Question about Biostar P4M900-M4 Motherboard
No audio output device is installed am not having any sound neither mic??? wats the problem pls help ??
    President:
  • 2,246 Answers
You need to install audio driver
insert your motherboard cd driver then chose to install audio driver
Posted on Mar 17, 2011
Output mic not working HP Mini
First go to start menu, control panel, sound and audio devices, click the voice tab, and make sure the voice recording has something listed. If not see if you can change it to your MIC. If you get no options in this box you probably don't have the mic installed correctly. If everything appears to be ok in this go to your volume controls, click options, click properties, and make sure you have mic selected in playback sections and check the boxes in recording settings then click ok, one you do this make sure alll volumes are unmuted and turned up.
May 28, 2009 | HP Mini 1000 Netbook
Can't install audio driver
i can't use the audio output device,,, it always says no audio output device is installed..
help me pls..
Apr 11, 2009 | ASUS M3N78-VM nVidia GeForce 8200 AM2+/AM2...
Sound is ok i hv mic problem
If you install the correct drivers, the audio device should work fine. That includes the microphone if present. Check your sound recording settings in Vista to make sure all the device selections, recording levels etc. are set okay.
Then try recording with the Vista sound recorder to verify.
Apr 05, 2009 | Dell Inspiron 1521 Notebook
Sonar LE: no playback b/c "NO MIDI OUTPUT" selected
You have to go in to the Sonar configuration and select what the default MIDI and WAV input and output devices are. That is usually handled by the ASIO driver. In your case you would select the USB mic for input, and for output you need to select your sound card. For midi you need to configure the midi controllers and the software synth or soft instrument you are using.
If you need any more detailed help I need to know what version of Sonar LE it is and what sound card. I am guessing it detected the mic and just needs the output device configured as I mentioned.
Dec 31, 2008 | Edirol UA-4FX External Sound System
Hi! when i play music on my lap top, it plays but no sound. pls help
you may need to take following steps:
Check Volume from the volume control
Check the sound output device is selected the same as your sound card in control panel, sound and audio devices section
re-install sound drivers
Dec 20, 2008 | Computers & Internet
Piano/keyboard won't work through imac
Try to connect to other input lines. If your computer has an input line except for mic input try to connect to it. Then configure the settings in your computer, go to the CONTROL PANEL on your computer click SOUNDS & AUDIO DEVICES then configure SOUNDS or AUDIO or VOLUME or VOICE. Then look for the device listed in your system that is available and compatible, then select the most appropriate. After that click APPLY then OK. There you go.
If this solution Doesn't work you must buy a sound card and for sure it will work. Having a sound card gives you several input lines and there is a particular input line for musical instrument like a keyboard in a sound card device. Installing a sound card is easy, and i'll show you. First you must insert your sound card device into your motherboard's PCI slot (most of the motherboards have 3 PCI slots) choose one and take note that your PCI sound card plugs in exactly in that slot so its very easy. After inserting your sound card install the driver for your sound card, install is easy just follow instruction. If you have done this, there you go.
Good Luck!
Pls. rate me if this helps.
Jun 10, 2008 | Casio Computers & Internet
Sound device
reformat & repair your OS & setup
Apr 14, 2008 | Microsoft Windows Vista Ultimate Edition
Plug mic and earphone to the front panel
hi!gud am...hope this will help...
have you check if your audio controller is working?have you installed the driver?if not check this out...start>control panel>system>hardware>device manager>sound,video and audio controllers...
is your mic and earphone new?if not try to replace it with a new one maybe its broken that's why its not working...
check if the front panel audio is connected on your mobo...some casing with front panel audio has no connection...let me know what you see and tried ok?
goodluck...
Feb 28, 2008 | EPoX EP-4PLAI Motherboard
C707TU LAPTOP DEVICE DRIVER WIN XP BASED
I AM NOT GETTING DEVICE DRIVERS FOR C707TU FOR WINDOWS XP OS. PL GIVE ME THE LINK FROM WHICH I CAN DOWNLOAD ALL THE DRIVERS LIKE AUDIO, DISPLAY, MODEM, LAN CARD, WIRELESS LAN ETC. ETC.
Nov 26, 2007 | Compaq Presario 700 470024-192 Notebook
Biostar P4M900-M4 Motherboard Logo
158 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
