Question about Apple iPod touch
Come togliere delle icone che non mi interessano
    President:
  • 2,246 Answers
You can remove an app from your iPod touch in the same way that you re-order items on the home screen: tap an icon and hold it down until the icons begin shaking.
When this happens, every icon will have a black X in its left corner. Tap the X to remove the app from the device.
This will not remove the app from your computer; it will still be on your desktop and can be added again later.
Delete it for Good To completely delete the app, you'll need to remove it from your computer's hard drive, too.
To do this, go to the Applications menu in the left-hand tray in iTunes.
On the screen that lists the apps on your hard drive, single click the app you want to delete. You can then right-click on it and choose delete or hit the delete key on the keyboard.
You'll be asked to confirm the deletion. If you really want to remove it forever, confirm. Otherwise, cancel and let the app live to be used another day.
Remember, though, if you delete the app and decide you want it back, you'll have to download it again and, if it costs money, pay for it a second time.
see this video
Posted on Mar 17, 2011
Buon giorno, la mia macchina Saeco Magic de Luxe e' appena stata in assistenza ed hanno dovuto cambiare la scheda. ora non riesco piuu' a far girare acqua nel circuito. accendo la macchina ma mi...
Anch'io ho lo stesso identico problema, l'ho smontata, ho dato un'occhiata e credo di aver capito che il problema sia la turbina (rotta) ma non ne sono sicuro..!! Ho dato un'occhiata in rete e una turbina costa circa 12 euro... credo convenga fare questo tentativo..!! Ciao Adriano
May 10, 2011 | Saeco Magic De Luxe Espresso Machine
OGNI ACCENSIONE (ANCHE SENZA TOGLIERE LE PILE) MI CHIEDE DEL'IMPOSTAZIONE DATA. FACENDO TALE COSA NON SI IMPOSTA NIENTE, PER USARE IL PRODOTTO DEVO FARE OK, LA DATA MI RISULTA SEMPRE DEL 2003.PERCHE' TUTTO...
Ciao Pino.
La Polaroid ha una batteria interna saldata sulla scheda madre (Altre marche e modelli usano una batteria tipo monetina, la Kodak ha una batteria saldata). Questa si ricarica usando le batterie principali. La batteria interna ha una autonomia di diverse ore. Il suo ruolo e' preservare le impostazioni.
Se il problema sussiste anche quando le pile nello slot sono cariche, vuol dire che la mini batteria saldata dentro la camera e' diffettosa, e non mantiene la carica.
Una camera da 5 Mp oggi vale meno di 50 euro. Se la camera funziona non vale la pena ripararla.
Ginko.
Mar 12, 2011 | Polaroid A500 Digital Camera
Message Code: CA1
ANCHE A ME MI DA CODICE MESSAGGIO CA1 E NON MI DA LACCESSO AL POKER MI RESTA DI PENSARE CHE SIA TUTTA UNA TRUFFA AL QUADO ANCHE COMPRANDO CIPS NON MELE INVIA
Mar 05, 2011 | Zynga Texas HoldEm Poker
Non so inserire la sim card al cellulare serene della bang e olufsen
Il design ha costretto gli ingegneri ad "ingegnarsi" per trovare una collocazione di sim e batteria. Il tutto si traduce nel fatto che per inserire sia una che l'altra bisogna prima consultare il libretto di istruzioni, cosa rara al giorno d'oggi. Bisogna infatti svitare le finte cerniere del telefono, togliere tutto un guscio e sotto inserire sim e batteria.
Feb 06, 2011 | Cell Phones
SAMSUNG S8300 QUANDO MI CHIAMANO I CELLULARI , IL TELEFONO RIMANE IN MODAITA' VIBRAZIONE, SENZA EMETTERE NESSUN SUONO. GRAZIE, DESY
Spero che non sembra troppo ovvio, ma hai provato di cambiare il profilo? Menu --> Impostazioni --> Profili
Mi scusa se sia qualche errore - l'italiano non e` la mia madrelingua.
Nov 07, 2010 | Samsung Cell Phones
Salve ho inserito la chiave di rete nel router belkin che ho acquistato e funziona ma ora ho un problema mentre il pc entra in automatico con il cell. IPhone ogni volta mi chiede la chiave di rete...
non solo emette segnali router Belkin e tutte le reti wireless dipendono da una singola password, controllare il prodotto in modo da poter ottenere Connected
Oct 26, 2010 | Belkin (F5D7230-4) Router (587009)
Salve , possiedo un samsungHT-DS400 che quando vado ad accendere mi appare sul display la scritta on protection per qualche secondo...per la samsung il pezzo che andrebbe sostituito non è...
Ciao Massi.
Come saprai, protection indica un errore generale, e non dice dove sia il problema. Semplicemente indica che il tuo Samsung ha rilevato un voltaggio incorretto, e che il sistema viene temporaneamente forzato in stato di standby chiamato protection (i Massive Attack ci avevano fatto su una canzone).
Il supporto tecnico Samsung non sa quale parte non funziona, semplicemente sospetta che il problema sia la PSU (circuito di alimentazione), la quale e' probabilmente il guasto piu comune in questi apparati.
Siccome le parti per questa unita' non sono piu distribuite (solo il telecomando e' disponibile), il supporto tecnico ha giustamente consigliato di sostituire il sistema.
Qui lista parti, le poche parti elencate non sono in stock.
Tutto quello che puoi fare e' assicurarti che le connessioni alle casse ed al sub siano intatte. Se un cavo fa corto, allora l'unita centrale segnala Protection.
Se il problema non e' un cavo balordo, l'unita centrale, il Sub, e qualcke volta ancke le casse (connessione ai coni in corto) devono essere aperti e testati da un tecnico.
Un lavoro del genere puo richiedere svariate ore, e generalmente non vale il prezzo dell'originale in un unita di questo tipo.
La riparazione e' fatta testando i punti di saldatura e i componenti, e richiede conoscenza tecnica.
Controlla i cavi, se non trovi niente, la riparazione puo essere fatta da un tecnico locale, il prezzo in Italia e' probabilmente tra i cento ed i duecento euro. Sono piu di dieci anni che io non lavoro piu in Italia e non saprei dire. Quando lavoravo li' la tua fattura sarebbe stata intorno alle 80/100mila lire un po meno se il problema si trova immediatamente (a volte puoi proprio vedere che un componente e' esploso, accade frequentemente con i condensatori dell'alimentatore, altre parti, come I chip del finale dell'amp, non mostranon alcun segno quando vanno male, nel tuo caso il problema non deve essere facile da identificare a prima vista perche il sistema ancora funziona, con un condensatore esploso il sistema rimane in protezione ).
Buona fortuna.
Ginko.
Sep 29, 2010 | Samsung HT-DS400 System
Non funziona il tasto virtual surround sound.non
Per il tasto surround, sempreché non sia un danno hardware, prova a reinstallare drivers: http://support.acer-euro.com/drivers/notebook/as_6920G.html
Per il problema delle SD Card, verifica che il lettore SD sia elencato in Hardware del Pannello di Controllo. Se non lo è, il problema è di driver oppure grosso guaio hardware (improbabile). Se lo è, potrebbe essere un problema con la scheda SD (prova con un'altra), o semplicemente sporco il contatto all'interno del lettore, che può pulire con aria compressa o inserendo/disinserendo la scheda SD poche volte.
Jun 07, 2010 | Computers & Internet
Ho un htc 3450 e non mi invia più gli
sorry I could understand but go to the store i am sure thy will help
Apr 08, 2010 | HTC Touch P3450 Smartphone
Lettore cd/dvd acer aspire 5630
Ciao,
Allora, ho il tuo stesso pc e mi è già capitato il prob. Mi sè risolto formatando il pc ma non è minca finita qui..
dopo un mesetto mi si ripresentato. La coluzione defintiva è stato quella di sfruttare la mia garanzia per farmene spedire uno nouve di zecca. Ovviamente solo il pezzo guasto.
Se no puoi provare a smontarlo e pulire il lettore dvd con l'alcol (xkè evapora).
Tienimi al corrente per eventuali sviluppi.
Ciao
Jul 18, 2008 | Acer Aspire 5630 Notebook
Apple iPod touch Logo
41 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
