Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
I use epson stylus tx100, why the power is steady blinking and the lights in ink?
SOURCE: Installing Ink Cartridges
I have a similar problem. I can get the print head into the appropriate position by using the ink cartridge replacement utility in the maintenance tab of the printer properties dialog.
Posted on Oct 30, 2008
aicaxz
  • 511 Answers
SOURCE: EPSON tx100 refuses to print - ink light on
ink light on? Check status monitor. Usually after jammed paper, printer trouble to recognized ink. Do change ink tank procedure, unplug and plug again ink tank.
Posted on Jun 13, 2009
  • 5 Answers
SOURCE: Epson Tx100 does not recognize my ink!
there is a chip re-setter located just above the cartridges. it is actually a small button switch. if that does not work, try to remove the cartridges. just lift them (1 by 1) slightly then put it back again
Posted on Aug 21, 2009
asabur
  • 102 Answers
SOURCE: my epson stylus C43UX not printing and showing red
you need to download "indoreset" website a adjustment program of this printer.
need to clean waste pad counter
Posted on Jan 09, 2010
cns assoc
  • 677 Answers
SOURCE: Epson TX100 won't recognise ink cartridges.
Yes, Genuine Ink Cartridges.
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Feb 05, 2010
Testimonial: "Thanks for your help. I have started using generic cartridges as I did with my Canon for years. Your help is much appreciated."
Print head doesn;t move at all in epson stylus tx100
Anon, epson stylus tx100 print head doesn't move when turned on.
epson printer problems
Feb 08, 2014 | Epson TX100 Series
I have an Epsom TX100, it has run out of black ink. I have replaced it with a 91N cartridge, but it is saying it is not compatible.
Hi leona_sha321,
TX100 doesn't use 91N ink cartridges that was why it is saying that it is not compatible. below are the list of inks for your TX100
T0731 73N - black
T0732 73N - cyan
T0733 73N - magenta
T0734 73N - yellow
Thank you. hope this helps
Janc30
Feb 08, 2011 | Epson Stylus C46 InkJet Printer
There's a general problem to my Epson TX100. the two orange light is blinking. What should I do? Do I have to reset my printer? What software should I use?
You have to reset your printer. Go to this link to download the program.
http://www.ngedownload.com/epson-tx100-resetter-wast-ink-pad-full.htm
NOTE: you have to replace the waste ink pad inside your printer to prevent flooding of waste ink.
Jan 19, 2010 | Epson Stylus NX400 InkJet Printer
All in one epson stylus tx100 installer
You can find the necessary drivers that you'll need for the TX100 on Epson's website. I've included the link for you below. Hope it helps!
TX100
Sep 29, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus TX100 printer Woeks but scanner not
It is a scanner as well, but you have to access the scanner through the software that came with it
Aug 27, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Aug 13, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Jun 13, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
564 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
