Question about LG RH1999H DVD Recorder/HDD Recorder
How can I copy all HDD's data in LG HDD/DVD Recoder RH1888HS by my computer or Laptop?
  • 1,591 Answers
If the unit is under warranty...DON'T DO THIS.
open up the unit and remove the hard disk.
If you have a desktop, connect the drive like you would any other hard disk.
If the drive does NOT show up under My Compujter, then the format is proprietary, and all you can do is back up the drive with a program like Acronis True Image (you must have more free space on your hard disk than the DVR's drive size...if the DVR has a 500G hard disk, you need 500G of free space on your desktop drive).
If the drive DOES show up with a drive letter under Computer, then create a directory on the C drive and simply drag and drop all the files from the DVR hard disk (E: or whatever it makes itself) to this folder. The files may still be in a proprietary format and unplayable though.
If you are trying to play the files on the computer, I suggest using VLC player. It plays almost everything in the universe.
Posted on Mar 17, 2011
  • Kenny Dec 02, 2011
    If the raw hard drive (such as from a LG plasma TV with inbuilt PVR hard drive) shows up unallocated space in acronis true image, then you might need to try something like Roadkill RawCopy. I have used RawCopy to copy a good hard drive from a LG 50PB2DR plasma tv, but have not yet tried hooking up the 'cloned' hard drive to the LG tv. Hopefully the clone works so that at least it is a way to 'backup' the recorded video from the original drive. LG is somewhat bad for not showing the public how to get recorded video content off the inbuilt PVR hard drives.
    Just wanted to confirm that the Roadkill RawCopy software successfully cloned the hard drive from my LG 50PB2DR plasma TV. I fitted the cloned drive inside the TV (SATA connection) and all the video contents showed up and played properly. This at least allows the video contents of the original to be stored for safe keeping. This isn't the same as transferring files from the PVR hard drive to a PC, but it is at least a method of 'backing up' the video content for cases where you don't have a way to transfer individual video files, or if you don't have a way to read proprietry file types. The only issue now is - what happens when my LG plasma TV breaks down? In that case, I wouldn't be able to view the video contents anymore from the inbuilt PVR hard drive. So thanks (or rather - no thanks) to LG on that possible issue. So hopefully we get a good samaritan out there that will one day provide a method to export LG video data from PVR hard drives to some well-known video format that can be played back on a computer etc.
    New Friend:
Clonezilla onto a new drive. Don't pfaff about with commercial software. Don't forget to set one jumper to Master & one to Slave and revert afterwards.
Posted on Nov 26, 2012
Please wait
Posted on May 10, 2011
HP Pavilion G7 laptop with windows 10 will not boot after taking apart to fix hinge. How can I access the data on the HDD ?
G7 2270us
it's 2012 pc
one of 3 cables you pulled during the hinge change
killed it. all are fragile and take skills to use.
they have locks and can be broken easy, ask how.
backing up has many paths.
ill list them all are covered online zillions if sites.
1: to the cloud oops PC dead,cant.
2: thumb USB drive, cant. dead.
3: to DVD or CD burner , cant. dead.
4, move HDD to other PC direct.
5: MOVE HDD TO OTHER pc INDIRECT usb.
6: MOVE HDD To a nice, hdd 2.5" external USB chassis.
#4 is the most easy, dead pc. G7
you are attempting to use 5.
and id bet that USB adapter does not support VISTA.
VISTA is dead now, for 1 full year.
VISTA has drivers of old things,
IS your vista online, it must be or it cant get to 99% of the plug and play drivers at MS.com.
ok, is it online? means web connected this VISTA PC.
if you plug in that new USB device, to vista
it needs to get a driver from Microsoft driver servers. and they dont have new drivers there now.
for all new USB things, and that is becuaSE
ms DOES NOT SUPPORT VISTA NOW.
SO WHY NOT USE W7./8/10 MACHINE TO DO THAT
AND BE Web connected
or do method 4 above and only costs $2 for Sata CABLE. DIRECT.?
Mar 30, 2018 | HP Computers & Internet
Backup hdd to external hd
DVD recorders are usually not the first selection for backup of data files. you may be better off with a 1 Tbyte external drive, which is suited for that purpose. Even though the DVD drive has the capacity, there are usually formatting issues with data files being burned to a DVD recorder.
May 19, 2012 | LG Computers & Internet
LG RHT498H recorder will not recognise new dvd discs to record to could you help me with this problem
i want to copy from the hdd to dvd but what i want to copy is to long for one dvd at good quality can i record to more than one disk. lester
Jan 27, 2011 | LG RH177 DVD Recorder/HDD Recorder
I Have a 1999 Sanyo DVD Recoder that will not read movies I burn from my Laptop Why is this so?
Well here is the resolution for your problem.
Well that happen so because your Sanyo DVD Player/Recoder is not compatible with the video format you burn it from your laptop so first of all go through the manual of your Sanyo DVD Recoder and find out what kinda video format's are really compatible with it.
Than after burn the CD in that format from your Laptop. It will work.
If you still have any more quarries regarding to it please write back to me.
Naiven.
May 27, 2010 | Televison & Video
I have an LG 2.5inch External HDD HXD2 320GB drive. I connected it to my desktop running VISTA. The HDD icon appeared when in inserted the USB connector. I attempted to copy a large group of files (80GB)...
My lg external HDD 2.5 inches does not let me in. Gives me a message that it is corrupted. My problem is how can I get my money back because I do not trust that thing any more.
Alfredo Lavagnino
lavagnino.alfredo@gmail.com
Mar 15, 2010 | LG Computers & Internet
I own a lg rh399h dvd recorder. I have finally figured out how to record from dvd to hdd, but it records in real time (slowly). Does anyone know how to :fast copy'' from dvd to hdd???
LG HDD/DVD RECORDER RH399H
Insert an empty DVD + R. The system asks whether to format - Format.
Select a recording on the HDD to copy to DVD.
Enter
Select dubbing
with arrows select type of recording to make (XP, SP, EP etc)
The system show the duration you can copy to you DVD. If small enough the FAST option also appears.
If big copies while playing the orriginal (I.e. playback speed)
Aug 28, 2009 | Audio Players & Recorders
Can I copy vcr tapes with the LG RH 1999H dvd/hdd recorder?
I use the av2 input in the front of the recorder to copy my vcr tapes to the hard drive
Apr 27, 2009 | LG RH1999H DVD Recorder/HDD Recorder
Home video on pc from digital camera, want to burn onto dvd disc?
You can buy a USB-HDD unit and use it to copy over all your files, program files, documents, including JPG video. You can then copy them to the laptop. The unit is also a good way to backup your computer files in case it crashes and you don't loose all your data. Good Luck, RAC
Apr 08, 2009 | Dell Dimension 2400 PC Desktop
Question about LG RH9509W
yes you can, first you have to connect that HDD to your computer and transfer all u wanna, and your done!
Mar 11, 2009 | LG RH177 DVD Recorder/HDD Recorder
RH1888HS /hdddvd
what you need to do is open the unit carefully remove the dvd loader, open it and gently clean the laser with a clean cotton tip, if that doesnt fix the problem you need to replace the units dvd loader. part number found on white or yellow sticker on dvd loader. hope this helps.
Dec 20, 2008 | LG RH1999H DVD Recorder/HDD Recorder
LG RH1999H DVD Recorder/HDD Recorder Logo
2,652 people viewed this question
Computer Repairing
Computer Repairing
