Question about RCA HD52W59 HDTV Projection Television
Hdtv blue screen with white strips saying A1 and unusable signal.....checked with cable provider and was told it was the tv
  • RCA Master
  • 8,617 Answers
Sounds like the small signal board has an issue. You can get replacement parts from www.tvrepairworld.com
Posted on Mar 18, 2011
I've connected my new Sony Blue-Ray Disk Player to my RCA F25645 TV via the three (Red, White, Yellow) composite cables but the screen only says "unusable signal" and will not display the Blue...
The output from the blu-ray is probably component video, where the brightness, blue and red difference signals are the three outputs. Sounds like the TV only has composite video input so won't work. Check the manuals, if you can get a composite signal from the blu-ray then your TV will display it but not high definition. A HD LCD or plasma TV is needed to show the blu-ray films in high definition.
Jan 02, 2011 | RCA F25645 25" TV
Entivoe DVD player worked fine. The next day, the tray opens, closes and the power turns on and off but the screen says only "Unusable signal", either with or without a video disc in the player. If there...
check the connection cable to the tv, unplug this an replug it to see if this helps.
if you used a cheaper HDMI cable for example the connectors are very wobbly and often make poor contact....
Aug 31, 2010 | Televison & Video
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
May 21, 2010 | RCA TruFlat 27F520T 27" TV
Samsung LN22C350D1D FACTORY SETTINGS??
1. Do what you did, enter to service mode, and reset to factory default.
2. Use the component cable (green, blue, red, white, red) connect your set top box to the TV’s component input.
May 10, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Losing picture when screen shows a white background
Try switching to a different cable provider. I have had many problems with their a/v boxes in the past and have found they aren't very compatible with most newer tv's. Time Warner/Comcast boxes have worked great for me.
Also, don't listen to the electronics stores, they are just out to make money, although it may fix your problem, it is unnecessary.
Check your tv's manual for settings that may fix that problem, like "source refresh time" or anything to do with signal loss and refresh rates.
For more info, contact me.
Thanks for asking!
-Josh
Feb 26, 2010 | Mitsubishi WD-Y65 65" HDTV
Why does it say no signal with a blue screen
Assumtions, but you should check:
Make sure the cable/antenna is attached properly
If you have a cable service, make sure it's active.
On initial power up, use the menu to navigate to the input selection screen, and choose the correct option for your application. Also worth noting is that there is a second menu page where you select cable or antenna. Check that too.
Please post your findings.
Thanks.
Joe
Dec 12, 2009 | Vizio L32 32 in. LCD HDTV
Screen says no signal. when i push the input button,tv says no signal not available Stuck on the blue screen, there is NO lock icon on the screen. I have the same problem. I attached the cable from my...
HD TVs do have different cables, I went to Time Warner and swapped my regular box for an HD box, the cable ends are blue red and white, I believe. Also in order for my box to work on the screen I have to switch to "Component" instead of "TV". Hope I helped!
Dec 11, 2008 | Haier HL22R 22 in. LCD TV
Blue screen
first , auto program you tv ,if still the same , your tv need to re solder. if you know how to solder,. Solder the tuner the jungle ic and system ic, but be careful of short circuit.
Oct 29, 2008 | RCA F32650 32" TV
Unusable signal
Could be a bad buffer/amp or bad tuner, depending on source selected....accordianman
Dec 08, 2007 | RCA Scenium D40W20 40" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
37 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
