Question about George Foreman GGR62 Grill
Temperture knob missing - George Foreman GGR62 Grill
    Brigadier General:
  • 4,736 Answers
Please see previous solution.
Posted on Mar 17, 2011
How do you adjust the temperture
turn the knob. really, the same knob that says pilot is also a temp gauge.
Mar 14, 2015 | Water Heaters
TEMPERTURE IS OFF 25-55 DEGREES
Most have an calibration adjustment screw usually located under the oven knob. Adjust no more that 1/4 turn at a time, then check new setting.
Feb 19, 2015 | Kitchen Ranges
I need a temperture control knob for rival crockpot
I have had good luck at our local appliance parts store. Take the old knob or the slow cooker in if you have a store close. Try looking for Appliances Household Parts in the yellow pages. If you have a metric/standard tape measure, remove the knob by pulling it off, if it will come off, then measure the shaft in mm and inches and look online. Also make sure to look at the shape of the shaft, sometimes they are half moon. Best of Luck
Jan 11, 2014 | Crock Pots & Slow Cookers
2003 Lincoln Navigator, I cleaned my center console panel (AC/Heater control knobs) because of sticking buttons now the buttons (Auto, Off, Dual, etc) does turn on or off AC/Heat, nor does the display...
shudnt hav done that-u caused corrosion--now u need to take um out and see if their salvagable--getta haynes manual or sec629-ur local library
Nov 20, 2013 | Lincoln Cars & Trucks
Searching for Model Number for a
post a picture of the dryer with the door open
Dec 27, 2012 | Dryers
Temperture control knob in dash not working
most likely your heat & air control panel is at fault but possible you have vac.leak
Oct 23, 2012 | 2000 Chevrolet Blazer
The freezer is geting high temperture, it could be set down.
find the adjustment knob, set it to a desired tempreture and allow 24 hours for adjustments
Mar 02, 2011 | Electrolux 21.0 Cu. Ft. Upright Freezer -...
1989 mitsubishi galant, when engine is cold has severe miss, after reaching operating temperature miss disappears, and engine runs smooth.
manifold air temperture or intake air temperture sensor is bad . you can check the voltage on it when cold then w/hair dryer warm sensor up an check voltage if the resistance is more than 500 ohms then it is bad.
Dec 12, 2010 | 1989 Mitsubishi Galant
The oven temp is 100 degrees hotter than the set temp.
On most oven temperture controls, if you pull the knob off there is an adjustment screw down in the shaft turn counterclock wise?? to lower setting. Good luck
Nov 14, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Tappan TGF336ASD stove Calibration of the oven
does it have a knob in front or is it a panel to operate bake broil ? if it has a oven knob take it off and look in the back of the knob you adjust it there if it is electric if it is gas you need to use a small screw driver in the stem where the knob goes on and turn a little screw in there to ajust temperture turn clockwize to adjust temp up
Aug 13, 2007 | Tappan TGFS_63 Gas Kitchen Range
George Foreman GGR62 Grill Logo
21 people viewed this question
Top George Foreman Grilling Experts
Jaime Hernandez
Steven Clarke
Steven Clarke
Are you a George Foreman Grilling Expert? Answer questions, earn points and help others
