Question about Viking DEDO205 Stainless Steel Electric Double Oven
Where can I get the stenciling for the over settings that go around the knows on the oven. These have worn away and I can't tell what the setting are when I move the knobs. It is a Viking DED0205SS model.
  • tami truong Sep 19, 2012
    I have the same problem. The control panel worn out and can't be read to control temperature. I just order new control panel and it is not much better. The writing are very light. I call and complained. Now they are resend a new panel. I hope the new one will be better. The only thing I like to know is can the DEDO 200 can be replace with digital control?
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: I have an AEG cooker but the marking around the cooker knobs have
Hi.
You need thermostat knob and main oven control knob.
Posted on Nov 20, 2008
SOURCE: lost manual for eaton/viking model # RS3025W-1.
set both knobs the temperature and the bake broil to the lock mode, set the time such as 3 to 4 hrs I think and hit start. You should then here the oven begin to lock.
Posted on Oct 16, 2009
  • 250 Answers
SOURCE: can no longer read the temperatures around the oven knob
On the 720EF the numbers are recessed behind a small glass panel, so I think you are not talking about the same unit. If all else fails, I suggest you buy an oven thermometer from say Lakeland - they are about 4 to 5 pounds and are good. Run the oven, making a note where the marker is and see what temperature the thermometer gives.
Failing that, run the oven with the thermometer in all the time and experiment to see what the control; knob is pointing at for any given temperature.
Posted on May 08, 2010
Testimonial: "Thanks for that, will try it asap!!"
No I see double wall oven
I have a B50STIP/1 wall oven who oven selection dial has worn away.
Can someone please tell me what is on the dial at 5.00 oclock?
Thank you ,
Liz
Jul 13, 2013 | Ovens
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
We are renting a property with a Westinghouse mod 05-208307, never used it before, the setting have worn off around the oven nobs and don't know what they where pls help, can use over
The knob is the image of this link http://www.repairclinic.com/PartDetail/Knob-Dial-or-Button/5304441580/1063188 is pretty typical of all westinghouse knobs, that one shown is for westinghouse and perhaps can give you a good idea of the temp. set based on how far you turn it
Gene
Aug 13, 2011 | Ovens
Can you tell me how to get the bottom oven in my belling 317 to work please
You may need to set the clock on the front first. Sounds silly but I had the same problem.
Jul 03, 2011 | Belling XOU487 Electric Double Oven
The temperature printing on the fascia of the oven around the knob has worn away. What can I do to find the oven temps?
Place an oven thermostat in the oven compartment, this will give you a reference point from which you should be able to determine the various settings to set the thermostat to.
The only other option is to replace the facia panel
Jan 08, 2011 | Ovens
Cant fix the clock to work without the timer
if you are having trouble setting the clock times etc this is probably down to a worn bit generator this is the knob you turn to set the time they get dirty when using oven or grill and wont operate properly,the clock will need changing im afraid as there no way to open the clock without destroying it.
hope this helps
Jul 09, 2009 | Neff B1421 Electric Single Oven
Temperature settings have worn off.
this is a tappan range any tappan dealer can help you find the knobs
Apr 20, 2009 | Ovens
Hi.
Nov 19, 2008 | Ovens
None of the controllers match the one in the oven I have
Hi jeff I found a site more information about oven,more about error codes of the sensor.
http://www.repairclinic.com/0078.asp#KitchenAid
http://fixitnow.com/oven-repair-faq
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
http://www.repairclinic.com/0003.asp
http://www.repairclinic.com/0047_13.asp
jeff checked these site and message whatever the result...
Jun 29, 2008 | KitchenAid Architect Series KEMC308KSS...
Viking DEDO205 Stainless Steel Electric Double Oven Logo
82 people viewed this question
Top Viking Ovens Experts
Dan Webster
Dan Webster
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Viking Oven Expert? Answer questions, earn points and help others
