Question about Hotpoint WMM75 Front Load Washer
Washer keeps tripping electric out whilst running through its cycle
    Brigadier General:
  • 6,277 Answers
Sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid as primary suspects. Secondary suspects could be main motor, drain motor.
I fear that you only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Posted on Mar 17, 2011
Fuse f21 what does it do. It keeps tripping out about every four weeks How can i fix this problem
The washer tripped the breaker once and OR after the breaker was reset it ran additional loads with no problem then it tripped the breaker again.
Intermittent problems are always difficult to diagnose because the problem usually doesn't occur when you're making the checks.
If the washer ran additional loads the problem will not be an electrical short with one of the washer parts. If the lid switch had a short it wouldn't run additional loads.
if the additional loads used the same cycle as previously. A timer can have an internal short that might trip the breaker in heavy duty cycle but not the permanent press cycle.
If you have access to a clamp on amp meter, see the image below, then you can check the amp draw of the washer. The washer normally will draw about 10-15 amps at start up and about 5-8 amps while running. The house breaker for you washer should be rated at 20 amps.
If the washer is running and drawing less than 20 amps and the breaker trips then if can be a weak house breaker.
Mid cycle the washer is most likely draining or spinning and if the bearing or pump locks up then the washer may draw additional amps to try to start and trip the breaker.
The key to this problem is what the amp draw of the washer is when the house breaker trips.
To narrow this problem down, there are three places that could be causing the ( outlet) GFCI to trip, a malfunction in the washing machine, a problem with the downstream wiring (aka load side of the GFCI-other items connected on same circuit), or the GFCI outlet itself. If there isn't anything downstream, then plugging the washing machine into another GFCI outlet, or simply swapping out the outlet for a known good GFCI outlet, will identify if the outlet itself is faulty.
If the outlet trips when the washing machine isn't running and isn't even plugged in, then there's a fault in the wiring on the load side of the GFCI outlet.
If the issue is neither of the above, then running the washing machine and monitoring to see which step is occurring when the trip happens will isolate what part of the washing machine may be leaking current to a ground. It could be a certain water level, a motor being engaged, a transition step in the controller, etc
Beware some techs believe that most Washing machines or any other motor should not be on a GFCI! Should be a dedicated single receptacle. If there are other outlets on the washer GFCI, replace that GFCI with a single receptacle and put the GFCI on the next jump in order to protect other outlets.
Another item to check is ur lid switch which may have gotten moister inside and created a short_ or broken open and the rubber seal dried out over time, and the switch assembly will be exposed. water can splash onto the assembly, somehow causing the GFCI to trip. In any event, if you are having trouble with your washing machine stopping mid-cycle for any reason, test and replacing the lid switchis probably a worthwhile idea, as it is cheap and easy to replace.
By the way my advice is free cuz God is good!
Apr 16, 2017 | Washing Machines
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
www.appliancesonlineblog.com.au/.../6-common-washing-machine-prob...
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
https://www.youtube.com/watch?v=dx2vCzO8828
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
Main fuse in house went now machine will not start light under start button keeps flashing
If the washer ran additional loads the problem will not be an electrical short with one of the washer parts. If the lid switch had a short it wouldn't run the additional loads.
You don't say if the additional loads used the same cycle as previously. A timer can have an internal short that might trip the breaker in heavy duty cycle but not the permanent press cycle.
May 17, 2015 | Washing Machines
When put on a wash it trips the electric
May 10, 2015 | Miele Washing Machines
Hi my fisher and paykel MW512 top loader washing machine keeps throwing my electrical switch. A few months ago it wouldnt drain and came up with heaps of error codes and now it is tripping my switch. What...
Mar 25, 2015 | Fisher and Paykel Washing Machines
Ground fault keeps tripping
Mar 17, 2015 | Washing Machines
Why does my washing machine trip the electric
run the machine, after it trips, unplug and carefully touch the motor,it may have a bad capacitor, or dry bearings causing it to draw excessive current,if these 2 things are not it, then look for a bare wire that may be touching case during this part of the cycle,and if you can get an "Amprobe" it reads current and check machines current draw during the start to trip current
Oct 27, 2009 | Hotpoint WMA58 Front Load Washer
Hotpoint washing machine keeps tripping electric
First unplug your washer. Check the ground on the washer and make sure it isn't loose; this would be a good time to inspect the wiring harness for any problems. Next check the outlet (turn off the electric to that breaker first) make sure all the wires are tight and are making good contact; pay special attention to the neutral (white) wire. If that seems fine, and you are comfortable with going into you breaker panel, turn off that breaker and check the hot (the wire on the breaker) to make sure it isn't loose and then check the neutral wire. If either of these wires seem loose tighten them down....a loose wire will move when a load is put on it and cause the breaker to trip. If all seems normal and washer is still tripping the breaker you might want to replace the breaker.....they can go bad. Good luck!
Aug 26, 2009 | Hotpoint Washing Machines
My aquairius hotpoint washer dryer wd62 keeps tripping electric why
Remove top cover, and unplug motor, try it, and if it does not trip, then motor is causing prob.
If it still trips, then heater is probably causing problem.
Please rate my advice.
Thanks.
Jun 01, 2009 | Hotpoint WD62 Front Load Washer / Dryer
Tripping the breaker
How far into the cycle does it trip the breaker?Does the motor run then trip it?Is it at the end of the cycle when it goes to a dry cycle?Does it trip in the beginning when it fill's up with water?
Mar 19, 2009 | Dishwashers
Hotpoint WMM75 Front Load Washer Logo
42 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
