Changed the toner but the same image that's on top print light at the middle of the page, why?
    Master:
  • 325 Answers
Drum kit requires changing
Posted on Mar 17, 2011
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Prints over its self down center of page. Whats printed on sheet in middle of page is lightly printed again and again every 2 to 3 inches down the page.
If it is jjust one color. Replace that toner since the wiper blade is not working. If it any or all colors try taking out the fuser and seeing if the image is laft on it. The fuser is under the top panel.
Dec 16, 2009 | HP LaserJet 4350TN Printer
Phaser 7300 - one color fading on diagnostics page
Are you using third party toner? That is one thing that causes that problem. Use only xerox toner.
The other thing is that your image unit could have come defected, if it was brand new. Try changing the image unit and that should fix that problem. Good luck. 016-1993-00 image unit & toner 016-1977-00
Oct 02, 2009 | Xerox Phaser 7300DN Laser Printer
Changed toner cart. do to void in middle of print
My whole day, today, was filled with dealing with bad toner carts.
Even new genuine ones from HP
6 service calls., 6 bad carts.
Aug 19, 2009 | HP LaserJet 5p Printer
I replaced toner and now light print
you need to replace the K pcu and if the unit has 60K prints all of the consumables need replacing CMYK drums CMYK Developers and the imaging transfer belt and fuser unit
Jul 08, 2009 | Ricoh Aficio CL3500N Laser Printer
Previous image repeats on next page
The problem is likely the fusing assm.
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Hope this helps
Mar 24, 2009 | HP LaserJet 4200tn Printer
A white strip in the middle of a printed page
You should first try a new toner. Ther may be something stuck inside the toner cartridge. You might also try cleaning out the inside to be sure there isn't something blocking the light flow. If it still continues to happen there may be a problem with the fuser unit.
Dec 13, 2008 | HP LaserJet 1022 Printer
Toner splatter and faint double image
replace the toner cartridge or get the cartridge refilled as its about to empty .
Dec 09, 2008 | HP LaserJet 1020 Printer
HP LaserJet 1012 Printer prints ghost images
I ran the hp toolbox "cleaning" mode too and it did not help the problem at all. I still have a dark smear concentrated in the middle of the page, and ghost images repeated lighter all the way down the page.
Aug 21, 2008 | HP LaserJet 1012 Printer
Ghost images
Is it from the most recently printed page, or is it the same image avery time regardless of what you print? It sounds like your drum or roller (I'm not sure about the exqact term in english) might be the issue. Have you somehow managed to "force" a printing without paper in the printer?
May 18, 2007 | HP LaserJet 4 plus Printer
k24674
jasbo
jasbo
