Question about SanDisk Sansa e260 MP3 Player
Frozen sansa my sandisk sansa is frozen and i tried to take the battery and put in back in. i also turned it off and held the rec. button for recovery mode. it still did not work! can you help?
Mee too!
Posted on Aug 02, 2008
Hold the on/off button and the big select button in the middle at the same time.
Posted on Aug 05, 2008
My sansa says to put it on recovery mode? can you help me?
On your Sansa player, press and hold the Power/Menu button for 15 seconds to turn the device completely off.
Slide the Hold switch so the orange portion shows.
On your PC, double-click My Computer
On your Sansa player, press and hold the REC button while connecting it to the PC.
Release the REC button when a 16MB-FORMAT drive partition appears under My Computer.
What is recovery Mode?
Recovery mode is usually done as part of a troubleshooting step in updating the fimware on a Sansa player.
Apr 05, 2010 | SanDisk Sansa e250 MP3 Player
I turn it on and the screen is white.
when that happen to me i held the power button and the middle button at the same time for like 15 sec then it turned off  try that  then turn it back on
Nov 09, 2009 | SanDisk Sansa Fuze MP3 Player
Turn on the mp3 and it said recovery needed
Download the Sansa Recovery Tool for your specific player
Then disconnect the Sansa from computer
Turn the Sansa player off
Hold in the REC button
Continue holding the REC button as you reconnect the Sansa to the computer
After 5-15 seconds, Recovery Mode should take hold.
-Tha Mp3 Doctor
Feb 18, 2009 | SanDisk Sansa e250 MP3 Player
Getting to recovery mode
You have to Download the Sansa Recovery Tool from Sandisk's website first. Then, disconnect the Sansa from the computer, press and hold in the REC button, and then reconnect the Sansa while holding the REC button.
-Tha Mp3 Doctor
Feb 15, 2009 | SanDisk Sansa e270 MP3 Player
My sansa e250 gets frozen
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + (REC button for Sansa e200 series) button, and reconnect the player to the computer while holding the volume + (REC button for Sansa e200 series) button in. Keep holding the volume + (REC button for Sansa e200 series) button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Dec 24, 2008 | SanDisk Sansa e250 MP3 Player
Frozen
Download the Sansa Recovery Tool from Sandisk's website (make sure the Sansa is not plugged into the computer yet). Once the Recovery Tool is downloaded, connect the Sansa to the computer while holding in the REC button and continue to hold it even after th player is plugged in. It should go into Recovery Mode in 10-15 seconds or so.
-Tha Mp3 Doctor
Dec 19, 2008 | SanDisk Sansa E280 MP3 Player
My Sansa 4.0 GB mp3 player keeps saying 'Not enough space for music DM. Please delete 6MB.' It won't detect any music and I have over 2GB still open, so why!?
hi you might need to run a recovery programme or update the firmware to do this then goto the sandisk website and down load the firmware onto your computer or download recovery programme ok
Once you have done this follow these instructions
1 turn mp3 off
2 slide hold/lock to on position
3 press and hold down rec button on left hand side keep held down
4 switch on whilst still holding down rec button on left hand side
5 it should now say recovery mode
once it says this then open the firmware file on your computer and follow instructions also do this if your using the recovery tool from the site.
If you have any problems then let me know ok
Apr 10, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e280 "frozen" won't turn off or respond to buttons pushed
hi could you try this for me and tell me if it goes into recovery mode or not
  1. with device off push lock button to lock position
  2. whilst in lock position hold down rec button on left hand side
  3. whilst holding rec press on button
  4. it should now say recovery mode
  5. let me know if you get this far
Feb 29, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa e250 has Refresh Database Frozen
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Please RATE my solution at the bottom.
Nov 23, 2007 | SanDisk Sansa e250 MP3 Player
Frozen?
Its easily fixed. Try this.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
Best of Luck.
Oct 14, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
55 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
