Question about Hotpoint Ultima WF860 Front Load Washer
Is there a filter to be cleaned on washing machine hotpoint wt 960
    Brigadier General:
  • 6,277 Answers
I think you will find that there are filters on all washing machines- to stop all manner of 'foreign' objects jamming the drain motor impeller blades!
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 17, 2011
Getting F-02 error code
wt-960 1600spin washing machine show error code f-12 each time
you switch on
Jul 21, 2014 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint Ultima WMD 960 displays "F04" on the display panel before the programme ends. Have cleaned the filter and it worked OK in spin mode and finished normally but now have put in a washing load, it...
Error code F04 means pressure switch jammed on empty.
Do the following.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside the hose.
Remove the hose on to the pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint wt 960 washer doesnt spin towards end
Error code F02 is indicating a motor tacho problem, it could be jammed or have become detached.
Check all connections on motor, plug motor lead , and the control module.
Hope this helps,
Dec 17, 2009 | Washing Machines
F-02 fault is showing on front panel. ultima wt 960.
motor jammed
no tachometrer reading
could be a bad motor
or a bad cntrol
Oct 08, 2009 | Hotpoint Ultima WF860 Front Load Washer
Our washing machine will not pump out and we have lost the manual
it should be at the back of the machine were the pipe for dirty water comes out there is a panel you can take off at the bottom of the machine when it is off you should see the moter and the pump were the pump is you and take off the black sump asmbaly and the filter should be there. hope this helps.
Mar 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Cant find filter on my hotpoint Ultima
Good luck. All modern washers that I know dont have the filter you need. If a clean out is needed you will have to clean out the pump.
Jan 26, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima super silent wash wt 960
i rang the service engineer and they looked up the code, it was something to do with overheating, they are sending someone to fix it soon!
Dec 26, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WMA30P
abi29
if you're looking for the lint filter, it's at the bottom where the door closes.
Mar 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
96 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
