Question about HP LaserJet 1020 Printer
My hp1020 works perfectly using xp but when I try to use the hp1020 on windows 7 (32 bit) it may work briefly then it stops working.
  • HP Master
  • 1,915 Answers
Your best bet to solve this will be to do the following. Go to HP.COM and download the VISTA 32bit driver to your computer. Go to the printer folder and right click on the icon for the 1020 driver that works intermittently, select printer properties. Click the advanced tab and you will see an option next to the currrently installed driver that says "new driver". Click on this and when the install starts say have driver and point it to the file you downloaded. The Vista drivers seem to work for most printers better than the downloaded ones that Win 7 installs automatically.
Posted on Mar 17, 2011
I'm using Studio HD v14 with the Dazzle 510 USB on Windows 7 64 bit. Everything is connected correctly but I keep getting a "no signal input" when I try to capture from my television. When used...
1. the software and the device is not compatible with the Windows 7 64 bit system\
2. check updated drivers for the software and the device at the manufacturers web site.
3. You can also see if the program will work in XP mode check the helps ( windows) to see the step by step of vistit the Microsoft knowledge base for step by step instruction set.
Mar 11, 2011 | Pinnacle Dazzle DVC 90 (210100371) Video...
Need drivers to run window 7 - 64 bit
Theres no updated driver for ASUS K8V-X SE for Win 7, try downloading windows XP 64 bit for your missing drivers in win 7 it might work..
http://support.asus.com/download/download.aspx
Jan 29, 2011 | ASUS K8V-X SE Motherboard
How do i use an epson filmscan 200 with a laptop running windows 7
were you using it under windows xp? if you have 32 bit windows 7 I would try those same drivers. Unfortunately the filmscan 200 came out under windows 95/98 and so Epson never released XP drivers and some people were able to make it work.
I would consider connecting it to an older computer running windows 98 and then transfer the files as you scan them (this would definitely be the least painful)
If you have 64 bit windows 7 I would not even waste the effort, 32 bit is a long shot maybe.
Do you have scsi drivers on the the windows 7? because the filmscan 200 is a scsi 2 device
Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/thomas_b83e841f114394f4
Nov 24, 2010 | Epson FilmScan 200 Film Scanner
Can not install old version of paper port on 64 bit system
I am assuming you are using one of the newer version of windows, although you don't mention this. There is a free version of paperport you can download over the internet so you might like to try this. With windows you can install 32 bit versions of software onto 64 bit system and they will generally work fine. You should also try using "compatibility" mode which windows uses to help manage programs designed for older version of windows. I have some older software that wont work on anything other than windows XP so I have installed a virtual machine onto my 64 bit computer, then installed windows xp onto the virtual machine, and then installed the software I need to use. This is a bit tedious and time consuming but works perfectly and allows me to use my older software.
Jun 20, 2017 | Brother DCP-9000 Copier
The game is made for 32 bit system, and mine is 64 bit. what to do?
You can try and run the game in XP compatibility mode in Vista or Window 7 64 bit. run it in 32bit compatibility in XP 64bit. This is set in the icon properties.
You can also use Virtual PC or dual boot to another OD install, since the 32 bit XP can run on a 64bit system perfectly well.
It's more work but I recommend the second solution over the first. Dual booting between out productivity software and out games is unfortunately the price to pay for a good gaming experience.
Mar 24, 2010 | CDV Software Blitzkrieg for Windows
HP LaserJet 1020 Printer Logo
56 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
