Question about Swisher 10 Ton Hydraulic Manual Log Splitter ()
I HAVE A SWISHER LOG SPLITTER MODEL-LS722A. 22 TON 7HP. I JUST CHANGED THE HYDRAULIC FLUID AND IN THE PROCESS OF CLEANING THE CONTROL VALVE I TURNED A SET SCREW THAT WAS UNDER A BOLT ON THE TOP OF THE VALVE. I WOULD LIKE TO KNOW HOW MUCH OF A TURN IN EITHER DIRECTION SHOULD IT BE ? MODEL NO OF THE VALVE IS 7287TK. I WOULD GREATLY APPRECIATE ANY HELP OR DIAGRAMS YOU COULD SEND ME.
2 Suggested Answers
badmofo1972
  • 7 Answers
SOURCE: How do I change belt on swisher log splitter model last 8526
GO TO YOUTUBE type that in and there will be a step by step walk through. video...trust me it's easy .
Posted on Apr 28, 2016
Early '90s mtd 20 ton log splitter developed a hydraulic fluid leak where the valve assembly connects to the piston housing. Leak is between hex nut and piston body. Suggestions...
2 possible answers
hydraulic washers in use have a steel surround with a rubber insert which acts a a seal
the rubber seals off and the steel stops hydraulic pressure from pushing it out of place
or the there is a crack in the thread where the hex nut is
get a new washer from a hydraulic shop and if that doesn't fix it, you may have to get a new valve body
discuss the problem when you are at the hydraulic shop for more ideas
Dec 30, 2016 | Cars & Trucks
Wood splitter is pushing hydrolic fluid out fill tube on the return stroke
make sure that the ram is in the fully retracted position
empty oil reservoir until the oil level is at the required position normally about 1/4 inch below filler plug
if oil is added with the ram at any extension then the extra oil will be pushed back into the reservoir and over flow out
Jun 19, 2015 | Swisher 28 Ton 11.5 HP Log Splitter -...
Can i run my hydrolics at 34000rpm with a electric motor?
I think you mean 3400 RPM not 34000. The 3400 rpm electric should work if the horsepower rating is enough.
Sep 17, 2014 | Swisher 10 Ton Hydraulic Manual Log...
Splitter runs through the cycle too slow
Make sure you hydrolic fluid tank has the proper amount of fluid.
Sep 11, 2014 | Swisher 28 Ton 11.5 HP Log Splitter -...
What type of oil filter for a Huskee 22 ton log splitter with a 190cc briggs & stratton engine?
Filter #s
Fram 1653A
Napa 1553
Cross 1A9023
Baldwin BT839
Wicks 51553
Kd460, here are some crossover part#s for a replacement filter for your Speeco splitter. To answer your other question, yes hydraulic fluid will pour out when you unscrew the filter. You can drain the entire tank first in to a clean container and then re-use the oil or you can put a container under the filter and then change the filter quickly. The fluid caught by the container can then be poured back in to the unit.
If you have any questions, you can call us here at Speeco@ 800-525-8322
Thanks
Kevin from SpeeCo.
Mar 31, 2013 | Garden
I have a 4052 mcCulloch 4 ton log splitter. What kind of oil does it take for the hydraulics
Not having a mcCULLOCH manual I dont know what they reccomend,but on mine I just use HI grade industrial/commercial hydraulic fluid. I have been using this for 15 years and have had no trouble. I change oil and filter every year. Thank you.
Nov 06, 2010 | McCulloch 4 Ton Electric Log Splitter #...
Swisher 22-Ton 7 HP Log Splitter #LS722
For all swisher log splitter problems go to swisherinc.com.
Dec 10, 2008 | Garden
Swisher 10 Ton Hydraulic Manual Log Splitter () Logo
112 people viewed this question
Top Swisher Garden Experts
lnbn1975
Jim Parker
Jim Parker
Tim Whalen
Are you a Swisher Garden Expert? Answer questions, earn points and help others
