Question about ION Audio SLIDES2PC
System cannot find ion slides2pc scanner. Driver has been installed normally. Scanner is connected in a correct way to an usb-2.0 port. What is wrong?
SOURCE: driver for umax astra 2500 usb scanner.
Driver for umax astra 2500 usb scanner.
Posted on Sep 24, 2008
SOURCE: UMAX Scanner Astra 3600 usb Driver Windows 98SE/ME/2000/XP
Dear,
I want to install for umax astra 3600 uap scaner driver
but i can't instalation for online download
so kinly requested for you plz tell us how can possible
plz. reply must
Posted on Oct 31, 2008
acdr
  • 1913 Answers
SOURCE: driver of plustek 1200dpi usb scanner
http://www.opendrivers.com/driver/214323/plustek-opticpro-96000t-12000t-scanner-driver-windows-9x-me-nt-free-download.html
download from here.
Posted on Mar 24, 2009
preachw996
  • 1179 Answers
SOURCE: need vista operating system driver 1200 UB Plus USB Port Scanner
According to the manufacturer this product is not compatible with Windows Vista. There are no drivers available for this reason. Sorry.
Posted on Jun 03, 2009
  • 109 Answers
SOURCE: cant use Umax Astra 4100 usb scanner with Windows Vista
its probly too old and must be replaced alot of manufatures never made vista driver for there older end of life equipment scanners are dirt cheap now invest in a new one because you will have this problem again!
Posted on Aug 29, 2009
Problem with SLIDES2PC
I think there is a buffer that has to be cleared after so many pictues ie processed.
Dec 14, 2011 | ION Audio SLIDES2PC
Hi, I can't get my scanner conected, it was conected, turned it off ,now can't get it to work. ion PIC2pc. Thanks Nan
Hello.
Be certain that you followed the step-by-step instructions (From ION Support):
1. Turn on the computer.
2. Insert the installation CD into the CDROM
drive and the installation menu will appear. *
3. When you see the installation menu, click Install Driver.
4. Follow the on-screen instructions.
5. When the driver installation is complete, click BlazePhoto to install the software.
6. Follow the on-screen instructions.
7. If your computer does not have DirectX 9.0 or greater or Adobe Reader, click those items to install them. (If your
computer is using Windows XP Service Pack 2 or higher, Windows Vista, or Windows XP Professional, this is not
necessary.)
8. Click Exit to close the window.
Note: The first time you connect PICS 2 PC to your computer, wait a few seconds until you see a dialog box
that says "Found New Hardware" (this means the computer recognizes the PICS 2 PC). After you see this,
PICS 2 PC is ready to use.
If you followed the above instruction and still have a problem, reinstall (first, Remove from Add/Remove Programs) the software and be certain that the USB cable is snug.
If your computer is not recognizing the ION PIC2, be certain that your computer has a USB 2.0 port. Check your Device Manager to verify what USB port.
If still a problem, what error message(s) are you getting ? What operating system software (Vista, Windows 7, etc.) ?
Hope this helps.
Jun 28, 2011 | Office Equipment & Supplies
I cannot install the above mentioned scanner since the driver is unspecified
IF IT IS USB BARCODE SCANNER, DO THESE:
1.
Locate the USB connector on the bar code scanner. Bar code scanners, like other computer peripherals, connect to the computer by way of a data cable. At the end of the data cable, most likely opposite the scanner itself, should be a small rectangle-shaped plastic and metal connector. This connector is the USB terminal that will plug in to the computer's USB port.
2.
Locate the USB port on the computer. The USB port, whether on the computer or a peripheral device, will be rectangular in shape and feature either the letters "U S B" or a small network diagram showing two circles, a square, and an arrow.
3.
Connect the USB cable to the computer or peripheral device. Once the USB connector and port have been identified, push the USB connector firmly but gently into the available USB port. USB connectors are keyed so that they can only be inserted the correct way; if you feel solid resistance while inserting the USB connector, remove the connector from the port, turn it over and plug it in.
4.
Install bar-code reading software. While the bar code scanner can scan the bar code into the machine, software must decipher the meaning of the code. Bar code scanners, if purchased new, should include a version of proprietary bar code software compatible with your scanner. If your scanner did not come with software, or if it is missing the installation disc, bar code software may be purchased on the Internet from sites like WaspBarcode.com.
TO INSTALL A SERIAL BAR CODE SCANNER, DO THESE:
1.
Locate the serial connector on the bar code scanner. Bar code scanners, like other peripherals, connect to the computer by way of a data cable. At the end of the serial cable should be a rectangular, typically male connector. The cable may be pinned with nine, sixteen, or more pins depending on the design of the scanner.
2.
Locate the serial port on the computer. Most computers have at least one serial port, usually found on the back of the machine. The port will be female, maybe blue in color, rectangular in shape, and should be approximately the same size (or slightly smaller) as the serial connector.
3.
Connect the serial cable to the computer or connected peripheral. When both the connector and port have been identified, push the serial connector firmly but gently into the port. Like USB connectors, serial connectors are keyed so that they can only be inserted the correct way; if you feel solid resistance while inserting the connector, remove the connector from the port, turn it over and plug it in. Do not use excessive force while pushing on the serial connector, as it is possible to bend the connecting pins and damage the connector.
4.
Install bar-code reading software. While the bar code scanner can scan the bar code into the machine, software must interpret the meaning of the code. Bar code scanners, if purchased new, should include a version of proprietary bar code software compatible with your specific scanner. If your scanner did not come with software, or if it is missing the installation disc, bar code software may be purchased on the Internet from sites like WaspBarcode.com.
THANKS AND WELCOME.
Apr 12, 2011 | Computers & Internet
I bought an Ion Slides2PC device yesterday. I installed the driver and the PhotoImpression 6 software tonight, but when I tried to launch the latter, I got a Runtime Error. What does that mean, and how do...
If you tried installing the 64 bit first on a 32 bit OS, that could be the issue.
Try doing a system restore back to a point before the installation, and install the 32 bit version and see if that fixes it.
Runtime errors can be a bit tricky to track down.
Mar 10, 2011 | ION Audio SLIDES2PC
Just trying to connect the scanner to my PC for the first time however the device is not recognised by the PC as a new piece of hardware. all connections are OK and have tried different leads
First of all you need to check whether the lock behind your scanner is open or not. If not, unlock it.
Two, if the secure lock has been opened already, but the system is still incapable of identifying your USB device, you can check if you have installed a scanner driver or if the driver is correct for your device.
Step 1 Find out your scanner model.
Step 2 Check Scanner driver in the Device Manager sheet.
Step 3 If you have not installed a driver yet, or the driver is incorrect, search on the website and download the supporting and latest driver for your USB scanner. Before installing the driver, uninstall the incorrect one. Note that when you install the driver, make sure it works well with your system.
Three, you can try to swap your scanner onto another USB port. Because if the cable order in this port is not right, it would also generate the failure above, which often happens in the motherboard's front USB port.
Four, your motherboard might not be compatible with your scanner's port, so you are unable to find out this device in your computer. To cancel it, you need to check the model of your motherboard chipset, download its latest driver or the corresponding motherboard USB patch from the website and then install this driver or patch.
Feb 06, 2011 | Plustek OpticFilm 7300 Film Scanner
My PC doesn't recognize my OVT scanner. Suggests I contact manufacturer regarding driver software support. Can I get access and a free download? What do I need?
this is the 32/64 bit drivers (copy and paste into your browser)
32 bit
http://www.ionaudio.com/stuff/contentmgr/files/26/d6d3a7895969750864ba4bd2db1ec94c/file /slides2pc_32_bit_windows_drivers_2.1.0.3.zip
64 bit
http://www.ionaudio.com/stuff/contentmgr/files/26/c62d2ba1c2036e5f1da81004314d23cb/file /slides2pc_64_bit_windows_drivers_2.1.0.3.zip
this will download the drivers for your product. you should not connect your device before installing the drivers. wait until the drivers are installed first. if you are unsure which version you are running, simple to find out .......
click start button, right click on computer, and select properties. the operating system version will be listed in the dialogue box.
Feb 03, 2011 | ION Audio SLIDES2PC
I have Windows 7 and have installed the correct driver, but it still gives a message - can't find scanner. Have tried uninstalling and re-installing a few times. Also looked on Google - it seems many...
if you ran the driver and it is installed ..check it on the device manager (right click on my computer ..properties/ hardware/ device manager ..and if the scanner appears in yellow you have to click right and update driver..It will run the add new hardware wizard and you will have to go along with it ..either let it make this manually ..it should find the driver you installed previously ..and install it ..or do this manually by choosing it from existing installed drivers..
There is always the possibility that the driver you have is not compatible ..so ..get on the support site and download the one for windows 7 from there or at least for the vista..
Jan 17, 2011 | ION Audio SLIDES2PC
OVT Scanner won't run with Windows 7. Vupoint
We suffered this initially on a new laptop with Windows 7. I can't tell if the driver on the Vupoint website has been updated, or is the old XP/Vista driver, but we installed this (1/2011). In Picasa or the Photoimpressions software which comes with the scanner, we were then only able to acquire solid black images. However, when we tried all of the USB ports on the computer, we found that one of them (a USB2 rather than USB1 port) was able to function like normal. We suspect there is a funny issue with the amount of power going to the scanner from different USB ports, and maybe this interacts with the driver in some way.
Jul 07, 2010 | Office Equipment & Supplies
Cable connectivity with my laptop through a "parallel to usb cable". My laptop has no parallel port but only usb ports.
make sure you follow this step :
1. install driver USB to Paralel port (LPT1) before the cable connected to PC
2. After the driver installed, install the cable - and it supposed to be detected
3. the last think u have to do is install the scanner/printer driver
if it is not work, i guess the problem is on the USB to paralel adapter, or the driver not installed correctly
Jun 01, 2009 | Acer ScanPrisa 640P Flatbed Scanner
ION Audio SLIDES2PC Logo
399 people viewed this question
Top ION Audio Office Equipment & Supplies Experts
Alun Cox
Brett Duxbury
Brett Duxbury
Are you an ION Audio Office Equipment and Supply Expert? Answer questions, earn points and help others
