Question about Schwinn Mesa Gs Mountain Bike
We have a sidewinder 2.6 and the pedals are loose. So the company sent us a bottom bracket to install. But how do we get the assembly apart to install new part
  • 1,915 Answers
Most bottom brackets require a special tool to remove them without damaging them. Unless you are going to do a lot of bicycle repairs your best bet would be to take the bike and part to a shop and have an expert do it for you. That type of service should not cost much.
Posted on Mar 17, 2011
2008 dts caddy blower motor resister location
Your not going to like to hear this , but you'll need to take the dash apart !
Blower Motor Resistor Replacement
Preliminary Procedure
  1. Remove the HVAC module. Refer to HVAC Module Assembly Replacement .
  1. Drain the cooling system. Refer to Cooling System Draining and Filling .
  2. Recover the refrigerant. Refer to Refrigerant Recovery and Recharging .
  3. Remove the evaporator tube from the thermal expansion valve. Refer to Air Conditioning Evaporator Hose Assembly Replacement .
  4. Remove the heater hoses from the heater core. Refer to Heater Hoses Replacement .
  5. Remove the brake pedal bracket assembly. Refer to Brake Pedal Assembly Replacement .
  6. Pull back and reposition the carpet.
  7. Remove the lower instrument panel (I/P) support brace. Refer to Instrument Panel Center Support Bracket Replacement .
  8. Reposition the auxiliary air distribution duct. Refer to Auxiliary Air Distributor Duct Replacement .
  9. Remove the instrument panel carrier. Refer to Instrument Panel Carrier Replacement .
  10. Disconnect the HVAC module assembly electrical connectors.
HVAC Module Assembly Nut (Qty: 5)
Tip
Tighten the nuts in sequence.
Tighten
9 N?·m (80 lb in)
HVAC Assembly Module
Disconnect the blower motor resistor electrical connector.
Jul 28, 2016 | 2008 Cadillac Dts
A squeak in my bike
Tyler lubricate bicycles chain, pedal bearings and pedal crank.
Check the attached links to see how some cranks come apart to lube,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Bottom Bracket Inspect clean and lube
How To Overhaul Bike Bottom Bracket With One Piece Crank
How to Take Apart and Service the Bottom Bracket on Bicycle
Sealed cartridge Bottom Bracket crankset and pedal removal installation...
May 02, 2016 | Norco Cycling
I need the exact location of the break light switch on a 92 labaron 2.5
The brake light switch is mounted to the brake pedal bracket assembly, under the instrument panel. The stop lamp switch attached to the mounting bracket.
  1. Disconnect the negative battery cable.
  2. Unplug the two brake switch wiring harness connectors.
  3. Remove the wiring harness for the switch from the clip on the brake pedal bracket assembly. Remove the nut and washer from the switch and bracket assembly stud and remove the switch and bracket assembly. To install:
  1. Position the switch and bracket assembly to the brake pedal bracket assembly, then install the nut and lockwasher. Tighten the retaining nut for the bracket until finger-tight (loose enough to allow movement of the bracket).
  2. Attach the electrical wiring harness connectors and route the wire through the retainer clip.
  3. Push the switch forward (toward the front of the vehicle) as far as it will go (this will cause the brake pedal to move forward slightly).
  4. Gently pull backward (toward the rear of the vehicle) on the brake pedal until the pedal lever rests against the its stop. This will ratchet the switch back to its properly adjusted position.
  5. Tighten the switch and bracket assembly mounting bracket nut securely.
See fig for more detail:-- helpmech_9.gif
-------------- This should help.Thanks.Helpmech.
Jan 12, 2011 | 1992 Chrysler Lebaron
How to remove a heator core from a 2001 dodge caravan? do you have to take the dash out? or just the bottom pannel.
The 2001 Dodge caravan has 2 heater cores - front (the main one), and the rear. Removal of the
rear heater core is a whole different procedure than the front.
Front Heater Core - Removal and Installation
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Align the wheels in the straight-ahead position.
  3. Disconnect the negative battery cable.
    CAUTION Before working around the steering wheel or the instrument panel all 2 minutes to pass to allow the air bag module to discharge.
  4. Drain the cooling system into a clean container for reuse.
  5. Remove the steering column, by removing or disconnect the following:
    Lower left side steering column cover Parking brake release cable from the parking brake lever 10 steering column cover liner-to-instrument panel bolts and the cover liner
  6. Rotate the key to the LOCK position; then, rotate the steering wheel to the LOCKED position.
    Gear selector cable and its mounting bracket as an assembly from the upper steering column mounting bracket 2 instrument cluster trim bezel-to-instrument panel screws, retaining clips and bezel 2 steering column shroud-to-steering column screws and the shroud Steering column-to-intermediate steering shaft coupler
  7. Loosen but do not remove the 2 lower steering column mounting bracket nuts/washers.
    2 upper steering column mounting bracket nuts/washers Steering column assembly from the vehicle
  8. Remove or disconnect the following:
    Instrument panel-to-chassis harness interconnect and bracket Lower silencer boot, at the base of the steering shaft
  9. Working in the engine compartment, pinch off the heater hoses.
    Heater core cover. Position some towels under the heater core hoses. Heater core plate and the hoses
  10. Depress the heater core retaining clips.
  11. Lift the accelerator pedal and slide the heater core past it.
  12. Depress the brake pedal and remove the heater core from the heater/air conditioning housing assembly.
    Fig. View of the steering column assembly
    Fig. View of the interconnect and bracket
    Fig. View of the front heater core assembly
To install:
  1. Depress the brake pedal and install the heater core into the heater/air conditioning housing assembly.
  2. Lift the accelerator pedal and slide the heater core past it.
  3. Install or connect the following:
    Heater hoses (using new O-rings) and the heater core plate Heater core cover Heater hoses clamps, working in the engine compartment Lower silencer boot at the base of the steering shaft Instrument panel-to-chassis harness interconnect and bracket
  4. Install the steering column assembly by installing or connect the following:
    Steering column assembly, carefully into the vehicle. 2 upper and 2 lower steering column mounting bracket nuts/washers. Torque the nuts to 105 inch lbs. (12 Nm). Steering column-to-intermediate steering shaft coupler and tighten the pinch bolt to 21 ft. lbs. (28 Nm) 2 steering column shroud and the shroud-to-steering column screws Bezel, the retaining clips and the 2 instrument cluster trim bezel-to-instrument panel screws Gear selector cable and its mounting bracket as an assembly to the upper steering column mounting bracket 10 steering column cover liner and the cover liner-to-instrument panel bolts Parking brake release cable to the parking brake lever Lower left side steering column cover. Lower left side steering column cover
  5. Refill the cooling system.
  6. Connect the negative battery cable.
  7. Run the engine to normal operating temperatures; then, check the climate control operation and check for leaks.
Jan 02, 2011 | 2001 Dodge Caravan
How to adjust clutch pedal on 86 mustang lx
clutch is supposed to be self adjusting. Here are instructions for replacing the adjuster:
REMOVAL & INSTALLATION
See Figure 1
  1. Disconnect the battery cable from the negative terminal of the battery.
  2. Remove the steering wheel using a steering wheel puller, Tool T67L-3600-A or equivalent.
  3. Remove the lower dash panel section to the left of the steering column.
  4. Remove the shrouds from the steering column.
  5. Disconnect the brake lamp switch and the master cylinder pushrod from the brake pedal.
  6. Rotate the clutch quadrant forward and unhook the clutch cable from the quadrant. Allow the quadrant to slowly swing rearward.
  7. Remove the bolt holding the brake pedal support bracket lateral brace to the left side of the vehicle.
  8. Disconnect all electrical connectors from the steering column.
  9. Remove the 4 nuts that hold the steering column to the brake pedal support bracket and lower the steering column to the floor.
  10. Remove the 4 booster nuts that hold the brake pedal support bracket to the dash panel.
  11. Remove the bolt that holds the brake pedal support bracket to the underside of the instrument panel, and remove the brake pedal support bracket assembly from the vehicle.
  12. Remove the clutch pedal shaft nut and the clutch pedal, as outlined above.
  13. Slide the self-adjusting mechanism out of the brake pedal support bracket.
  14. Examine the self-adjusting mechanism shaft bushings on either side of the brake pedal support bracket, and replace if worn.
To install:
  1. Lubricate the self-adjusting mechanism shaft with motor oil and install the mechanism into the brake pedal support bracket.
  2. Position the quadrant towards the top of the vehicle. Align the flats on the shaft with the flats in the clutch pedal assembly, and install the retaining nuts. Tighten to 32-50 ft. lbs. (43-67 Nm).
  3. Position the brake pedal support bracket assembly beneath the instrument panel, aligning the four holes with the studs in the dash panel. Install the four nuts loosely.
  4. Install the bolt through the support bracket and into the instrument panel. Tighten to 13-25 ft. lbs. (18-34 Nm).
  5. Tighten the four booster nuts that hold the brake pedal support bracket to the dash panel to 13-25 ft. lbs. (18-34 Nm).
  6. Connect the brake lamp switch and the master cylinder pushrod to the brake pedal.
  7. Attach the clutch cable to the quadrant.
  8. Position the steering column onto the four studs in the support bracket and start the four nuts.
  9. Connect the steering column electrical connectors.
  10. Install the steering column shrouds.
  11. Install the brake pedal support lateral brace.
  12. Tighten the steering column attaching nuts to 20-37 ft. lbs. (27-50 Nm).
  13. Install the lower dash panel section.
  14. Install the steering wheel.
  15. Connect the battery cable to the negative terminal on the battery.
  16. Check the steering column for proper operation.
  17. Depress the clutch pedal several times to adjust the cable.
Sep 24, 2010 | Ford Mustang Cars & Trucks
How do you replace the front and rear brakes in a 2003 pontiac Grand Prix
Removal & Installation Front To Remove:
  1. Inspect the fluid level in the master cylinder reservoir. Remove fluid from the reservoir until the level is lower then half way between the MAX and MIN levels.
  2. Remove the tire and wheel assembly.
  3. Install 2 wheel nuts to secure the rotor on the hub.
  4. Remove the bottom brake caliper pin bolt.
  5. Pivot the brake caliper body upward and secure out of the way. Do NOT disconnect the hydraulic brake flexible hose from the caliper.
  6. Compress the piston back into the bore using a C-clamp. Figure of brake assembly with caliper raised showing brake pads in mounting bracket gmpc_l4.gif
  7. Remove the inboard and outboard brake pads from the brake caliper bracket.
To Install:
  1. Install the brake pad retainers and both brake pads into the caliper bracket.
  2. Pivot the brake caliper down over the brake pads and into the brake caliper bracket. Insert the lower brake caliper pin bolt and torque bolt to 70 ft-lb. (95 Nm).
  3. Reinstall the tire and wheel assembly.
  4. Lower the vehicle.
  5. Refill the master cylinder. Pump the brake pedal several times to seat the pads against the rotor.
  6. Check the master cylinder level and add fluid as necessary.
Rear To Remove:
  4. Remove the upper caliper mounting bolt.
  5. Pivot the caliper down to access the pads.
  6. Remove the inboard and outboard pads from the caliper bracket.
  7. Remove the brake pad clips from the caliper bracket.
  8. Compress the piston back into the bore using a C-clamp and the old inner pad.
To Install:
  1. Install new brake clips in the caliper bracket.
  2. Install the inboard and outboard pads in the caliper bracket.
  3. Pivot the caliper up over the pads.
  4. Reinstall the upper mounting bolt and tighten to 32 ft. lbs. (44 Nm).
  5. Remove the 2 wheel nuts securing the rotor.
  6. Reinstall the tire and wheel assembly.
  7. Refill the master cylinder. Pump the brake pedal several times to seat the pads against the rotor.
  8. Check the master cylinder level and add fluid as necessary.
Aug 26, 2010 | 2003 Pontiac Grand Prix
How to change front brake pads on 2003 Chevy Suburban
Disc Brake Pads for Suburban 1500 Removal & Installation Front To Remove:
  1. Remove the cover on the master cylinder and siphon out 2/3 of the fluid. This step prevents spilling fluid when the piston is pushed back into the caliper bore.
  2. Raise and support the vehicle safely.
  3. Remove the wheel and tire assembly.
  4. Compress the brake piston back into its bore using a C-clamp.
  5. Remove the 2 caliper mounting bolts. Lift the caliper off the rotor.
  6. Remove the inboard and outboard pad.
  7. Remove and discard the anti-rattle clips.
To Install:
  1. Thoroughly inspect, clean and lubricate all caliper slide points, bolts and hardware.
  2. Install new anti-rattle clips.
  3. Position the inboard and outboard pads into the support bracket
  4. With the 2 pads in position, place the caliper over the brake rotor and align the holes in the caliper with those of the mounting bracket.
  5. Install the caliper mounting bolts through the sleeves in the inboard caliper ears and into the mounting bracket.
  6. Tighten the mounting bolts to: 80 lb. ft, (110 Nm).
  7. Install the tire and wheel assembly. Lower the vehicle.
  8. Add fluid to the master cylinder reservoirs so they are 1/4 in. (6.35mm) from the top.
  9. Test the brake pedal by pumping it to obtain a hard pedal. Check the fluid level and add fluid as necessary.
Rear To Remove:
  1. Remove 2/3 of the brake fluid from the master cylinder.
  2. Raise and safely support the vehicle.
  4. Remove the brake caliper mounting bolts. Suspend the caliper from the frame with mechanic's wire. Do not allow the caliper to hang from the brake hose.
  5. Remove the brake pads from the caliper mounting bracket.
  6. Remove and discard the anti-rattle clips.
To Install:
  1. Install new anti-rattle clips.
  2. Position the brake pads to the caliper mounting bracket.
  3. With the 2 pads in position, place the caliper over the brake rotor and align the holes in the caliper with those of the mounting bracket.
  4. Install NEW caliper mounting bolts. Tighten to: 30 lb. ft, (40 Nm).
  5. Install the wheel and tire assembly.
  6. Lower the vehicle.
  7. Refill the master cylinder to the proper level with fresh brake fluid. Pump the brake pedal slowly and firmly to seat the brake pads. Burnish the brakes as needed.
Jul 05, 2010 | 2004 Chevrolet Suburban
I need a power supply for a Sidewinder Wheel and Pedals set. Where can i get one?
I would check amazon.com and ebay.com and if those don't have it I would check the company website. :)
Jun 02, 2010 | Microsoft SideWinder Force Feedback Wheel...
Schwinn Mesa Gs Mountain Bike Logo
202 people viewed this question
Top Schwinn Cycling Experts
Tony
michael
michael
jasiel murphy
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
