Question about Coleman Electrical Supplies
Need replacement for gas cap on a coleman generator. this is a cap with a primer on the top.
    President:
  • 1,796 Answers
Hi!
Click on the following link to get a parts catalog for your particular generator model http://arkansas-ope.com/COLEMAN_POWERMATE_GENERATOR_IPLS_LISTING.html copy and then go to this site and paste the part No. http://www.arkansas-ope.com/POWERMATE_GENERATOR_PARTS.html ' order your part.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Mar 17, 2011
My coleman 2500 powermate generater leak from top of carburater, help
The carburetor needs to be rebuilt - the float valve is stuck open.
Jul 05, 2014 | Coleman Powermate Portable Generator...
Coleman 1000 generator primer button
It will not due to the fact it is sucking air into the fuel stream, it needs to be fixed to make it work and of course leaking fuel isn't safe
Nov 09, 2012 | Coleman Electrical Supplies
Generator will not start unless you spray etatr in carbuator, and then it quits and there is fuel in tank.
Read your posting. Either the carb needs cleaning or the bolts holding it to the motor frame need tightening. If they are loose the carb will **** air and not gas. In that case, the spray will start the engine only and will stop when that primer substance burns out, usually a second or two. Bill...
Jun 27, 2012 | Coleman Powermate Powermate 5000W...
Gas leaks out of the vent hole in the top of the gas cap when running.
I am having the same problem with my 1850 as well. I borrowed the cap off my lawn mower but the vibration was still pushing gas out of the top of it as well. I cut out a thick piece of rubber and put it inside the cap, that sealed the leak but now the engine dies after about 5 mins of running. I suspect that the cap is now too tight and that it is creating a vacuum in the tank. I am going to call Coleman tomorrow to see about getting a proper replacement cap, which I hear are available.
Dec 14, 2010 | Coleman Sport 1850 Generator
Is there a gas filter on coleman 5000? runs until hot then shuts off
There is somewhat of a filter inside the tank, however your issue could be air lock or faulty oil sensor. Try running the generator with gas cap loose to allow more air into the tank. If cap is fault try to clean cap vent ports with carb cleaner or just replace the cap. If not fuel lock, remove wire from oil sensor and test again.
Nov 04, 2010 | Coleman Powermate Powermate 5000W...
I have a Coleman generator 1850 pulse and it runs ok for a little
Gravity feed fuel systems are the most simple and reliable way to deliver fuel to the engine, however suffer from a couple of problems.. As the engine heats up fuel tends to be pushed out of the carb back into the fuel tank and if the vent in the gas cap is not working properly fuel lock (or a slight vacuum in the tank) will prevent fuel from entering the carb. There should be a plastic block or manafold seperating the carb from the engine to keep the carb from overheating. Some engines have this block bolted to the engine, then the carb bolted to block., others have two bolts thru the carb and block to engine. In ether case make sure parts are held tightly together so no vacuum leaks thru gaskets.. One should make sure that the gas cap is venting. Sometimes fuel sloshing in the tank will clog the vent-hole in the cap. Try running the generator with the cap loose to see if this helps.. Replace fuel cap as needed if vent is clogged. Good luck with your generator.
Jul 29, 2010 | Coleman Sport 1850 Generator
Electrical Supplies Logo
240 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
