I have got an electric fire Place that blows out hot air, well after about 5 mins it stops blowing out hot air and it blows out cold air, can any one help me fix it?
    Brigadier General:
  • 4,736 Answers
More than likely, the heater element is overheating and the overload switch is turning it off. It could just be a case that the heating element needs cleaning. As they do become clogged with dust and lint, because they take in cool air at floor level, heat it and send it back out. You didn't mention who the manufacturer of your electric fireplace is, but they all work just about the same way (badly, most of the time). Turn OFF the Master On/Off Switch, unplug the fireplace from the wall and leave unplugged for 12 to 15 minutes. Now, would be a good time to clean the interior, if you want to under take it. Plug the heater back in and turn the Master On/Off switch to the On position. Turn ON and set the heater control. If it returns to normal operation, the problem is solved. If the unit continues to have to be reset (if it's a Dimplex) turn the Master Switch Off, unplug the unit and contact Dimplex USA, Technical Service at 888-346-7539 for more information.
Hope this helps solve the problem.
Posted on Mar 17, 2011
How do i get my newair af 1200e portable air conditioner to stop blowing cold and warm air.
that is normal operation when thermostat setting is reached it will cycle off compressor.
Sep 09, 2015 | NewAir Heating & Cooling
2007 Toyota Yaris blowing cold air for 1 min then starts blowing hot/warm air
Vacuum leak most likely, thus not operating air blend door.
Jul 01, 2015 | AC Cars & Trucks
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
2009 Nissan Altima A/C blowing cold for 20 min. then blows hot
if the ac system is very strong and there a lot moisture in the air the a'c evaporator core will freeze up and stop air flow threw the cold core only use the recuiculation part to cool the car down about 5-10 min the turn the recuit off
Aug 22, 2012 | 2009 Nissan Altima
It blows cold air for 5 min. and the it blows cool air for 15 min. the room warms up . Why does it stops blowing cold air continuasly???? The thermostat was disconectet on purpose so it coul clow cold air...
See if you can reposition the thermister on the facing of the evaporator coils. That could be it or the thermister might be bad. They don't use copper/mercury sensing bulbs these days. They use these cheap thermisters.
May 22, 2010 | LG Heat cool Window Air Conditioner
I have a 2000 jeep cherokee sport 6 cyl. The a.c will come on and blow cold air for about 5 min. then starts to blow hot. Can't get it to stay cold. What could this be?
over pressure or high pressure in system will cause high pressure cutoff switch to go open,also poor air flow across condenser could add to the problem. When the A\C stops getting cold is the compressor still engaged and running.
Aug 23, 2009 | 2000 Jeep Cherokee
Heater is blowing cold air 1999 dodge stratus
A heater blowing cold air can be a few things. have all of these things check for proper operation to find the source of the problem.
1. Coolant level
2. Thermostat
3. Water Pump
4. Heater control valve
5. Make sure that the heater control doors are closing when you switch from hot to cold.
6.Last but not least if the climatic controls are electric it maybe at fault.
Good Luck
Dec 09, 2008 | 1999 Dodge Stratus
Heater only blows hot (well, warm) on full speed of fan
Replace the temp control on this car, it should be electrical control not cables.
Dec 03, 2008 | 2000 Ford Escort
Comp shuts off
Coils could be dirty. Compressor could be getting too hot and cutting off. Will have one fan motor that turns condenser fan and evaporator blower.
May 30, 2008 | Fedders D Chassis A6D24E7A Air Conditioner
Heating & Cooling Logo
278 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
