Question about Dell Dimension 2400 PC Desktop
I need to find an adapter for my dell dimension 2400 to connect the speaker to the computer. Where do I find that??
    Brigadier General:
  • 10,406 Answers
Any set of "computer-speakers" will have a connector (usually GREEN coloured) that connects to the "line-out" (a GREEN circle) socket on your computer.
See: http://www.bestbuy.ca/en-CA/product/dynex-dynex-3-5mm-audio-cable-dx-mp353g-green-dx-mp353g/10153080.aspx
for a picture of the connector that will connect to your computer.
Posted on Mar 17, 2011
4 Suggested Answers
preachw996
  • 1179 Answers
SOURCE: Unsure if my wireless PCI adapter will fit in my dimension 2400?
You can get your systems exact specs on the Dell website under the support page. Hope this helps.
Posted on Jan 10, 2009
metropcstech
  • 115 Answers
SOURCE: What cable for Gateway FPD monitor to Dell Dimension 2400 compute
You can either use a dvi or vga cable, for more info go to http://service.gateway.com/s/Manuals/Monitors/8511253.pdf
Posted on Mar 03, 2010
  • 47 Answers
SOURCE: My Dell dimension 2400 monitor doesn't work when
Hi! For dell machines when u unplug the video cable/VGA from the tower while the system is on it will show monitor self test.If you are seeing a black box moving around the screen it means that monitor is ok.Check connection between monitor and tower.Make sure cables are securely plugged in.Check if the tower is ok. There is a possibility that your monitor is ok but the tower is not.check the power button (whats the color) if amber/orange, this means there is something wrong the the tower. If its blue or white it means its ok.Also check if you are going to hear one beep, it means system is booting up properly. If tower is ok and you are using a expansion video card then try to use internal one, normally its the vga port above the usbs.If you are going to use onboard video card make sure you enable it first in bios.If all things fail, contact your manufacturer, if the system is under warranty then they will send a tech to check the machine.hope this helps...
Posted on May 28, 2010
Dell dimension 2400 network adapter driver
The Dell Dimension 2400 drivers are available here: http://www.dell.com/support/drivers/us/en/19/product/dimension-2400 . Use another computer to visit the site and make sure that Microsoft XP shows in the OS search drop down. Expand the section labeled Network. The wired network adapter is a Broadcom 4401. The direct link to the latest driver (V. 3.63 released 8/5/2003) page is http://www.dell.com/support/drivers/us/en/19/DriverDetails/Product/dimension-2400?driverId=R64645&osCode=WW1&fileId=2731129724&languageCode=en&categoryId=NI .
A more recent driver for XP is available from Broadcom at: http://www.broadcom.com/support/ethernet_nic/4401.php . Select the driver for the 32-bit version for XP.
I hope this helps.
Mar 01, 2014 | Computers & Internet
Reinstalled Windows XP on an old computer (DELL Dimension 2400) and the monitor won't display above basic resolution. Downloaded and reinstalled the monitor driver and still no good. Opened up START
According to the Dell Support web site the Dell Dimension 2400 has a built in Intel 3D extreme graphics adapter, assuming you are using this and not a PCI graphics card.
Go to the Intel Download Centre and run their Intel Driver Update Utility which will automatically scan your system for updated drivers for any installed or integrated Intel devices.
If the Intel Utility identifies an updated driver for your graphics adapter then download and install that which should enable you to configure a higher resolution for your display.
Dec 24, 2011 | Computers & Internet
Dontno sound on speakers
Make sure the speaker cable from the speaker is connected to the speaker plug on the machine, usually green. If the speakers have an AC adapter make sure it is plugged into the wall outlet and to the speaker. Make sure the sound card is configured and working correctly. Make sure you don't have the sound muted. I hope this helps. Good luck and have a great day.
May 01, 2011 | Dell Dimension 2400 PC Desktop
Why no sound from my speakers with Dell Dimension 2400, even though it's equipped for sound? Speakers worked fine plugged into Compaq.
Please try other speakers to make sure that it is in fact the computer and not the speaker port itself. If other speakers work, then it is most likely a driver problem. Try to find the drivers for your speakers and install them, restart, and reconnect your speakers. Good luck!
Dec 22, 2010 | Dell Dimension 2400 PC Desktop
The volume knob from my right computer part Rev A00 broke off. Computer model Dell dimension 2400. Can I get a replacement knob and where?
Sounds like you broke the volume control knob for your speakers (Likely A215s)
Best bet, new pair of speakers as they don't sell replacement parts for the speakers themselves
Apr 24, 2010 | Dell Dimension 2400 PC Desktop
No audio from external speakers dell 2400 computer
hi,
1)Check audio Enabled in bios
2)Check whether audio drivers are installed in device manager if not install audio driver for DIMENSION 2400 from Support.dell.com
3)Check Audio port using Head phones to ensure is audio port is working fine.
4)If Dell speakers, check speakers Manuals from support.dell.com
Dec 04, 2009 | Dell Dimension 2400 PC Desktop
Dell dimension 2400, wireless internet
Hi Whitney,
I was able to locate manual and a troubleshooting guide.
  1. Manual
  2. Troubleshooting Guide
Summary: Your modem only supports 802.11b standard, which limits the throughput to max. 11Mbps (compare to 802.11g = 54Mbps, 802.11n = 108 Mbps). In other words: your connection is only about 10% of the speed compared to a wired connection via Ethernet cable (100 Mbps). So - if you can - you should try to use a wired instead of a wireless connection, but you have to decide what makes is more important to you: having no cable and you can be away from the modem or the connection speed.
This also means - and that is in regards to APremkumar's solution - that you can skip all 802.11n adapters (this would just be a waste of money). Since you will not find an adapter that only connects to a class b network, look for something like "802.11b/g".
An example page is here. You can choose between an internal (PCI card) or external (USB adapter) solution. Both are ok and the decision depends on the availablity of a free USB port on your Dell and your comfort of opening the computer case or not. (You can always come back here and ask for help;-)
If you have any more questions, please let me know - I'm happy to help!
Mar 30, 2009 | Dell Dimension 2400 PC Desktop
Jan 10, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
125 people viewed this question
Alun Cox
