Question about Dell Studio XPS 13 Laptop Computer (Intel Core 2 Duo P8800 500GB4GB) (dypcgp31) PC Notebook
I have a Dell Studio XPS 13 and a few months ago my speakers suddenly stopped working. I lived with it for a while by jut using a headphone jack. However, lately both of my headphone jacks have stopped playing through the right earphone. I was just wondering if it was a hardware problem or a software problem. Thanks in advance for the help. P.S. I have already checked to make sure that both the headphone jacks sensors aren't "stuck" and have already checked audio drivers and my default playback devices.
  • ukfan1991 Mar 17, 2011
    Thanks genuinegemin. But no luck. I loaded up in Dell Diagnostics and it played through the speakers fine, but still a problem with the right earphones in both headphone jacks. I am going to open my laptop up because it looks like a cable problem. Thanks again!
    Scholar:
  • 117 Answers
Check the device manager in the windows control panel and make sure your audio device is listed and has no conflicts present. If all is good there, I suggest downlading the latest driver, then uninstall/remove your audio device from the device manager, then install the new driver and let the computer rediscover the harware. Sometimes it just helps when the computer thinks it's a new device.
Posted on Mar 17, 2011
  • Christopher Warnick Mar 17, 2011
    Well it seems to me that if the speakers worked fine in the diagnostics test then it would be a software problem within windows. Maybe a resource issue or communication issue between the hardware and the software. The sound is hardwired to the motherboard so if it was bad it wouldnt work in any state. The headphone jacks may need to be cleaned or the ground contact inside the jack maybe needs to be bent back into position. A flashlight and a micro flat head screwdriver can achieve that, but be careful not to pry to hard. I would suspect a cable or wire issue as a near last resort. Hope ya get it workin.
I've a peavey vypyr 75 amp I used it with the headphones, few days ago it stops the output to the speaker, but it works if it's auxiliary input means the speaker is OK. From the jack input to the...
Phone output jack connector, this kind of connector acts as a switch that when you have your earpieces connected the speaker is automatically disconnected, and when you unplug your earpiece then the speaker activates, so there's your issue.
Oct 01, 2013 | Peavey Audio Players & Recorders
I have Seinheiser HD 202 headphones that my dad bought me for Christmas about a year ago. About a few months ago the left earphone stopped working. I have tried messing with the jack but that didn't seem...
The fault is in the cable: you will have to dismantle the left speaker housing and start cutting from the cable until the break is removed then solder it back to the speaker - use an multimeter to check the continuity of the wires.
Oct 10, 2010 | Sennheiser HD 202 Consumer Headphones
Speakers getting power but not sound
check the speaker.. could be burned or open connection
May 17, 2010 | Logitech Z523 2 Speakers
Dell D810 speakers do not work, but headphone jack does work
It seems as though you might have a bad plug, There is a set of tabs that tell the laptop whether to use the speakers or the headphones. This switch may of locked into the headphones position. This is probably a case of where you would need to replace or repair the headphones port. check to make sure there is nothing in the port to block it. You can also try applying some light oil on the end of a headphones jack and placing it in and out several times to break free a possible stuck part. It also may be a case that the solder mark on the board has disconnected itself from the headphones jack and needs reseating. This would be a difficult fix but not at all impossible.
Apr 26, 2010 | Dell Latitude D810 PC Notebook
Dell studio xps no sound will come out of the speakers
I assume you mean the internal speakers.
First thing I would try is hooking up a set of headphones. If you can hear sounds thru the headphones then there could be an issue with the headphone jack. (the jack acts like a switch, switching OFF the speakers when you have a plug inside, and switching them back ON when you remove the plug).
If you dont hear sounds thru the headset or speakers, check your device manager, and remove/reinstall your audio driver. You can download the driver at the dell website Support.Dell.com.
Oct 26, 2009 | Dell A525 Computer Speakers
I have a 4 month old Dell Studio 1535 laptop, with audio problems
Firstly check that the microphone level is down or turned off as this sounds like some sort of feedback that's being produced.
Check the microphone and try to play music again.
Please post back
Good luck.
Oct 02, 2009 | Dell Studio 1535 Notebook
Dell studio 1737 speakers crackle and pop.
My best guess is, if they crackle with the speakers but not the headfones,  then replace the speakers. Must be a lose wire or something of that nature.
Jul 27, 2009 | Dell Studio 1737 Laptop
No sound from X-530 speakers
unless you are capable of replacing the jak on the speaker u need a new pair. the wiring functions the the jack which is now broken
Sep 30, 2008 | Logitech X-530 Computer Speakers
Dell Studio XPS 13 Laptop Computer (Intel Core 2 Duo P8800 500GB4GB) (dypcgp31) PC Notebook Logo
119 people viewed this question
Alun Cox
