My gaggia sycronny compact digital machine will not work anymore becuase it always claims it needs to "ventilate." I have placed the declacifier solution in and went through the declacyfying cycle and rinsing cycle over 3 times but after 1 cup of coffee it asks to ventilate again. What do I do? Please help!
Big problem, you two options, continue what you are doing or replacing the ECU. EXPENSIVE OPTION!Big problem, you two options, continue what you are doing or replacing the ECU. EXPENSIVE OPTION!
You can't post conmments that contain an email address.
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
I think you have get air in the system, try to find a bellows pump or similary. Fill it with water, open the steam knob and take of the water tank, put the pump in the water inlet and press. When the water begins to flow, close the steam knob and put the water tank back.
bad chip get if repair my friend good luck.to verify keep it unplug for some days then replug back.but since the posing of this article,you can plug it now and lets see what happens.if it does what it do again call a tech.your machine has a bad chip if it is the embbeded chip buy a new machine.good luck my friend
