Question about Echo Garden
Echo cs-370 chainsaw wont start. running fine the day before. good spark. fuel wet at muffler. plug always wet.
  • 784 Answers
Check air filter- is it clean?
Some plugs are without cilinder ok but if in place dont work. cahange the spark plug.
Posted on Mar 17, 2011
I have a CS-4400 Echo chainsaw that wont start. I don't think it is firing
1st thing let's check the spark.remove the plug leave it connected to the wire and ground the side of the plug to the engine. and have someone pull the started rope. watch the gap area of the plug for spark. make sure the plug is gap to factory specs, and hold it by the rubber booth. and the on switch is in the run position. good luck Tom
Mar 09, 2015 | Echo Garden
Echo t330 chainsaw has compression lock cant pull start cord
remove your spark plug and try to pull over. if it still won't turn over then you will have to decarbon your head or you have vapor lock so then with plug removed pull recoil and if fuel sprays out of plug hole keep pulling over until there is no more spray from hole. clean plug off. reinstall and try starting
Oct 14, 2014 | Echo Garden
Echo Chainsaw keeps cutting off
does it start and run for a min or two then die try and remove the muffler and run it if ok open the muffler and clean the screen off
May 25, 2012 | Echo Garden
Can't pull the starter cord, it's very hard to do. Removed spark plug and then the pull cord worked fine. Put the spark plug bvack in and once again the starter pull cord was hard to pull. Seems...
Hi and welcome to FixYa, I am Kelly
Remove the muffler and clean out the exhaust port and screen. You will have to disassemble the muffler and clean off or replace the screen item 8 of this link:
http://www.partstree.com/parts/?lc=echo&mn=CS-330T++S%2FN%3A+C08611001001+-+C08611999999&dn=7946
Before taking the muffler apart... unhook the spark plug and just pull it though with the muffler removed. If it pulls normally you know you have found the problem.
If it still pulls hard...check the exhaust port of the cylinder head for 2 tiny holes (not screw holes) Some have them some don't depending upon the year of the saw. If you do find 2 small holes that appear clogged with carbon... do your best to clean them out.
Thanks for choosing FixYa,
Kelly
May 15, 2011 | Echo CS400 18" Chain Saw
I have a echo cs 4600 chainsaw & am having problems with starting the saw. When it sits for awhile it starts up, but when you shut it off it will not start again. I check the plug and it is wet with...
First thing to do is a new plug.Also clean the air filter.Might help?When you take the plug out.Look down the hole to see if there are any scratches on the cylinder?usually muffler side is where they will be if any.I had one doing the same thing.It was blowed up.Needed a new piston and cylinder.Hope yours don't?
Mar 06, 2011 | Echo Garden
My Echo CS starts fine but then will not accelerate. Sometimes, after it's warm, it will work OK, but more often, it acts as if the chain lock is engaged and almost wants to stall as the throttle is...
Can the chain be pulled by hand fairly easily? Check the fuel filter, air cleaner, and muffler for plugging. Inspect the fuel lines for decay or other damage. Make sure the carburetor fasteners are tight. Try turning the H jet needle CCW about 1/8 turn--the engine should 4-stroke when running free at speed, but 2-stroke when cutting. Hope this helps!
May 12, 2010 | Echo CS400 18" Chain Saw
Husqvarna chainsaw stops when using it
Check for spark after it quits. If none, the ignition module may be dying when hot. If ok, check the muffler for plugging. Use compressed air to remove sawdust from cylinder and head area. If everything looks good, note whether the spark plug is getting wet with fuel after trying to restart the saw. If dry, check the fuel lines for cracking or other deterioration. Make sure the fuel tank vent is clear of debris. (Loosen the fuel cap for a moment, then see if it will start.) Hopefully, one of these suggestions will hit on the problem!
Feb 19, 2010 | Husqvarna Chain Saw 20" Bar
I have predator and wont start
Does it have good compression? Is the muffler plugged? Is the spark plug wet after trying to start? If not, try a little starting fluid in the plug hole, and try to start. If you get a few pops, try resetting the carburetor H and L jet screws each 1-1/2 turns out from CW stops. It should run with these settings. Warm the engine up, then apply full throttle and adjust H CW until it runs fast, but 4-stroking. It should smooth out when cutting. Next, set idle L for fairly smooth idle, yet follow the throttle without lag. Adjust idle speed just below chain movement. Hope this helps.
Sep 10, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
My Echo CS 440 will not start
Pull the spark plug, dump in about half a teaspoon of fuel and try to start it. I think you have a carb problem or low compression.
Mar 21, 2009 | Echo Garden
Garden Logo
567 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
