Question about Porter Cable Tools & Hardware - Others
I have a Porter Cable FC350-Type 2 Nail Gun . The nails do not feed consistently , misfires . What is causing this . I am using 30 degree 3" nails .
  • 2 more comments
  • rasorf Mar 17, 2011
    I have oiled the gun and also pulled the spring back and snapped the nails to be sure they are seated at the end . Still the gun misfires .
    I have oiled the gun and tried pulling back the pusher loading spring and letting it snap back to hopefully set the nails at the end . But the gun still misfires . Eventually , the gun would fie a nail after many tries.
    What nails are to be used ? I am using 3" 30 degree clipped head
    What gasket are you referring to ?
    Genius:
  • 1,114 Answers
I would check the tension on the spring that pulls the nails into position. Make sure that when the rack of nails is out, that the loading mechanism is reaching the top of the gun. I would also recommend that you oil the gun prior to each use. If you are using it regularly through outt the day, then I would definitely recommend oiling it through out the day.
Posted on Mar 17, 2011
  • 1 more comment
  • Charles Huckeba
    Charles Huckeba Mar 17, 2011
    Have you tried switching nails? If you are using PC nails then it shouldn't be an issue. How old is the gun? It may have a bad gasket in it.
  • Charles Huckeba
    I would recommend that you use Porter Cable nails, sometimes other brands of nails will not feed right, either due to the gluing compound that holds the nails in the rack form, or simply the design of the nail will that will not allow the gun to feed, of function properly. In all nail guns there are a series of gaskets that create a seal for the pneumatics to work correctly. If one of these gaskets are faulty, then you can have a misfire/feed as well.
  • timbvr
    timbvr Sep 05, 2012
    also check your bumper and piston stop ,the early modles were made of white nylon that deteriorates and just crumbles to peices keeps the piston from returning to the top this keeps the nails from feeding. any 30 to 34 degree nail strip will work clipped head
Can you use 30 degree nails in a Porter Cable FC350 34 degree nailer?
Yes, you can use 30 degree clipped head nails in the Porter-Cable FC350 framing nailer. The FC350A and FC350B nailers are newer models that specify the 30-34 degree clipped head nails. Make sure that the nails are between 2' - 3 1/2" in length. The manuals for each of the later models do not explicitly list the 30 degree nails. Their specifications page do list the 30 degree nails. See http://www.portercable.com/Products/ProductDetail.aspx?ProductID=11542 and https://www.homedepot.com/p/Porter-Cable-3-1-2-in-30-Degree-to-34-Degree-Clipped-Head-Framing-Nailer-FC350B/203555581 . The manual for the FC350 is available here: https://www.manualslib.com/manual/132288/Porter-Cable-Fc350.html . It is the same as the manual for the FC350B, https://www.homedepot.com/catalog/pdfimages/7e/7e0d0f88-a9e7-4411-ad0f-7fc5c1c1fbaa.pdf .
I hope this helps.
Mar 21, 2018 | Porter Cable Air Tools & Compressors
What degree nails to use?
Your gun uses 22 degree round head plastic strip nails. Most likely nail that is easy to find in stores is 21 degree nails for Hitachi , Duo Fast and others. Both work ok.
Apr 03, 2013 | Porter Cable Cable No. FR350A Rnd Head...
Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
I have a porter cable fr 350 an it says to use 22 degree nails it i have always used 21 degree nails in it will this hurt the gun
There are many different brands of nails sold for your gun. Nail companies try to sell nails to fit as many different guns as possible in one box(will range a few degrees). I have found that the stated angle is not always exact. To determin the best nail for your gun, place a strip of nails on the outside of the rails with top of the strip of nails (nail heads) aligned with rails. Now slide the nails forware to the centerline of the path of the driver. If a perfect fit, the first nail will align with the rails and the path of the driver. Note if the bottom of the nail is ahead of the nail head. If this is the case the driver will not hit squarely on the head of the nail. If the head is in line with the driver but the shaft of the nail angles back toward the rails, the nail may jam against the nose. Use your best judgement when buying nails. If you have not had a jam, keep using the nails, however test the nail as described above for good fit. Good luck
Sep 06, 2011 | Porter Cable 60074 Overhaul Kit For FR350...
Can you use regular round head nails in the cliped nail version ?.
Your gun uses 30 -34 degree clip head paper tape. Order a sample of the nail below. It may work on your gun. These are offset full round head with paper tape. Safe way to test if nails will work is to remove the head of the gun and insert nails into rails. Push down on the driver with wood handle of hammer to eject nail. This will test for jamming or two nails trying to eject and cause jam. Look down barrel to see if the head is alighed correctly or too far from centerline of driver.
http://www.mazenails.com/catalog/catalog.php?page=PAGE04&group=PT34
Aug 24, 2011 | Porter Cable Cable No. FC350A Clipped Head...
Can i use full round head 3-1/2 passlode nail in this nailer
The FC350A uses a 30- to 34-degree collated clipped head nail which is very similar to the Paslode 34-degree round head nail. Paslode's nails are unique because the round head nails collated very close together and the head of the nail is offset to the shaft unlike Porter Cable full round head are further apart and the head is centered on the nail. What does all this mean? The Paslode round head nail may work however the driver will deliver the blow off center to the shaft of the nail, This could cause the nail to bend as it enters hard wood and possibly jamb the gun. You should be able to exchange the nails (with small restock fee) at a major fastener store (not Lowes or etc. ) with out having purchased them at location because the Paslode nails are very popular and with todays economy the store will gain a new customer. If however you would like to try using the nails, try the following. Remove the head of the gun to expose the driver. Install the nails as usual and with **** of small hammer quickly and firmly push driver all the way down the cylinder to see if nail is easily pushed out of bottom of nose. (You can push driver back up with long thin screwdriver or allen) If successful, replace head and connect to air however lower pressure to 40-50 psi and nail into soft wood increassing the pressure little at a time with each test untill full pressure around 90-100psi. Good luck
Jul 19, 2010 | Porter Cable Cable No. FC350A Clipped Head...
I just bought a porter cable fr350a nail gun and need to know what type and angle nail goes in it.
it will shoot a nail from .113 to .148 diameter plastic collated full round head from 2" to 3 1/2" 22degree nail. If you want you can download the instruction manual from Dewaltservicenet.com and type in your model number under looking for manual it is 15 pages long. If I have helped you with your request would you please rate this response accordingly and thank you.
Nov 12, 2009 | Porter Cable Cable No. FR350A Rnd Head...
Trouble finding 3 1/2 clipped head nails 34 degrees
You can use the same nails that are used for these nailers: Porter Cable FC 350A, Hitachi NR83AA2, Senco FramePro 701XP, 751XP ,Ridgid R350CHA, DeWalt D51822, D51823, and Paslode F-3505. Make sure you purchase the correct shank nail. Nail length should be 2"- 3 1/2" and the shank should be .113" - .131". I have purchased nails for my FC350 at Home Depot and they are relatively inexpensive. Though you have to buy a case of like 2000 or 4000. The brand of nail is Grip Rite that I purchased. Any questions please post.
Oct 06, 2009 | Campbell Hausfeld 3 1/2" Rh Fram Nailer
Framing nailer intermittently doesn't shoot the nail.
Make sure to blow out the magazine where the nails load, make sure the spring tension on the nail clip is working properly, make sure you're not holding the clip somehow with your off hand so the clip can't feed correctly.
Apr 20, 2009 | Tools & Hardware - Others
Tools & Hardware - Others Logo
646 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim Parker
Jim Parker
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
