Need a contraol manual for a zanussi jetstream
    Brigadier General:
  • 6,277 Answers
Sorry but this forum does not supply any type of manual or schematic diagram direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Posted on Mar 17, 2011
Spin only on Zanussi Jetstream 1400
no agitation check timer and control board. but more likely culprit is the water pressure switch. Which determines water level and when machine goes into agitation mode?
Sep 26, 2014 | Zanussi Washing Machines
How much does a new PCB board cost for a Zanussi Jetstream 1600? Is it cost effective to change it?
hi if the product number is914512801 followed by 00 the electronic is £170 and has to be programmed on the machine (not do it yourself repair) . if the product number is followed by 01 the electronic is £82 and does not need programming as it is pre configured This you can do. I would look for earth faults on the heater or motor or short circuit on the pump or solonoid valves before changing the electronic . hope this helps.
Jan 20, 2011 | Zanussi FJS1225W Front Load Washer
Zanussi jetstream 1000 turbodry door remained locked this morning. Emptied machine through filter port and cleaned filter. Door opened ok. Machine will now not start any program although the power light...
the drain pump is jammed .........remove the filter at the bottom left of the machine get down and look in the hole and you will likeley find something in there if not you need a new pump
Feb 26, 2010 | Zanussi FJS1225W Front Load Washer
We have a zanussi jetstream washing machine about 5yrs old and it has started to make an terrible winning noise on spin, is it repairable or wiser to get a new machine?
From the symptoms you describe, I would conclude that the main drum bearings have failed, and zanussi spares prices being what they are , I personally would recommend repacing the washer, it will probably be cheaper in the long term.
Hope this helps you with your problem
Dec 28, 2009 | Washing Machines
Error 10 message
Hi
E10 means there is no water getting in to machine.
check water supply if ok then fault will be fill valve.
regards
Mar 07, 2009 | Zanussi ZWF1430W Front Load Washer
Opening the door
Have you tried to disconnect it from power mains for a few minutes to see if that will reset the security timer?
Dec 05, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi error code 30(model zws 1640s)jetstream time line.
Does the machine drain out water in the beginning of the process ? In case it drains out water: -Check first the filters on the inlet water line. - If problem still exist,test for 115/220V on solenoid tags. Good luck !
Aug 06, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
