Question about RCA RT2910 Theater System
The unit shut itself off and now it won't turn back on at all, I have the RCA RT2910
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on Mar 17, 2011
RCA 50: HDTV, just started shutting itself off and won't come back on for several minutes or over an hour what could cause this
My friend had the same problem. There is some display bulb that is on its way out. They aren't cheap. Find a 2nd hand TV parts/repair shop, They usually have cheap used ones from discarded units, and will know what you need!
Sep 16, 2012 | RCA Televison & Video
I have a RCA 32" Flat Screen TV that shut off and
The sound was came from the clicking of the relay. This kind of symptoms is an indication of out-of-regulation condition on the power supply section. This is caused by faulty electrolytic capacitor. It will dropped the supply voltage and will trigger that kind of symptoms.
Faulty electrolytic capacitor mostly has a physical indication of fault like bulged/dome at the top and can be easily identified. See sample picture of faulty electrolytic capacitor below.
capacitor with bulged/dome at the top.
Check these parts on the power supply section. Once found, replaced it with same capacitance and working voltage which is printed on its body itself. Click this LINK for more info regarding electrolytic capacitor.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified TV Technician to isolate the faulty parts.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 05, 2011 | RCA L32HD31 32 in. LCD HDTV
My RT2910 will not turn on, power/standby light flashes softly, and stops flashing when the power button is hits. Then starts again. My brother ran multiple excess speakers from the box and now it's...
These units aren't made for speaker experimentation. Disconnect all speakers and try again. If it doesn't come on stick a fork in it - it's done.
A hands-on tech might be able to help.
Jul 31, 2011 | RCA RT2910 Theater System
I just purchased the RCA RT2910 Theater System yesterday. When I hooked everything up, it was all working great. However, tonight when I was turned it on, all of the speakers were acting weird. They would...
What source(s)? Verify the speaker setup with the test tones to prove the hardware is all okay. Then go back and evaluate the conditions that create the problem. It could be an external cause.
Jun 01, 2011 | RCA RT2910 Theater System
We have everything hooked up to the system all in hd and nothing is working it wont turn anything on
If it won't turn on start with absolutely nothing attached but the power and see if that helps. If it does, crack the manual and add things one at a time.
May 21, 2011 | RCA RT2910 Theater System
I have a sanyo hdtv and the dvd home theater system works fine when the dvd is on but when we want to hear it with the tv it doesnt work. What can be the problem?
You would need audio input from either the TV itself (if it uses an antenna) or the actual source of the program you're watching on the Cable/Sat box as applicable. The manual covers both but I recommend the latter.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/RCA-RT2910-Home-Theater-Systems-manual/id/23699ag100/t/2/
May 19, 2011 | RCA RT2910 Theater System
I have an RCA home theatre...model rt2910. I have hooked my PS3 via HDMI to the TV for the video and used an optical cable for the audio. I set the PS3 to send video via HDMI and audio via optical cable....
You should have the HDMI plugged into the Home theater unit. The theater unit then is attached to the TV using the HDMI out.
The home theater unit passes the HDMI through to the TV while playing the audio for you.
You will likely need to select the correct source on your RT2910.
Here is a link to the manual.
http://www.1800customersupport.com/productdocuments/RT2910_RCA.pdf
See the section entitled "Connecting to HDMI Components" for an illustration of what I have described above.
Feb 28, 2011 | RCA RT2910 Theater System
I don't know how to use the remote controle to turn on the surround sound, can you tell me what button to push? My husband threw away the instructions.
You can download the manual & print it out here: http://www.retrevo.com/support/RCA-RT2910-Home-Theater-Systems-manual/id/23699ag100/t/2/
Jan 31, 2011 | RCA RT2910 Theater System
RCA RT2910 Theater System Logo
223 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
