DVI - HDMI cabel connection.
I use DVI -HDMI cabel to conect my older HDTV with no HDMI input and new receiver( then I connect this cabel) sound is gone, it's heppen when I use DVD player( connected HDMI cabel to reciever).
  • 6 Answers
You must use a separate two wire audio cable with this connection.
Posted on Aug 15, 2008
HOW DO I PLAY A DVD USING Hitachi Flat Panel Television 32HDL51 (ITS CONNECTED THROUGH HDMI CABLE)
Page 18 of the manual, you shouldn't need to do steps 2 or 3.
CONNECTING A COMPONENT SOURCE WITH HDMI or DVI CAPABILITY TO INPUT 1 or INPUT 2
1.Connect the HDMI or DVI to HDMI connection cable from the output of the HDTV set top box or DVD player to the HDMI input as shown on the AVC Center below.
2.With DVI output, connect the cable from the AUDIO OUT R of the HDTV set top box or DVD player to the INPUT (AUDIO/R) jack.
3.With DVI output, connect the cable from the AUDIO OUT L of the HDTV set top box or DVD player to the INPUT (AUDIO/L) jack.
4.Press the INPUTS button, then select INPUTS 1 or 2 to view the program from the HDTV set top box or DVD player. The VIDEO OSD label disappears automatically after approximately four seconds.
5.Select ANT A or B from the INPUTS menu to return to the previous channel.
NOTES:1. Completely insert the connection cord plugs when connecting to rear panel jacks. The picture and sound that is played back will be abnormal if the connection is loose.
2. The HDMI input on INPUT 1 or 2 contains the copy protection system called High-bandwidth Digital Content Protection (HDCP). HDCP is a cryptographic system that encrypts video signals when using HDMI connections to prevent ******* copying of video contents.
3.HDMI is not a "NETWORK" technology. It establishes a one-way point-to-point connection for delivery of uncompressed video to a display.
4.The connected digital output device controls the HDMI interface so proper set-up of device user settings determines final video appearance.
http://tv.manualsonline.com/manuals/mfg/hitachi/lcd_television_lcd_display_monitor_32hdl51.html?p=18
Jun 14, 2016 | Hitachi Televison & Video
Why is there no power to DVD box?
Check your power cord and plug for damage, do a wiggle test with DVD plugged in and see if it comes on while moving and bending wire plug. press the helpful button
DVD power supply repair tips
Press Release Consumer Electronics Video Audio Camera TV
DVD Player Repair Guide Covers Every Detail
Jan 26, 2016 | Televison & Video
Ive recently bought a 1080i samsung tv and was wondering will is there any way to connect it to a hdmi cable so i can play my ps3 in better quality?.
IF YOU HAVE A DVI CONECTER A BIG WHITE PLUG WITH MANY CONNECTERS YOU CAN BUY A HDMI -DVI ADAPTER BESIDE THE DVI CONNECTER YOU WILL HAVE INDICATION FOR DVI AUDIO YOU MUST PASS TWO AUDIO CABLES FOR SOUND
Jun 03, 2010 | Samsung HC-P4241W 42" Rear Projection...
Connection Problem with HDTV, Receiver, DVR, and DVD
check the setup menu to direct your inputs from the hdmis. its all in the setup menu. good luck
Feb 10, 2010 | Yamaha RX-V463 Receiver
My menu says dtv Currently unavailable. How do I use the HD feature on my Olevia LT32HV
Do you have a High Definition cable/satellite reciever or a Blu-Ray player? Does your tv have a HDMI input or component or DVi or all of those? Most newer HD components use the HDMI connection. The HDMI connection is a single cable that has both video and digital audio together. The component connection is a connector with three rca jacks that are red, green, and blue. Audio is connected seperately with this connection via red and green rca audio jacks or a digital audio connector. The last is a DVi connector that is found on computers. Some older HD tvs and components use this connection. There are adapters available to turn a DVi connection into a HDMI connection. So if your TV does not have a HDMI connection but your HD reciever does you can use and adapter but you will not have any audio this way without using a seperate connector for the audio.
Sep 16, 2009 | Syntax Olevia LT32HV 32 in. HD-Ready LCD...
HDMI only for video and sound through regular audio input
DVI does NOT support sound unlike HDMI. Hopefully your PC has a Co-axial S/PDIF digital output. If not you might want to spend the $50 and buy a nice one from Creative. Modern motherboards are even coming with HDMI built-in but that's NOT your situation. I use a 15" DVI to HDMI cable but you are probably using an adapter and the a regular HDMI cable. Get co-axial digital audio cable of the right length and connect it to the co-axial inputs (they're in the upper corner). Use the remote's set-up button and select the "Digital Input" option. This is very powerful. You can assign any of the Optical or Co-axial inputs to any associated device.
I have my PC as Video 3 with sound coming in via HDMI which I assign under the "HDMI Video" menu and sound under the "Digital Input" as "Coax1". I use "Coax2" for the DVD player that lacks an optical output. If you use regular analog you are screwed as you found out. I usually use the headphone jack and an extension cable with the Computer and watch on it's monitor.
All HDTV sets are **** compared to a decent computer monitor. The deliver MUCH clearer video and much higher resolutions that shitty the 1080 HDTV maxes out at. ATSC is **** compared to a PC. Grated, cable is junk compared to ATSC at 1080i but that's another story. Yet, comparing ATSC to a computer is like comparing NTSC or digital cables' crappy 480i with ATSC at 1080i. It that much greater. At least 720p is wide screened unlike 480i garbage that's most of Comcast's "HD" digital junk.
Feb 20, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
HELP WITH CNECTION
Only if you've got an HDMI output on your computer. Some computers with higher quality video cards, or just newer ones will have a DVI output for a monitor. You can get a DVI to HDMI cable that will then be able to connect the two.
As others have said, if you have a video card with DVI output, you can get the video to the TV using a DVI to HDMI cable.
But no one mentioned anything about audio. DVI can not carry audio, so you'll need to send audio from the computer to the TV (or receiver). Some TVs have audio inputs associated to one (or more) HDMI ports for use with devices that have DVI, but not HDMI. My Sharp LCD has two HDMI ports, one with separate audio inputs, one without.
Sep 27, 2008 | Computers & Internet
Play station 3 hdmi-dvi
Yes you can. It will not be like a HDMI cable but it will be better than the RCA. Your image will be in your HDTV (1920 × 1080). But you will have to buy a HDMI cable and and HDMI-DVI adaptor. You will not have sound so you will have to connect either your RCA or if you have a Digital Optical Audio sounds better.
If you have any questions just ask.
Feb 26, 2008 | Sony Playstation 3 (PS3) Console
Sony STR-DA5300ES Audio Problem
I am posting this to try and get everyones audio problem for this receiver fixed. If you only connected the HDMI cable to the 510, you will not get sound. This receiver passes through HDMI only, no processing of audio. You must either connect a fiber optic or digital coax to the 510 for that respective HDMI input from the BD player, the DVD HDMI only accepts digital coax, and the Video2 HDMI only accepts fiber optic. If you BD player does not have digital coax out for audio, you must move the connection to Video2 HDMI and connect fiber optic to the Video2 fiber input. Sony butchered the whole purpose of HDMI with this receiver. Hope this heps you. By the way, it is hardware, no firmware update will correct this.
Jan 02, 2008 | Sony STR-DG510 Receiver
Televison & Video Logo
269 people viewed this question
Top Televison & Video Experts
Electro Med Services...
