Question about Dometic Heating & Cooling
Just replaced a Comfort Control Center Part No. 3109228.001. Light comes on screen and only the leters "EE" come up. What do I need to do now. Will not respond to any commands.
  • 68 Answers
SOURCE: I have a dometic dou
The thermostat needs to be reset. Turn it off and hold the top and bottom buttons in at the same time and turn the thermostat on. In a few seconds will read FF and you should be good to go.
Posted on Mar 19, 2009
  • 127 Answers
SOURCE: What is the EE message on the DuoTherm Comfort
It means that an error has occurred. If you have a 4 button comfort control. Follow these steps to reset:
To initiate a RESET, do the following in the order
listed:
1) Turn control on to ensure annunciator data and light are present. If data and light are present, continue to next step. Depress MODE switch to activate annunciator light.
Simultaneously depress the bottom two buttons (temperature UP and DOWN) and hold.
While holding these buttons down, depress the MODE button once and release.
Release the two buttons previously held down. Depress the MODE button once again.
At this time the light should extinguish, and the mode should register “OFF”. If not, repeat these steps.
Retest system ensuring that all functions are present
and operational.
If you have the five button comfort control. Turn the unit off and hold down the mode and zone buttons together. While holding them down, turn the thermostat back on. Hold the buttons down until an FF appears on the screen. Release the buttons and the display should return to normal. If not, try it again.
Posted on Jul 04, 2009
  • 127 Answers
SOURCE: comfort control center not working properly
You need to check the cable that connects the Comfort Control to the upper unit. This cable has four wires and should have continuity through all wires. If there is a break in one of the wires or a short, it will cause the CCC to fail and report an error. If all this is fine, then you have a bad control unit in the main unit. Try unplugging the rear unit from the control board and then resetting the Tstat, if this works, then there is a communication problem between the front AC control board and the rear AC control board or the rear control board is bad. Check the cable between the front and rear AC for OK. If it is alright, then you have a bad control unit in the front unit.
Another quick check is to remove the inner shroud from the front unit pull down the control box. Remove the access cover and view the dip switch panel located inside. It should be labeled Zone 1 Zone 2 etc...try turning off Zone 2 and furnace and resetting the tstat. If this works then turn zone 2 on and reset the tstat. If this is ok, then turn the furnace on and reset again. If this works, then all should be ok. If one of these fails, then you can pinpoint the problem there and move forward.
Hope this helps,
Jeff
Rate me please!!!
Posted on Jul 05, 2009
hvac1960
  • 2133 Answers
SOURCE: WHAT DOES EE MEAN ON A DOMETIC COMFORT CONTROL
EE- High Pressure problem.
Posted on Jan 02, 2011
  • 910 Answers
SOURCE: We just installed a brand
Not quite sure what you mean by flipped and spliced the wire? Whats the Make & Model?
Posted on Jun 14, 2011
Flashing code ee
sounds like defective t-stat or it needs to have time and setpoints reconfigured
Sep 18, 2013 | Dometic 3109228.001 Duo Therm Comfort...
Comfort curve keyboard 2000
Have you tried my solution for keys not working here?:
http://www.fixya.com/support/t3015431-microsoft_comfort_curve_2000_v_1_key
Mine is toward the bottom, with the video
Good Luck
Jan 07, 2013 | Microsoft Comfort Curve 2000 Keyboard
Good morning--my Comfort Aire dehumidifier will no longer run & is still under warranty. When I turn it on the red light just comes on.
May be power supply failure, faulty control panel or other problem. It may just need to be left unplugged overnight for reset.
Aug 27, 2009 | Comfort-Aire BHD-301 Dehumidifier
Comfort control center not working properly
Hope this helps,
Jeff
Rate me please!!!
Jul 04, 2009 | Dometic Rooftop RV Air Conditioner
What is the EE message on the DuoTherm Comfort Control Center?
listed:
and operational.
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
There appears to be a problem with the thermostat/control panel. It won't turn on/off with out removing power. Once turned on, cannot adjust temp or mode or anything.
What type of Thermostat is this? If it is a Comfort Control Center, four or five button, then turn off the thermostat, hold down the mode and zone buttons at the same time and turn the tstat back on. When EE appears on the screen, then release the button and see if it begins to work. If not, then we need to check the control unit in the AC. Hopefully it is just a simple reset.
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
I have a dometic dou therm roof mount a/c model number 59136.331 with a comfort control center 3109228.001. I get an error code ee and have no information as to what this code is this is the only thing...
Jan 11, 2009 | Heating & Cooling
RV Dometic AC Comfort Control Double EE Problem
I have a dometic duo-therm. The unit works great and fan blows strong and both high and low work., but air is coming out of the ceiling unit rather than the duct work. The bedroom unit works OK, but the air is strong out of one duct, and not much comes out of the others. The front unit only has air coming out on the A/C unit and none out of the ducts.
Mar 24, 2008 | Dometic Rooftop RV Air Conditioner
Comfort aire A/C Rads 101-A EE light
Possible faulty control electronics. Call a repairman.
May 28, 2007 | Comfort-Aire RADS-151 Air Conditioner
Heating & Cooling Logo
117 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
