service bulletin for sony KLD
KLV40EX600 not austalia model but think KDL will be similar
Model No: KDL-32EX400 KDL-40EX400 KDL-32EX500
KDL-40EX500 KDL-46EX500 KDL-55EX500
KDL-32EX600 KDL-40EX600 KDL-32EX700
KDL-40EX700 KDL-46EX700 KDL-52EX700
KDL-60EX700 KDL-40HX700 KDL-46HX700
KDL-55HX700 KDL-40NX700 KDL-46NX700
KDL-52NX800 KDL-60NX800
SUBJECT: Counter measure for Intermittently 5 times standby LED blinking
SYMPTOM: Customer may report that intermittently after AC OFF/ ON (or Deep Standby/ ON), TV will shut down with LED blinking 5 times. If set is placed in Standby, then On, symptom will re occur. If AC is removed, set will work normally when AC restored
CAUSE: Timing mismatch of I2C communication causes interrupt signal inside TV. This causes TV to shut down with error 'Standby led flashes 5 times'
SOLUTION: This is a user correctable issue -
Where possible, please refer customer to Sony Website -(or ) and search for relevant model to download correct update. If the unit is in Workshop, please perform update as per Instructions.
Dec 14, 2012 | Sony KDL52NX800 52 in. TV
Sony user instruction manual for KLD-19BX200BU
This Model is not seemed to be listed in the site of Sony.
Please check this support site of SONY for manuals.
Nov 16, 2010 | Televison & Video
I have a sony lcd kld-46w3000. The power light is on, but the screen is still black with no audio sound.
Reseat all cables including the signal cable.
Test the screen by pressing MENU on the remote. This will let you see if the issue is with the signal.
If the menu appears, reprogram the channels.
Jan 15, 2010 | Sony BRAVIA KDL-46W3000 Television
Sony KDL-52Z5100 LCD TV Logo
192 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
